Fading Signal: The Neglect of Electronic Warfare.
Old April 8th 08, 10:14 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
William Black[_1_]
Default Fading Signal: The Neglect of Electronic Warfare.
"Paul J. Adam" wrote in message
In message , William Black
writes
"Jeff" wrote in message
e.com...
The more sophisticated jammers only switch on when a signal is detected,
hopefully quickly enough to stop a detonation.
They'll make electronic garage door openers, radio type car alarm tags
and
a huge assortment of other things entertaining to use...
You'll just have to wait for the HMMWVs to drive past before your car will
unlock, your garage door open or your cordless phone ring.
It's counterproductive to shut down a neighbourhood, you just need to
prevent detonations within lethal distance.
It also gives a nice easy system to tell the snipers that they're coming.
Sound of telephone ringing, a voice says "They are at point Mustapha" (or
"Aunty Fatima says your washing is ready" if they're being really paranoid
about things)
The guy knows they'll be around the corner any minute and redies his .50
calibre sniper rifle...
William Black
I've seen things you people wouldn't believe.
Barbeques on fire by the chalets past the castle headland
I watched the gift shops glitter in the darkness off the Newborough gate
All these moments will be lost in time, like icecream on the beach
Time for tea.
  #32
Old April 8th 08, 10:47 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Paul J. Adam
writes
about things)
You need less than that. Not much help for the snipers...
The nation that makes a great distinction between its scholars and its
warriors, will have its thinking done by cowards and its fighting done
by fools.
-Thucydides
pauldotjdotadam[at]googlemail{dot}.com
  #33
Old April 9th 08, 02:54 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Andrew Swallow[_2_]
Jeff wrote:
BTW, do those jammers send white noise, or are they smart enough to
fake a signal? Say, I build a small detonator from RC car parts, and it
depends on the transmitter sending "left, right, left..." every 30
seconds, with a timer starting on every signal, counting down until the
opposite side timer is started.
With a white noise jammer, no signal gets through anymore, 30 seconds
later you get *bang*...
But that is not a system that you would want to use for real, any kind of
failure or signal interuption would cause a detonation.
[snip]
Providing they kill someone they do not care. Terrorist organisations
have repeatedly show that they consider local civilians to be targets.
Western soldiers are just higher valuse targets.
Andrew Swallow
  #34
Old April 9th 08, 06:50 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
BlackBeard
On Apr 8, 7:41*pm, Mike Williamson
* * And the Air Force had to walk from electronic warfare.
* * Since the idiots still don't understand that nothing is as
* * stealthy as an electonic Satellite.. Since the "Radar"
* * the idiots are evading, isn't radar, it's the media.
* *I hate to interrupt a good show of rhetoric, but the Air Force
hasn't "had to walk from" electronic warfare, as we still have
a dedicated electronic attack platform, that has been deployed
for the last 4 years and counting- an online base "paper" article
noted one of the two deployed squadrons passing the 10,000th combat
flight hour associated with that deployment in January of
last year.
* *As to the rest of the paragraph- *what??
Mike
You are replying (arguing with) to a failed turing-test net-bot. Your
replies to it will only instigate further senseless posts. Ignoring
it completely (and not mentioning its name) is the only way to get it
to go away.
(it is a 'failure' in the worst way because occasionally its handlers
tweak its answers to attempt to debunk doubters. That is scientific
fraud.)
BB
I guess everybody has some mountain to climb.
It's just fate whether you live in Kansas or Tibet...
  #35
Old April 9th 08, 06:52 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
BlackBeard
On Apr 8, 9:15*am, "William Black"
Almost certainly the big drop was caused by training people how to spot the
bloody things.
Not according to the article.
"Thomas said the technology works by "basically providing a protective
bubble around a vehicle," jamming incoming signals and blocking the
remote detonation of bombs."
BB
  #36
Old April 9th 08, 01:09 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
William Black[_1_]
"BlackBeard" wrote in message
On Apr 8, 9:15 am, "William Black"
bloody things.
If that's the case then expect the lull to last for only a couple of months,
until the bad guys get hold of a technology that works.
William Black
Time for tea.
  #37
Old April 9th 08, 04:59 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Paul J. Adam
writes
Whereupon the ECM gear will be modified to suit. The kit being used in
2005 is pretty much obsolete now... the WIS guys don't sit on their
laurels either.
by fools.
-Thucydides
  #38
Old April 9th 08, 05:25 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
William Black[_1_]
writes
months,
laurels either.
True.
But the countermeasures people have to react. It's not something you can be
proactive about...
William Black
Time for tea.
  #39
Old April 9th 08, 05:39 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
beausabre
[snip]
Andrew Swallow
SNIP
Actually, a paper I read points out to the fanatic of any stripe, it's
the act, not the result that's important. If I get killed before I can
kill the enemy, that's unfortunate, but I 'm still a hero/martyr since
I died in the attempt.
  #40
Old April 9th 08, 05:44 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Jack Linthicum
[snip]
Andrew Swallow
SNIP
could you? would you?
CG(X) And The Future Of Naval Warfare. Mike[_1_] Naval Aviation 0 December 14th 07 05:28 PM
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy Mike Naval Aviation 0 December 27th 05 06:23 PM
GPS - losing signal Hilton Piloting 6 October 23rd 05 07:18 PM
Fading Rocker Switches O. Sami Saydjari Owning 2 February 16th 04 03:54 PM
asymetric warfare phil hunt Military Aviation 505 January 23rd 04 12:31 AM
