High altitude Helicopter work
Old November 17th 03, 01:59 PM
Allen
Default High altitude Helicopter work
I am curious about use of a chopper in the higher altitudes of
Afghanistan. The Canadians are in Kabul and the word is our Griffin, a
Bell 412 helicopter, can't work in the mountains. Anyone now why.....
lack of power at altitude, lack of oxygen ?
Allen
Old November 17th 03, 06:46 PM
Simon Robbins
"Allen" wrote in message
Rather than lack of oxygen, I imagine it would be that the lower air
pressure simply means the rotor is unable to achieve lift without an
unacceptable increase in rotor speed, which would likely overstress the
engines and gearbox.
Have a look at:
http://www.bellhelicopter.textron.co...pec_detail.htm
and you'll see the service ceilings. Not much room there to take mountains
into account, less so with a full load.
Si
Old November 17th 03, 07:16 PM
B2431
Date: 11/17/2003 12:46 PM Central Standard Time
Message-id:
Have a look at:
http://www.bellhelicopter.textron.co...z412EP_spec_de
tail.htm
Si
There was an example of that which made the rounds last year. There was a high
altitude rescue involving an H-60. The helicopter simply dropped out of the
sky, hit the mountain and rolled down the slope.
If anyone has a clip of that please post a link.
Dan, U.S. Air Force, retired
Old November 17th 03, 11:47 PM
Archibald
Highest heli-rescue was in Nepal...Mount Everest, 7000 meters i think.
That's pretty high! Anyone know what it was? Gazelle i think?
Message-id:
Have a look at:
tail.htm
Si
Old November 18th 03, 12:10 AM
David Lesher
"Simon Robbins" writes:
I've wondered what keeps you from building a high-altitude version.
I envison big fat blades and an engine design for thin air. Or is there
some other issue I'm not seeing?
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old November 18th 03, 02:00 AM
steve gallacci
Actually, that was a windy situation on a very steep slope that ended
with a rotor strike (if I remember correctly). The footage clearly
showed the machine hovering, attempting to get in close, then things got
bad. It was on Mt Hood or Mt Rainier.
But many helios have fairly limited ceilings and simply can't go very
high.
Old November 18th 03, 03:27 AM
Larry
The footage clearly
Right down the street at Mount Rainier.
(¯`·._.· £ãrrÿ ·._.·´¯)
"steve gallacci" wrote in message
a high
high.
Old November 18th 03, 05:00 AM
Dick Snyder
On Mon, 17 Nov 2003 20:19:57 -0500, "Allen"
Thanks for the info guys. I checked out a web site with articles by the
crews of the CH-47Ds that worked the mountain ranges in Afghanistan.
They frequently did landings at 17000 - 20000 ft. All very interesting
and informative.
Allen, RCAF/Canadian Air Force, retired
Mind posting the link. As an ex-hook driver from during the
Vietnam era I'd be very interested. Our A-models had a service
ceiling of 12,500 due to hydraulic cavation. Hooks, at least the A,
B, & C models (all of which I flew), are hydraulic dependent (an
understatement to say the least). Can't even spool up the engines
without pressurizing the systems with the APU. A lot of changes were
made on the D model however.
Thanks,
Snyder, US Army, retired.
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 12:39 AM
Low and high altitude airways David Megginson Instrument Flight Rules 7 September 9th 03 01:18 AM
High Altitude operations (Turbo charge???) Andre Home Built 68 July 11th 03 11:59 PM
