FAR 91.113d Question.
Old April 12th 08, 05:19 PM posted to rec.aviation.piloting
SD
Default FAR 91.113d Question.
Hello-
I have a quick question/concern regarding FAR 91.113d. I pretty much
grasp the concept well. Basically apply the acronym BGAAR (baloons,
gliders, airships, airplanes and helo's). For example, If I am flying
my Cessna and a balloon is about 2 mi ahead of me I will alter course
to the right and give it the ROW. Likewise for any of the other items
on that list except, helo's, right?
Well in the event that I come across a vessel that is not listed in
91.113d, what do I do? Yesterday I was flying and a Rombulan Warbird
decloaked and was dead ahead of me. I tried to hail him but I had no
luck. Since he was traveling at impulse power I was able to maneuver
around him. There was no wake turbulence or anything of that sort.
Although starships are not included in 91.113d, I typically just give
them the right away. Its easy on planet earth since we are in
Federation airspace, all federation vessels are not cloaked and tend
to travel at impulse power. I am concerned about the Rombulan Warbird
however.
What should I do in this case especially if I cannot hail the
Warbird?
Old April 12th 08, 05:32 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
SD wrote in news:258bf789-9611-4bf9-8d8d-
Hello-
however.
Warbird?
You mis-spelled Romulan
Bertie
Old April 12th 08, 05:59 PM posted to rec.aviation.piloting
Peter Clark
On Sat, 12 Apr 2008 09:19:54 -0700 (PDT), SD
Hello-
however.
Warbird?
Who has better manuverability? Better manuverability has to give way.
Old April 12th 08, 06:25 PM posted to rec.aviation.piloting
Fleet Intelligence identified that as a Tholian accent.
AKA Thought-Captain K'anttiah Tai Hazar
Old April 12th 08, 06:29 PM posted to rec.aviation.piloting
muff528
"SD" wrote in message
Hello-
however.
Warbird?
You should then immediately hail Mary.
BS,TP
Old April 12th 08, 07:28 PM posted to rec.aviation.piloting
Jim Logajan
How can a dead Warbird do anything, much less disrobe?
You should have fired your phasors, as there is nothing more disturbing to
the space-time continuum than naked Romulans.
If there was no wake turbulence then he wasn't using impulse power. Clearly
you are mistaken.
Yes they are - under "weight-shift-control," also known as "warp drive."
Just because the warp drive is not in use at that time, they are still
classified as warp drive wessels (as Chekov would call them.) Sheesh, what
are they teaching in ground school these days?
Warbird?
Dropping hail onto it would be in violation of 91.15 "Dropping Objects".
The approved method is use of phasors. See 91.99 of the FARs.
Old April 12th 08, 07:36 PM posted to rec.aviation.piloting
Ron Wanttaja wrote in
Warbird decloaked and was dead ahead of me.
Oh dear!
Bertie
Old April 12th 08, 08:20 PM posted to rec.aviation.piloting
WingFlaps
On Apr 13, 4:19*am, SD wrote:
Hello-
I have a quick question/concern regarding FAR 91.113d. *I pretty much
grasp the concept well. *Basically apply the acronym BGAAR (baloons,
gliders, airships, airplanes and helo's). *For example, If I am flying
to the right and give it the ROW. *Likewise for any of the other items
91.113d, what do I do? *Yesterday I was flying and a Rombulan Warbird
decloaked and was dead ahead of me. *I tried to hail him but I had no
luck. *Since he was traveling at impulse power I was able to maneuver
around him. *There was no wake turbulence or anything of that sort.
them the right away. *Its easy on planet earth since we are in
to travel at impulse power. *I am concerned about the Rombulan Warbird
however.
Warbird?
Use only drugs as approved by the director.
Cheers
Old April 12th 08, 08:21 PM posted to rec.aviation.piloting
Larry Dighera
Generally, yes; that's how I interpret the regulation, but the
necessity to alter course to the _right_ is only mentioned in (e):
http://ecfr.gpoaccess.gov/cgi/t/text... .1.3.10.2.4.7
(e) Approaching head-on. When aircraft are approaching each other
head-on, or nearly so, each pilot of each aircraft shall alter
course to the right.
However there are other pertinent situations:
(f) Overtaking. Each aircraft that is being overtaken has the
right-of-way and each pilot of an overtaking aircraft shall alter
course to the right to pass well clear.
So if you're flying your motor-glider (wich is classed as a glider,
not an engine driven aircraft if I understand correctly) and
overtaking an airplane, you don't have right-of-way, FAR 91.113(d)
notwithstanding, unless your flight is in distress.
Then there are the issues of landing, towing, and refueling
aircraft....
Old April 12th 08, 08:34 PM posted to rec.aviation.piloting
WingFlaps
Hello-
however.
Warbird?
You think "Damn Romulans, what shall I do" and a big ballon appears
above your head with those words in it. The Romulan sees the huge
ballon and gives way (as all good cartoon pilots must obey Federation
aviation rules when manuvering in .sector 0 planet atmoshphere).
Cheers
MA-8 Static test firing of MA-8 Atlas 113D S62-06634.jpg [email protected] Aviation Photos 0 April 10th 07 02:51 PM
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
B-2 question Harley W Daugherty Military Aviation 37 August 27th 04 12:45 AM
