Comparison of Air band Receivers
Old April 13th 08, 04:57 AM posted to rec.aviation.piloting,rec.aviation.student
Andrew Sarangan
Default Comparison of Air band Receivers
Following the previous discussion of scanners, I did a comparison of
three different scanners (Uniden, Radioshack and ICOM) by recording
clips from each unit using the same outdoor antenna.
I was surprised by how much the ICOM-A6 outperformed the other models,
but the picture (audio in this case) is worth a thousand words. It
could be of use to anyone considering purchasing these for aviation
use.
You can find the recordings here.
http://www.sarangan.org/aviation/sca...anner/compare/
Old April 13th 08, 05:57 AM posted to rec.aviation.piloting
Larry Dighera
On Sat, 12 Apr 2008 20:57:27 -0700 (PDT), Andrew Sarangan
I would guess the price of the Icom was significantly in excess of the
other two...
See if a dealer will let you record the Vertex VXA-220 Pro VI:
http://www.vertexstandard.com/indexV...2&isArchived=0
It has 8.33 kHz synthesizer steps for the new narrow-band channel
plan. Do the others?
Old April 13th 08, 11:54 AM posted to rec.aviation.piloting
Bob Noel
http://www.vertexstandard.com/indexV...odCatID=204&en
cProdID=DA07CE6217CCD6F284F47B698B8EB483&DivisionI D=2&isArchived=0
8.33 is only applicable in Europe.
Bob Noel
(goodness, please trim replies!!!)
Old April 13th 08, 07:28 PM posted to rec.aviation.piloting
Andrew Sarangan
other two...
Yes it is more expensive. But prior discussions on this newsgroup lead
me to believe that transceivers are more expensive mainly because they
have transmit capability, but for listening just about any scanner
would do. My goal was to find out if that was really true.
See if a dealer will let you record the Vertex VXA-220 Pro VI:http://www.vertexstandard.com/indexV...oducts&ProdCat...
Old April 14th 08, 12:58 AM posted to rec.aviation.piloting
Larry Dighera
On Sun, 13 Apr 2008 06:54:37 -0400, Bob Noel
So it appears, but who knows what the future will bring:
http://research.faa.gov/downloads/re...s_04292003.pdf
The Europeans are channel splitting to 8.33 kHz and using VDL Mode
3 for voice communications. This is different from the U.S.
approach and the FAA should work with the Europeans to identify a
common solution.
http://mae.pennnet.com/articles/arti...A%20radio&p=32
FAA and airlines at odds over next-generation aviation
communications
WASHINGTON — Leaders of the U.S. Federal Aviation Administration
(FAA) are delaying indefinitely their nationwide rollout of the
new Controller-Pilot Data Link Communications (CPDLC) system,
which has been undergoing tests at Miami International Airport
since October 2002.
FAA officials say they are delaying the program for two reasons:
the airlines are unable to make the necessary investment in the
cockpit, and the FAA's new prime objective of increased security.
Avionics companies are responding by trying to cover all possible
bases with multimode radios capable of talking to VDL2, 8.33 kHz,
and VDL3. But they and the airlines have voiced concerns about
that approach, as well.
"We, the manufacturers, can put multimode inside a single box, but
is it cost-effective to add additional technology to the same box
when we haven't resolved all the interoperability issues?" asks
Richard Heinrich, director of strategic initiatives at radio
designer Rockwell Collins in Cedar Rapids, Iowa. "Our goal is to
serve the community by offering them one product with multiple
functionality; the community needs to decide what that
functionality needs to be."
http://airlineprocurement.com/magazi...D=1183&print=Y
Doubts about the grand plan increased as 2000 came and went
without a completed Nexcom, and European 8.33-kHz radios became
more and more prevalent in international aircraft. Airlines began
to question whether there was truly a need to buy yet another new
radio for the now-projected 2009 rollout of Nexcom (few converted
radios support Nexcom, nor necessarily do new 8.33-kHz radios).
"Europe had backed itself into a corner," says Melvin Reese,
director-communication and surveillance for Eurocontrol. "We had
converted so many 25-kHz radios to 8.33 kHz that there was no way
to back out to a 25-kHz system like Nexcom." Europe required the
8.33-kHz radios for flights above 24,500 ft. starting in 1999 and
will continue the rollout next January[2006] with 8.33 kHz spacing
for flights above 19,500 ft. Reese says about half of the US
airline fleet already is equipped with radios that can handle both
the 25-kHz and 8.33-kHz spacing.
Old April 14th 08, 03:46 AM posted to rec.aviation.piloting
Bob Noel
8.33 was needed in Europe NOW. They couldn't wait for
the higher capacity that would (eventually) be available from
VDL whatever mode.
Long term, 8.33 doesn't provide the capacity that we'll eventually
need in the NAS.
Bob Noel
Old April 14th 08, 02:51 PM posted to rec.aviation.piloting
Larry Dighera
On Sun, 13 Apr 2008 22:46:13 -0400, Bob Noel
VDL whatever mode.
need in the NAS.
What does? At least 8.33-kHz triples the current number of available
channels, but it would seem that the FAA agrees with you. However
Eurocontrol required the 8.33-kHz radios for flights above 24,500 ft.
starting in 1999 and lowered that to flights above 19,500 ft. in 2006,
so if one extrapolates, it would seem that 8.33-kHz radios will be
mandatory at even lower altitudes there before long.
With the majority of the US airliner fleet equipped with 8.33-kHz
radios, and the FAA's indefinitely delaying their nationwide mandate
of the new Controller-Pilot Data Link Communications (CPDLC) system, I
believe there's a significant probability that 8.33-kHz radios could
see use in the NAS if congestion continues to increase.
Old April 14th 08, 03:27 PM posted to rec.aviation.piloting,rec.aviation.student
Marco Leon[_5_]
"Andrew Sarangan" wrote in message
use.
Wow Andrew, what a difference. Of course the two you chose to compare to the
ICOM A6 were the two that I happen to have... grrrr.
Thanks (I think) for doing the comparison.
Marco
Old April 15th 08, 12:55 AM posted to rec.aviation.piloting
Bob Noel
need in the NAS.
channels,
It doesn't quite triple the current number. They still have to be careful
of adjacent channels.
Yep - eventually they'll run out of 8.33 channels that aren't splashed
by the 25 kHz radios. Then they will have to get rid of all the 25 kHz
radios.
radios
eh? The only US aircraft needing 8.33 radios are those that have
to go to Europe. Most of the US fleet doesn't go anywhere near
Europe.
There are waaaaay more radios that would have to be replaced here
in the NAS than in Europe. And we don't have the short distances
between national borders that adversely impacts the radio freq
allocation challenge found in Europe.
Bob Noel
Old April 15th 08, 01:10 AM posted to rec.aviation.piloting
Larry Dighera
On Mon, 14 Apr 2008 19:55:09 -0400, Bob Noel
wrote in
radios
Europe.
Reese says about half of the US airline fleet already is equipped
with radios that can handle both the 25-kHz and 8.33-kHz spacing.
How to use the AR-108 Air Band Scanner Channels Chris L Piloting 3 January 1st 08 11:45 PM
Can old LORAN receivers use single loop antennas Rick Marvin Home Built 0 September 10th 05 06:10 AM
Who has fitted a TRI-band ELT to a TB20? Chris G. Instrument Flight Rules 0 June 28th 05 03:21 PM
Band of brothers ArtKramr Military Aviation 10 March 9th 04 10:44 PM
Home air band listening. Rich Hare Instrument Flight Rules 3 July 15th 03 03:15 AM
