The plywood monocoque car guy
Old April 21st 08, 03:59 AM posted to rec.aviation.homebuilt
Default The plywood monocoque car guy
On Apr 19, 8:05 pm, wrote:
Trying to bend it with the grain (grain parallel to the bend
line) will usually fracture the core plies, since it's pretty hard to
get moisture that deep.
Try adding two ounces of household ammonia and ONE DROP of liquid
detergent (or a drop of Kodak 'Photo Flow') to each GALLON of water.
Soak over-night then heat the soaked wood to 165 to 185F degrees.
Bend to the desired shape and allow to dry. For extremely deep
curves, do the bend in graduated stages, keeping the plywood moist
until the desired shape has been achieved.
Thinner is better; make the part as two shells if needed to achieve
the desired thickness.
This procedure does not work with all plywoods.
-R.S.Hoover
Old April 21st 08, 09:45 PM posted to rec.aviation.homebuilt
On Apr 18, 1:15 pm, Bart wrote:
First, I'm guessing that marine plywood was used in the construction
of the Marcos line of cars because it was the best laminate wood
material available at the time (early '60s). The car I'm building will
be very much like the Marcos, in that it will be a multiple "stressed
box" semi-monocoque structure bonded at the sills and front and rear
bulkheads to the open-cockpit fiberglass body I'm using.
http://blog.modernmechanix.com/2006/...ny-sports-car/
Mechanix Illustrated, September 1956
Nothing of any technical value, I think, but it's the same sort of
project.
Mike
okoume plywood SpadXIII Home Built 2 December 4th 07 08:08 PM
Why no plywood monocoque homebuilts? [email protected] Home Built 36 October 31st 06 12:27 PM
Scarf Joints in Plywood Kyle Boatright Home Built 11 September 11th 06 11:49 PM
compound curves in plywood BA-100 Home Built 58 April 13th 05 05:29 AM
Plywood Kathi Jo Home Built 3 January 12th 04 10:48 PM
