flight Instruments on the Cheap
Old April 21st 08, 11:59 PM posted to rec.aviation.homebuilt
Dick[_1_]
Default flight Instruments on the Cheap
Anyone know about a seminar at SNF
discussing flight instruments made cheaply??
A while ago, I remember someone describing an attitude gage consisting of a
tube loop (the loop was orientated fore and aft) filled with a liquid.
Wonder if some arrangement utilizing a manometer (sp? "u" shaped open ended
tube is meant) might due for airspeed??
A buddy just found A.S.S. raised an airspeed unit $70 over the 2007/2008
catalog price...
Thanks, Dick
Old April 22nd 08, 02:00 AM posted to rec.aviation.homebuilt
Paul Tomblin
That wouldn't work. It would point straight down during an coordinated
turn.
Paul Tomblin http://blog.xcski.com/
We'll burn that bridge when we come to it.
Old April 22nd 08, 01:34 PM posted to rec.aviation.homebuilt
Dick[_1_]
If my refreshed G memory serves, it was a four sided glass tube "loop"
with vertical instrument panel mounted portion indicating pitch via fluid
level while firewall vertical portion was much shorter and remaining
portions were therefore not parallel. Apparently it was used on early mail
planes after WW1 for flight in IFR conditions. Believe thinking at the time
,how simple to replace "glass" with plastic tubing..
Thanks for the comment but in any case, it is the airspeed alternative I'm
seeking.
"Paul Tomblin" wrote in message
a
turn.
Old April 22nd 08, 09:38 PM posted to rec.aviation.homebuilt
steveukman
There is the Hall ASI that uses forward air pressure to lift a marker
in a tube.
If my memory serves me well it is is at hallwindmeter dot com.
I was thinking of using one as a backup gauge on a slow biplane. I am
not sure what your ASI range requirements are but this may be a good
place to look.
Best Regards
Steve
catalog price...
Thanks, Dick
Old April 23rd 08, 01:17 AM posted to rec.aviation.homebuilt
Dick[_1_]
Thanks. Interesting and I've asked manufacturer if a higher mph range might
be made available.
I wonder what the downside of such an instrument is??
"steveukman" wrote in message
in a tube.
place to look.
Best Regards
Steve
a
ended
catalog price...
Thanks, Dick
Old April 23rd 08, 02:23 AM posted to rec.aviation.homebuilt
Maxwell[_2_]
"Dick" wrote in message
news:fevPj.5393$Ux4.1316@trnddc07...
might be made available.
The up side (besides cost) is extremely good resolution at slow air speeds.
Especially 0 to 30, where conventional ASIs are usually less reliable, if
even calibrated in that range. I bought one from AS&S years ago calibrated
for a helo that wasn't bad, but not nearly as repeatable as a Hall in the
low speed range.
The only down side I recall is their reliance on gravity to oppose their
reading. They bump around a little bit on bumpy days, and of coarse are
useless when inverted. I don't recall much change on positive G's. They
seemed accurate in 2 or three G turns because the indicating disk is very
light weight. Just the zero and half G's loads were a problem.
Old April 23rd 08, 11:26 AM posted to rec.aviation.homebuilt
GeorgeB
It might be realistic to look at Dwyer Instruments; there are many
offerings. In particular, the $50 unit
http://www.dwyer-inst.com/htdocs/air...riesMWSpec.CFM is 0-55
kt, resolution of 0.2 kt. Accuracy is about 5% of reading. There are
mini-pitot based models, rising vane (as used on some ultralight type
craft I've seen) and these rotating units.
On Tue, 22 Apr 2008 20:23:30 -0500, "Maxwell" luv2^fly99@cox.^net
low speed range.
Old April 23rd 08, 01:35 PM posted to rec.aviation.homebuilt
steveukman
That was the reason that I delayed ... but I realised that for my
purposes (backup for an EFIS) I would only be flying VFR and the only
time I *really* needed a backup ASI would be at landing time, when my
speed would be low enough.
be made available.
Old April 23rd 08, 03:29 PM posted to rec.aviation.homebuilt
Does anyone know where I might obtain flight instruments that don't
work? I need them for a cockpit demonstrator -- everything has to
look right, but it's not going to do anything. Thanks.
primary flight instruments on partial panel Greg Instrument Flight Rules 22 September 1st 06 04:18 AM
Flying on the Cheap - Instruments [email protected] Home Built 24 February 27th 06 02:30 PM
Flight Logging - Cheap Marry Daniel or David Grah Soaring 10 March 10th 04 01:22 AM
Flight sims way to cheap to pass up for sale on Ebay. Curtis Simulators 0 November 20th 03 04:41 PM
Flight Instruments Book? Greg Esres Piloting 1 July 16th 03 08:31 PM
