Should I be scared -- C172 over Gross
Old April 23rd 08, 08:18 PM posted to rec.aviation.piloting,alt.usenet.kooks
Maxwell[_2_]
Default Should I be scared -- C172 over Gross
"Maxwell" luv2^fly99@cox.^net wrote in
"Mxsmanic" wrote in message
writes:
Funny that where ever you post there seems to be a "treehouse club"
that thinks you are a twit.
I consider it more sad than funny. There are a lot of mean people in
the world, and for some reason cyberspace encourages them to show
their true colors.
It's always someone else's fault, isn't it?
1
Bertie
2
  #252
Old April 23rd 08, 08:50 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
WingFlaps wrote in
On Apr 23, 5:39*pm, Mxsmanic wrote:
writes:
Sure it is in a simulatated world.
Or if you hit the ground just beyond the runway in the real world
because
you
took off overweight.
I've flown a 172 more loaded that!
Cheers
I've flown one on a ferry that was probably about 300 or 400 lbs
overweight, but off very long runways and in a quite cold region. No
problem, but I wouldn't do it as routine and I wouldn't do it if
performance was an issue. A couple of pounds overweight is one thing,
but it doesn't take much to reach a point where the airplane won't go up
at all, particularly if it's a relatively low powered aircraft like a
172 in the first place. The degradation is not linear, so if there's a
100 FPM loss with a 100lb overload, it does not mean that there will be
a 200 lb loss with a 200 lb overload. Obvious, I know, but it's
something often forgotten when wishful thinking takes the place of a
rational approach to the problem.
Bertie
Bertie
  #254
Old April 23rd 08, 08:55 PM posted to rec.aviation.piloting
Mxsmanic wrote in
writes:
Yeah, right.
As usual.
Yeah, right.
Bertie
  #255
Old April 23rd 08, 08:56 PM posted to rec.aviation.piloting
Mxsmanic wrote in
gatt writes:
If actual pilots here need advice they'll get it from pilots.
Since a lot of actual pilots ignore any advice that doesn't agree with
their own beliefs, it doesn't really matter where it comes from.
Nope, wrong again, fjukkwit.
Bertie
  #256
Old April 23rd 08, 09:54 PM posted to rec.aviation.piloting
george
On Apr 23, 5:01 pm, Mxsmanic wrote:
george writes:
Uh. 30 pound over is burned off in about 30 minutes.
Unfortunately, take-off is over in 30 seconds.
With a modern runway in front of me around 700m long and no
obstructions above 200 feet for a km or so I will be safely off the
ground and established in the climb at 30 seconds.
30 minutes I will be clear of the circuit at my (C172) cruising
altitude and on track for my destination.
  #257
Old April 23rd 08, 10:00 PM posted to rec.aviation.piloting
george
On Apr 23, 5:39 pm, Mxsmanic wrote:
writes:
Or if you hit the ground just beyond the runway in the real world because you
You are demonstrating as to why you are the group clown.
If an aircraft impacts the ground after takeoff it will be engine
failure or loss of control (spin off departing turn) nothing to do
with load..
Mate of mine is an ag pilot.At 72+
  #260
Old April 23rd 08, 10:31 PM posted to rec.aviation.piloting
terry
On Apr 22, 10:16*am, tman inv@lid wrote:
tman wrote:
, and also the day turned out to be +20F hotter than I thought
it would. *I've experienced that heat not only hurts the planes
performance, but the pilots too. *Oh yeah, a slightly gusty xwind too.
Pretty happy I planned on leaving one pax behind.
If you look very closely at the take off performance data of a 172
( which I have) you will find that higher temperature actually
improves performance, for the same air density. Now I know that
contradicts what we get taught in flight school, and while it is
generally true that when temperature is lower the air will be more
dense , the atmosphere is a dyanmic system and pressure and
temperature can vary independantly. So it is possible to have the
same air density , or density altitude at 2 different temperature and
the day with the higher temperature wil give you better performance.
It is related to engine performance and the best explanation I have
got is that at the same density on a higher temperature day, the
pressure will also be higher ( since density = PM/RT where M is
molecular wt, R is gas constant, P and T press and temp), and the
higher pressure provides a greater driving force to suck air into the
engine. If you do the same analysis on the landing distance you see
no such temperature effect because landing distance is not power
related , only lift related.
In the next few days I will get around to providing a link to this
data, but you can easily prove it yourself if you have the Cessna
takeoff distance tables..
Terry
PPL Downunder
My wife getting scared Paul Tomblin Piloting 271 October 11th 07 08:19 PM
Scared of mid-airs Frode Berg Piloting 355 August 20th 06 05:27 PM
UBL wants a truce - he's scared of the CIA UAV John Doe Aviation Marketplace 1 January 19th 06 08:58 PM
Max gross weight Chris Piloting 21 October 5th 04 08:22 PM
Scared and trigger-happy John Galt Military Aviation 5 January 31st 04 12:11 AM
