#261
#262
gregvk wrote in news:Xns9A89A923F1A08E817AC3D8380227
@127.0.0.1: Bertie the Bunyip wrote in news:fuo8tf$6rt$1 @blackhelicopter.databasix.com: "Maxwell" luv2^fly99@cox.^net wrote in : "gregvk" wrote in message ... Bertie the Bunyip wrote in news:fuo1ls$iga$1 @blackhelicopter.databasix.com: "Maxwell" luv2^fly99@cox.^net wrote in : "Mxsmanic" wrote in message ... writes: Funny that where ever you post there seems to be a "treehouse club" that thinks you are a twit. I consider it more sad than funny. There are a lot of mean people in the world, and for some reason cyberspace encourages them to show their true colors. It's always someone else's fault, isn't it? 1 Bertie "Results 1 - 10 of about 1,280 for group:rec.aviation.piloting author:Maxwell" Erm, better start the counter at 1,281. Ahh, give it a rest Bertie. Your sockpuppet routine isn't fooling anyone, just showing how lame you really are. Besides, your statistics are waaaay off. Uh, yeh, sure k00kie boi. I thought you were running away? Forget something? Bertie /rolls eyes Am I your sock or are you my sock? Just wondering. I'm not fussy. In Maxie's mind anything is possible, so maybe we're like that Escher drawing of the two hands drawing each other.. And I like how Maxie-poo thinks his post count is more accurate than Google's post count. It's... cute. He's adorable. Bertie |
#263
On Apr 24, 9:31 am, terry wrote:
On Apr 22, 10:16 am, tman inv@lid wrote: tman wrote: , and also the day turned out to be +20F hotter than I thought it would. I've experienced that heat not only hurts the planes performance, but the pilots too. Oh yeah, a slightly gusty xwind too. Pretty happy I planned on leaving one pax behind. If you look very closely at the take off performance data of a 172 ( which I have) you will find that higher temperature actually improves performance, for the same air density. Now I know that contradicts what we get taught in flight school, and while it is generally true that when temperature is lower the air will be more dense , the atmosphere is a dyanmic system and pressure and temperature can vary independantly. So it is possible to have the same air density , or density altitude at 2 different temperature and the day with the higher temperature wil give you better performance. It is related to engine performance and the best explanation I have got is that at the same density on a higher temperature day, the pressure will also be higher ( since density = PM/RT where M is molecular wt, R is gas constant, P and T press and temp), and the higher pressure provides a greater driving force to suck air into the engine. If you do the same analysis on the landing distance you see no such temperature effect because landing distance is not power related , only lift related. In the next few days I will get around to providing a link to this data, but you can easily prove it yourself if you have the Cessna takeoff distance tables.. Terry PPL Downunder You can play with your C172 N weight and balance here http://home.new.rr.com/trumpetb/alph/wb172N.html |
#264
Mxsmanic wrote:
Dudley Henriques writes: You are to be Congratulated! With this absolutely astounding statement of astronomically historic and infallible intellect, you have succeeded in completely negating the entire concept of learning. You're confusing acquired knowledge with intelligence. Intelligence is relatively static throughout life, but acquired knowledge tends to steadily increase. Learning is the process of acquiring knowledge; it has no effect on intelligence. However, aptitude--the capacity to learn--is largely a function of intelligence. Smart people learn faster and more easily, all else being equal. This is why smart people tend to know more than stupid people. You are truly amazing :-) -- Dudley Henriques |
#265
WingFlaps writes:
Well, you'd have a hard time understaning how a 172 can fly to Haiwaii then. Try simulating a 172 300# over MTOW? I don't exceed weight limits. |
#266
george writes:
You are demonstrating as to why you are the group clown. If an aircraft impacts the ground after takeoff it will be engine failure or loss of control (spin off departing turn) nothing to do with load.. I've already pointed this out: http://www.alexisparkinn.com/photoga...loaded-172.wmv Doesn't look like an engine failure or spin to me. The aircraft was overweight, though. |
#267
Dudley Henriques wrote in
: Mxsmanic wrote: Dudley Henriques writes: You are to be Congratulated! With this absolutely astounding statement of astronomically historic and infallible intellect, you have succeeded in completely negating the entire concept of learning. You're confusing acquired knowledge with intelligence. Intelligence is relatively static throughout life, but acquired knowledge tends to steadily increase. Learning is the process of acquiring knowledge; it has no effect on intelligence. However, aptitude--the capacity to learn--is largely a function of intelligence. Smart people learn faster and more easily, all else being equal. This is why smart people tend to know more than stupid people. You are truly amazing :-) He is, isn't he? He's like one of those battery powered Japanese robots from the early sixties. you know, the kind that runs around the floor moaking a lot of noise and get stuck every time he hits the edge of the carpet. Bertie |
#268
You are truly amazing :-) Thank you. Maybe I should write an article in Wikipedia promotiong myself. |
#269
#270
Mxsmanic wrote in
: Dudley Henriques writes: You are truly amazing :-) Thank you. Maybe I should write an article in Wikipedia promotiong myself. Oh! Let me! bertie |
My wife getting scared | Paul Tomblin | Piloting | 271 | October 11th 07 08:19 PM |
Scared of mid-airs | Frode Berg | Piloting | 355 | August 20th 06 05:27 PM |
UBL wants a truce - he's scared of the CIA UAV | John Doe | Aviation Marketplace | 1 | January 19th 06 08:58 PM |
Max gross weight | Chris | Piloting | 21 | October 5th 04 08:22 PM |
Scared and trigger-happy | John Galt | Military Aviation | 5 | January 31st 04 12:11 AM |
