Should I be scared -- C172 over Gross
Old April 23rd 08, 11:10 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Default Should I be scared -- C172 over Gross
terry wrote in news:303fdf2b-7e83-4b08-aaf8-
On Apr 22, 10:16*am, tman inv@lid wrote:
tman wrote:
, and also the day turned out to be +20F hotter than I thought
it would. *I've experienced that heat not only hurts the planes
performance, but the pilots too. *Oh yeah, a slightly gusty xwind
too.
Pretty happy I planned on leaving one pax behind.
If you look very closely at the take off performance data of a 172
( which I have) you will find that higher temperature actually
improves performance, for the same air density. Now I know that
contradicts what we get taught in flight school, and while it is
generally true that when temperature is lower the air will be more
dense , the atmosphere is a dyanmic system and pressure and
temperature can vary independantly. So it is possible to have the
same air density , or density altitude at 2 different temperature and
the day with the higher temperature wil give you better performance.
It is related to engine performance and the best explanation I have
got is that at the same density on a higher temperature day, the
pressure will also be higher ( since density = PM/RT where M is
molecular wt, R is gas constant, P and T press and temp), and the
higher pressure provides a greater driving force to suck air into the
engine. If you do the same analysis on the landing distance you see
no such temperature effect because landing distance is not power
related , only lift related.
In the next few days I will get around to providing a link to this
data, but you can easily prove it yourself if you have the Cessna
takeoff distance tables..
Terry
Yeah, you'll get about 1% per 5 deg C on a typical normally aspirated
lightplane engine under those circumstances.
Bertie
  #262
Old April 24th 08, 12:28 AM posted to rec.aviation.piloting,alt.usenet.kooks,alt.alien.vampire.flonk.flonk.flonk
Bertie the Bunyip[_25_]
gregvk wrote in news:Xns9A89A923F1A08E817AC3D8380227
@127.0.0.1:
Bertie the Bunyip wrote in news:fuo8tf$6rt$1
@blackhelicopter.databasix.com:
"Maxwell" luv2^fly99@cox.^net wrote in
"gregvk" wrote in message
Bertie the Bunyip wrote in news:fuo1ls$iga$1
"Mxsmanic" wrote in message
writes:
Funny that where ever you post there seems to be a "treehouse
club" that thinks you are a twit.
I consider it more sad than funny. There are a lot of mean
people
in the world, and for some reason cyberspace encourages them to
show their true colors.
It's always someone else's fault, isn't it?
1
Bertie
"Results 1 - 10 of about 1,280 for group:rec.aviation.piloting
author:Maxwell"
Erm, better start the counter at 1,281.
Ahh, give it a rest Bertie. Your sockpuppet routine isn't fooling
anyone, just showing how lame you really are.
Besides, your statistics are waaaay off.
Uh, yeh, sure k00kie boi.
I thought you were running away? Forget something?
Bertie
/rolls eyes
Am I your sock or are you my sock? Just wondering.
I'm not fussy. In Maxie's mind anything is possible, so maybe we're like
that Escher drawing of the two hands drawing each other..
And I like how Maxie-poo thinks his post count is more accurate than
Google's post count. It's... cute.
He's adorable.
Bertie
  #263
Old April 24th 08, 12:57 AM posted to rec.aviation.piloting
george
On Apr 24, 9:31 am, terry wrote:
On Apr 22, 10:16 am, tman inv@lid wrote: tman wrote:
, and also the day turned out to be +20F hotter than I thought it would. I've experienced that heat not only hurts the planes
performance, but the pilots too. Oh yeah, a slightly gusty xwind too.
Terry
PPL Downunder
You can play with your C172 N weight and balance here
http://home.new.rr.com/trumpetb/alph/wb172N.html
  #264
Old April 24th 08, 01:07 AM posted to rec.aviation.piloting
Dudley Henriques[_2_]
Mxsmanic wrote:
Dudley Henriques writes:
You are to be Congratulated!
With this absolutely astounding statement of astronomically historic and
infallible intellect, you have succeeded in completely negating the
entire concept of learning.
You're confusing acquired knowledge with intelligence. Intelligence is
relatively static throughout life, but acquired knowledge tends to steadily
increase.
Learning is the process of acquiring knowledge; it has no effect on
intelligence. However, aptitude--the capacity to learn--is largely a function
of intelligence. Smart people learn faster and more easily, all else being
equal. This is why smart people tend to know more than stupid people.
You are truly amazing :-)
Dudley Henriques
  #265
Old April 24th 08, 01:22 AM posted to rec.aviation.piloting
Mxsmanic
WingFlaps writes:
Well, you'd have a hard time understaning how a 172 can fly to Haiwaii
then. Try simulating a 172 300# over MTOW?
I don't exceed weight limits.
  #266
Old April 24th 08, 01:24 AM posted to rec.aviation.piloting
Mxsmanic
george writes:
You are demonstrating as to why you are the group clown.
If an aircraft impacts the ground after takeoff it will be engine
failure or loss of control (spin off departing turn) nothing to do
with load..
I've already pointed this out:
http://www.alexisparkinn.com/photoga...loaded-172.wmv
Doesn't look like an engine failure or spin to me. The aircraft was
overweight, though.
  #267
Dudley Henriques wrote in
and infallible intellect, you have succeeded in completely negating
the entire concept of learning.
is relatively static throughout life, but acquired knowledge tends to
steadily increase.
function of intelligence. Smart people learn faster and more easily,
all else being equal. This is why smart people tend to know more
than stupid people.
He is, isn't he? He's like one of those battery powered Japanese robots
from the early sixties. you know, the kind that runs around the floor
moaking a lot of noise and get stuck every time he hits the edge of the
carpet.
Bertie
  #268
Old April 24th 08, 01:25 AM posted to rec.aviation.piloting
Mxsmanic
Thank you. Maybe I should write an article in Wikipedia promotiong myself.
  #270
Old April 24th 08, 01:33 AM posted to rec.aviation.piloting
Mxsmanic wrote in
myself.
Oh! Let me!
bertie
My wife getting scared Paul Tomblin Piloting 271 October 11th 07 08:19 PM
Scared of mid-airs Frode Berg Piloting 355 August 20th 06 05:27 PM
UBL wants a truce - he's scared of the CIA UAV John Doe Aviation Marketplace 1 January 19th 06 08:58 PM
Max gross weight Chris Piloting 21 October 5th 04 08:22 PM
Scared and trigger-happy John Galt Military Aviation 5 January 31st 04 12:11 AM
