Lancair crash at SnF
Old April 24th 08, 03:54 PM posted to rec.aviation.piloting
B A R R Y[_2_]
Default Lancair crash at SnF
Jay Maynard wrote:
I did this on the first attempt in a Warrior with my CFI from 400 AGL.
You're good!
Did you know it was coming? A big part of this is the fast transition
from climb attitude to power-off glide.
Old April 24th 08, 04:05 PM posted to rec.aviation.piloting
Stefan
Brian schrieb:
Your right in that many aircraft it is possible. But the problem is it
isn't possible for many pilots when the engine quits. It is not a
maneuver that is routinly practiced.
Now this problem could be solved.
Jay Maynard
On 2008-04-24, B A R R Y wrote:
You're good!
No, my CFI was.
This is why I succeeded: because I knew it was coming. It was intended as a
demonstration, not as a test of my abilities. He talked me through it.
Afterward, I set my personal decision height at 600 AGL. Below that, in that
aircraft and under those conditions, I don't attempt it. Above that, it's
possible. That's why I plan to do the same with the Zodiac: so I know where
the line is, and have the decision already made before I take off. Too many
lives are lost to indecision; I do not intend mine to be one of them.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 2 June)
Old April 24th 08, 04:07 PM posted to rec.aviation.piloting
Big John
On Wed, 23 Apr 2008 22:26:44 -0700, Ron Wanttaja
On Wed, 23 Apr 2008 23:53:32 -0500, Big John wrote:
AW&ST today had a small article that a Lancair piloted by Gerand
Schkolnk crashed moments after takeoff during the Sun and Fun AirShow.
He was director of Supersonic Technology Programs at Gulfstream.
Anyone have any data on accident other than what AW&ST had?
http://www.avweb.com/avwebflash/news..._197685-1.html
Tnx for info Ron.
To comment about the 180 if engine out after take off.
You cannot make a level turn, engine out, back to field. No way and
better believe it.
If you do not have enough altitude to make a diving 180 degree turn
back to field, don't try it.
If you are not comfortable to make a diving turn close to ground don't
try it.
If you believe in probabilities, then limit yourself to a max of 45
degree turn either right or left to miss any immovable object.
NO MATTER WHAT HAPPENS AND WHAT YOU DO,FLY THE AIRCRAFT AND DO NOT
STALL IT.
Fly safe and survive.
Big John
Old April 24th 08, 04:12 PM posted to rec.aviation.piloting
Dylan Smith
On 2008-04-24, Brian wrote:
Depends on what you mean by "the impossible turn". If you mean turning back
at 200 AGL, yeah, that one's pretty much impossible. If you mean 600 AGL,
it's pretty much possible in the average aircraft. (Hell, that's pattern
altitude at EFD!) The line lies somewhere in between.
It is statements like this that get pilots killed.
It's statements like 'never turn, always land straight ahead' that also
gets pilots killed. There are plenty of airfields where going straight
ahead is quite possibly the worst option, and the best survivability
options are at least a 120 degree turn away from whatever point you're
at when at 600' AGL.
The only thing you can do is use the best judgement at the time. You get
one chance - it may be wrong. Sometimes, trying to turn back might be
wrong. Sometimes doing anything *other* than trying to turn back might
be wrong.
In gliders, every glider pilot is taught "the impossible turnback" from
200 feet (which, in the typical low performance training glider, is
about equal to turning back at 600 feet in a C172). We actually train
for it for real - there's no other way to do it - the instructor will
eventually pull the bung on you at around 200ft. It's an essential skill
because power failures (rope or cable breaks) are a lot more frequent
than engines quitting on a single. Doing it off a simulated winch launch
failure is quite exciting - we tend to do that at about 400 ft though
because it's an extremely critical manoevre, since you're pitched up at
50 degrees or so and any delay equals a low altitude stall. The ground
looks really, really close when you pitch down steeply to quickly regain
your airspeed and can see nothing but green in front of you. The really
important bit about this training though is you're not taught it as an
absolute. The mantra is to first do what it takes to maintain airspeed,
then quickly decide on a course of action. The course of action could be
any of several possibilities - can you get down on the remaining runway?
Can you turn back? Is what's in front of you landable? Land to the side?
Which way is the wind going? (If there's a crosswind aloft, this affects
the decision on which way you're going to turn: you should have already
decided turn direction in the 'eventualities' part of the checklist
before the slack is even taken up on the cable or tow rope).
The answer is as always training, and having a plan. Think of the
eventualities just as you line up - if you lose power at point X, what
should you do. At point Y, what should you do? What about point Z?
From the sunny Isle of Man.
Yes, the Reply-To email address is valid.
Old April 24th 08, 04:40 PM posted to rec.aviation.piloting
B A R R Y[_2_]
possible.
I think personal decision height also depends on several other factors.
- Departing from a 5500 (or longer) ft. runway vs. a 2500-3000. You'll
be closer to the threshold as you glide back to a longer runway, because
you were sill over it as you climbed.
- What's at the end of the runway? A flat and open approach area beats
big trees, power lines, factories, a river dike... Coming up short at
one of my local fields puts you in a sewage pond, _if_ you clear the
river dike, at another, a steel mill with large overhead cranes.
In all probability, I'm going straight ahead, but there are individual
circumstances that could sway that. The factors that might have me
attempt the turn would have to be clear, obvious, and pre-planned.
Old April 24th 08, 06:19 PM posted to rec.aviation.piloting
Larry Dighera
On Thu, 24 Apr 2008 12:46:29 GMT, Jay Maynard
wrote in
On 2008-04-24, WingFlaps wrote:
When will pilots learn to stop trying to do the impossible turn... and
go for a straight ahead landing on soemthing horizontal?
This subject has been discussed in detail with the assistance of
erudite professor Lowry's input:
http://groups.google.com/group/rec.a...1d80a2e846a88b
John T. Lowry
Best turnaround bank angle phi (least altitude loss per angle turned
through) for a gliding airplane is given by: cos(phi) =
(sqrt(2)/2)*sqrt(1-k^2) where k = CD0/CLmax + CLmax/(pi*e*A) where CD0
is the parasite drag coefficient, CLmax is the maximum lift
coefficient for the airplane's flaps configuration, e is the airplane
efficiency factor, and A is the wing aspect ratio. I know most ng
readers hate those darned formulas, but that's the way the world
works. For GA propeller-driven airplanes, k is a small number (0.116
for a Cessna 172, flaps up) and so the best turnaround bank angle is
very closely the 45 degrees cited by Rogers and, much earlier, by
Langewiesche (Stick and Rudder, p. 358). For the above Cessna, for
instance, it's 45.4 degrees. For a flamed-out jet fighter, however,
things are considerably different. The formulas above, along with
formulas for the banked stall speed, for banked gliding flight path
angle, and for the minimum altitude loss in a 180-degree turn, can all
be found in my recent book Performance of Light Aircraft, pp. 294-296.
The following seven pages then treat the return-to-airport maneuver,
from start of the takeoff roll to contact with the runway or terrain,
in excruciating detail. Including wind effects, the typical
four-second hesitation when the engine stops, etc.
John. -- John T. Lowry, PhD Flight Physics; Box 20919; Billings MT
59104 Voice: 406-248-2606
Nov 1 1999, 1:00 am
Newsgroups: rec.aviation.piloting, rec.aviation.student
Date: 1999/11/01
Subject: Turn Back Maneuver
cos(phi) = (sqrt(2)/2)*sqrt(1-k^2)
where CD0 is the parasite drag coefficient, CLmax is the maximum lift
works.
For GA propeller-driven airplanes, k is a small number (0.116 for a
Cessna 172, flaps up) and so the best turnaround bank angle is very
The formulas above, along with formulas for the banked stall speed,
for banked gliding flight path angle, and for the minimum altitude
loss in a 180-degree turn, can all be found in my recent book
Performance of Light Aircraft, pp. 294-296. The following seven pages
then treat the return-to-airport maneuver, from start of the takeoff
roll to contact with the runway or terrain, in excruciating detail.
Including wind effects, the typical four-second hesitation when the
engine stops, etc.
John.
John T. Lowry, PhD
Flight Physics; Box 20919; Billings MT 59104
Voice: 406-248-2606
Mo
http://groups.google.com/group/rec.a...4829291b24775f
http://groups.google.com/group/rec.a...c37fab40401aba
http://groups.google.com/group/rec.a...73917967e58181
http://groups.google.com/group/rec.a...b42a74fe660741
http://groups.google.com/groups/sear...X-Y_&filter=0&
http://groups.google.com/group/rec.a...095b7459a04b3a
Old April 24th 08, 06:29 PM posted to rec.aviation.piloting
buttman
On Thu, 24 Apr 2008 17:05:06 +0200, Stefan sayeth:
You're suggesting instructors practice engine failures with their
students on takeoff? Oh boy, better hope Dudly doesn't see this...
Old April 24th 08, 06:34 PM posted to rec.aviation.piloting
Stefan
Glider pilots do it routinely.
Old April 24th 08, 07:24 PM posted to rec.aviation.piloting
Andy Hawkins
Hi,
EFATO practice is normal during the PPL in the UK (simulated, obviously).
The instructor chops the throttle and you pick a landing sight and get set
up for it in much the same way as you would a PFL.
You do have a bit of warning when he announces 'fanstop' over the radio
though!
Andy
lancair crash scapoose, OR gatt Piloting 10 October 26th 06 03:34 PM
Lancair IV Dico Reyers Owning 6 October 19th 04 11:47 PM
Lancair 320 ram air? ROBIN FLY Home Built 17 January 7th 04 11:54 PM
Lancair 320/360 kit wanted!!! Erik W Owning 0 October 3rd 03 10:17 PM
Lancair IVP Peter Gottlieb Home Built 2 August 22nd 03 03:51 AM
