WWII warplanes vs combat sim realism
Old November 21st 03, 12:39 PM
The Revolution Will Not Be Televised
Right, instead of forking out billions upon billions for a force of
capable strike fighters, I suggest the RAF has a look at what it's
been doing for the past 20 years plus, and accepts that there is a
role for a cheap strategic bomber. Yes, that's right: strategic
bombing on the cheap. Do not adjust your newsreader.
The role: All we want is a fantastically long range aircraft, with an
excellent sub-sonic economic cruise, extensive ECM and ECCM fit,
shedloads of decoys and suchlike, and a good PGM fit to allow an
enormous bombload to be carried and dropped on distant people of whom
we know little with great accuracy.
Let's face it, it's never going to operate against anybody with
substantive air defences or if it does the RAF will almost certainly
be operating with the USAAF who can handle all the glamour work. We
can even have a Eurofighter force for some token in-house air-to-air
capacity. But what we really need is something to lug large
quantities of PGMs to distant battlefields, and to do so more cheaply
than a carrier can in the majority of cases, and without all that
annoying diplomacy required to allow the use of local bases.
The solution: something that can be built relatively cheaply by BAe
Systems in the UK. Relatively low-tech in terms of airframe, with no
pretensions to any kind of multi-role or air-to-air performance
capability. This means lower chances of budgetary overruns, and
higher chances of maximising the pork-barrel job creation factor.
Only one service customer to confuse the issue with random spec
changes, only one defence beaurocracy to beat into submission, and
the admittedly minute production run offset against low airframe cost.
Or shall we just re-engine and re-fit the Vulcans?
Quick, before the men in white coats come to take me away!
Gavin Bailey
"Will Boogie Down For Food".- Sign held by Disco Stu outside the unemployment office.
Old November 21st 03, 01:22 PM
Keith Willshaw
"The Revolution Will Not Be Televised" wrote in
message ...
I suggest that this is one role that is right for a pilotless vehicle.
If all you intend to do is fly to a map reference point and
drop a shedload of guided or unguided HE on it why do you
need a pilot ?
Most of them have been turned into double glazing.
Keith
Old November 21st 03, 03:45 PM
Greg Hennessy
On Fri, 21 Nov 2003 14:05:11 -0000, "Keith Willshaw"
A reengined victor would be superior to the vulcan in all aspects of what
you propose IMHO.
Carrying 50% more bombload, higher and faster.
Until the wings fell off, they all used their airframe hours
many moons ago.
Keith
Quite true.
greg
$ReplyAddress =~ s#\@.*$##; # Delete everything after the '@'
The Following is a true story.....
Only the names have been changed to protect the guilty.
Old November 21st 03, 05:28 PM
On Fri, 21 Nov 2003 13:22:55 -0000, "Keith Willshaw"
need a pilot ?
I forgot the real reason: we have to sell it to a service full of
ex-pilots.
Gavin Bailey
Old November 21st 03, 05:30 PM
On Fri, 21 Nov 2003 13:53:55 +0000, Greg Hennessy
you propose IMHO.
Yeah, but let's face it, all the old V-force are shagged, and in any
case wouldn't have the same pork-barrel job-creation dynamic as a new
aircraft. Think modern cheapskate version of the B-52 or something
similar - I doubt they'd go for embedded engines again.
Gavin Bailey
Old November 22nd 03, 08:17 AM
On Fri, 21 Nov 2003 18:38:24 +0000, Greg Hennessy
Quite. The unnecessary selection and production of 3 aircraft was an act of
political stupidity. Nonsense about it being 'insurance' should have been
sorted at the trial stage.
I dunno, at least the Valiant came in on time and almost to budget.
which is impressive if we ignore the fatigue situation for a minute.
They really should have made a choice between the Vulcan and the
Victor, though, and probably in favour of the latter. Having said
that, there was a time constraint at the time coupled with the
necessity to produce a successful type which doesn't exist now.
similar
Yes, airbus will suggest using the wings and engines of the A-400M on a new
slender fuselage and call it the A-95M Ursa, The maritime variant, A-142M
would be an ideal nimrod replacement.
Think of all the french aerospace workers we can featherbed.
No, this is not a collaborative effort. They can work for certain
flagship programs at the political level, but one financial quagmire
at a time until the Eurofighter procurement and the A-whatever
(ex-FLA) contract is complete. This is a UK-led supplier effort.
Yes, with a modern high bypass turbofan, it would lead to some interesting
levels of wing root thickness.
Dig those old Short Sperrin airframes out of storage now!
Gavin Bailey
Air Force combat search and rescue joins AFSOC team Otis Willie Military Aviation 0 September 30th 03 09:49 PM
Combat Related Special Compensation update for Sept. 8-12 Otis Willie Military Aviation 0 September 17th 03 03:38 AM
FA: WWII B-3jacket, B-1 pants, Class A uniform N329DF Military Aviation 1 August 16th 03 03:41 PM
"Target for Today" & "Thunderbolt" WWII Double Feature at Zeno'sDrive-In Zeno Aerobatics 0 August 2nd 03 07:31 PM
"Target for Today" & "Thunderbolt": An Awesome WWII DoubleFeature at Zeno's Drive-In zeno Military Aviation 0 July 14th 03 07:31 PM
