#101
"Maxwell" luv2^fly99@cox.^net wrote in news:yckQj.67983$y05.63596
@newsfe22.lga: "Bertie the Bunyip" wrote in message ... WingFlaps wrote in news:ac05ca83-bbc8-4c3b- 9469- : On Apr 25, 8:31 pm, Stefan wrote: WingFlaps schrieb: Try reading the statement again, here it is: "Now we add in the energy losses from having to accelerate with the wind and to glide speed." To summarise your missed point, the pilot control inputs cost energy that is not factored into simple glide/time analysis. This is absolutely correct. But then, I dont understand the connection to your first statement regarding the wind. Additioinal drag by control input is completely unrelated to the presence or non-presence of wind. Itls a turn upwind to downwind. That involves 2 direction changes, one to reverse course and the the other to line up the runway. If there's wind there will be an effect on line up. Try thinking about more factors that cost altitude OK? It's not so much the loss of altitude that will get you in this manuever. it's the probable loss of control trying to manuever around back towards the field. Firstly, in any emergency that hasnt been drilled, you will have a moment where you will be sitting there with your mouth open in utter disbelief of what has just happened. in fact, even if you have drilled for it you will still have this moment, but if it's been practiced the moment you begine to do something about it will be sooner coming. While you're sitting there wondering what's going on, the speed will be bleeding off. Not good. Then, you will have to manuever the airplane around using rapid manuevering at a relatively high bank angle if you're going to make it (I'm assuiming you're still pretty low) and if you aren't 100% au fait with this sort of flying you're going to be very lucky to be able to maintain control of the airplane before the ground reaches up and smites you. This is less about the maths than the pilot;'s proficiency. The pilot who is proficient enough to do this will have determined an altitude above which he knows it is possible to do it and so the question will not be one of whether it's within the performance capabilities of the airplane, but one of whether the pilot can accurately control the airplane through the required manuever. Here is what you'll have to do the instant the engine gives up: Smooothly lower the nose as you roll just as smoothly, but as quickly as possible, towards the crosswind, if any. You will have to continue to lower the nose as the turn, which should ideally have at least 60 deg of bank, is completed. you should be just nibbling the stall during this, and , needless to say, perfectly co-ordinated. Pitch control is now critical as what you're trying to do is cheat physics by offloading the wing as you turn. a 60 degree bank in level flight will give you a stall speed of 1.4 VSO and you should be below that so you're right on the edge. This is all about having very good seat of the pants capability based on experience. As you approach the desired heading to your landing spot, you have to smoothly roll out and get the nose up and back to a good glide attitude. You'll have sacrificed some altitude doing the sharp turn, but far less than you would have making a wider turn with a gentle bank. As you level the wings, you should be on, or close to, your desired glide speed. This is a difficult manuever to pull off. Even practicing at a bit of altitude has some risks. you're going to pull a bit of G and it's easy to lose the plot and either spin out of it or overstress the airframe praciticing it unless you know what you're doing. It's not really something that most pilots should even consider. Someone flying 25 hours a year s unlikely ever to become sharp enough to do this reliably. I certainly wouldn't try it now unless there was no choice. There's a lot of crap talked about turning back and most of the accidents occuring as a result of this are because the pilot has heard it's possible and decides to learn how to do it when it actually happens. Most modern flight manuals tell you it isn't possible but this advice is ignored by guys who reckon they're a cut above because they did the math or tried it once or twice at altitude or because they read about it here. Bertie Now come on, Dudley wrote this for you, didn't he? Nope. Bertie |
#102
![]() @newsfe22.lga: "Bertie the Bunyip" wrote in message ... Dylan Smith wrote in : On 2008-04-25, WingFlaps wrote: On Apr 25, 9:31 pm, Dylan Smith wrote: IIRC, Vy is for a C172 is in the region of 65 knots - or best glide, and I can see you missed the point entirely. By the way, Vy is never at best glide (it is above that ~69knots in a 172) -perhaps you would I never said it was best glide. I said Vy for a C172 is *in the region of 65 knots* (I don't actually remember what it is off the top of my head, it's been 5 years since I flew a C172, but I do remember Vy being close to 65 knots). I do, however, remember that for an 'N' model C172, 65 knots was best glide and Vy was close to that number. (In fact a brief internet search shows it to be 70 knots, so if the pilot recognises an engine failure promptly, should not have to dive to regain airspeed as your scenario stated. In reality, your 'concrete numbers' are just as much handwaving: how many pilots seriously climb out to 600 feet at Vx? How many pilots would seriously spend 10 seconds doing nothing but talking on the radio when the engine has quit cold - instead of looking for a suitable landing site and navigating towards said site?) Good luck on your first engine failure during climb out, if you turn back I hope you make it. but you'll have a better chance going straight ahead... Actually, I did go straight ahead but with 4000 feet of runway remaining and a slow aircraft (C140), it wasn't exactly the hardest aviation decision I've had to make. If it happens again, I'll do what I think is prudent at the time. That might be straight ahead, it might be turn to some amount, and it might even be return to the airfield. I can't say at this point, and I won't be able to say unless it actually happens - just like one of our glider pilots did when the rope really did break at 200 feet: owing to the strong tailwind that he would have had on a downwind landing, he elected to land in a field instead, even though the turn itself was eminently possible and he could have made it to the runway. My friend who did have his engine lunch itself had the choice of a built up area, a busy beach full of people, or the airfield. He was at about 600 feet in a C150. If I had been in the same situation as him, I'd have done the same - try to get back on airfield property because it was the only thing flat not covered in people that was within range. I can not fault his decision. (He did better than airfield property, he did get it onto the runway). What I'm trying to say in a long winded way is that there are no prescriptive solutions. "Always land straight ahead" isn't always the right decision, nor is the decision to turn back even if you really can make the runway safely (in the glider example, the prospect of groundlooping into a barbed wire fence when the glider got below wind speed on the ground was a deciding factor to land in a field rather than on the runway). It depends on conditions at the time, how much altitude and airspeed you have, and what the terrain is like. Actually, if you're light or have a tailwind, best glide will come at a lower airspeed. in a manuever this tight you need every trick in the book at your disposal. Bertie Only if you fly as lame a you do. Snort! Yeh, my self image as a pilot hinges on the opinion of someone who counldn't teach a bird to fly. Bertie |
#103
In rec.aviation.student WingFlaps wrote:
On Apr 25, 8:31?pm, Stefan wrote: WingFlaps schrieb: Try reading the statement again, here it is: "Now we add in the energy losses from having to accelerate with the wind and to glide speed." To summarise your missed point, the pilot control inputs cost energy that is not factored into simple glide/time analysis. This is absolutely correct. But then, I dont understand the connection to your first statement regarding the wind. Additioinal drag by control input is completely unrelated to the presence or non-presence of wind. Itls a turn upwind to downwind. That involves 2 direction changes, one to reverse course and the the other to line up the runway. If there's wind there will be an effect on line up. Try thinking about more factors that cost altitude OK? A crosswind should only help you line up. If you stay aligned with the runway and turn into the wind then it will reduce the offset after you complete the turn. If you allow yourself to drift with the wind then this will further work in your favor. If you turn into the wind and push upwind during the takeoff then the wind can make things quite exciting, but don't do that. -- Michael Ash Rogue Amoeba Software |
#104
Stefan wrote:
B A R R Y schrieb: I'd rather hit a bus shelter or light poles @ 40-50 MPH than go in inverted after a stall/spin @ 200-300 AGL. But I hope that you rather risk a stall/spin than to hit a crowd of pedestrians with that meat chopper turning. If the chopper were turning... G |
#105
Stefan wrote:
B A R R Y schrieb: I'd rather hit a bus shelter or light poles @ 40-50 MPH than go in inverted after a stall/spin @ 200-300 AGL. But I hope that you rather risk a stall/spin than to hit a crowd of pedestrians with that meat chopper turning. Guys... Take a deep breath, please. Is this the "Argument Room", or what? In truth, I'm going to aim for the pack of baby joggers, or the senior citizen walking club, doing laps around the parking lot. Or with better luck, it'll be recess at the local elementary school... Come on! G A dead stick spam can, even though quickly descending, is plenty controllable while still flying. As one gets closer, and options run out, pilot choices remain to minimize or eliminate collateral damage. Shopping centers, industrial parks, golf courses, etc... all have greatly varying "busy" periods. That's all part of the decision at the actual time of need. We're talking low altitude, where the population of a landing spot should be pretty obvious. As we nit-pick this to death, what are the choices after a stall just a few hundred feet above the ground while turning? |
#106
WingFlaps schrieb:
In everyday's language, the word velocity stands for the _magnitude_ of the vector. Nope. Not even at high school. The magnitude is "speed". Maybe where you live. Not where I live. BS. This is stated in any basic physics text book -even Wiki knows it: "In physics...The scalar absolute value (magnitude) of velocity is speed." What part of "everyday's language" wasn't clear? |
#107
On Fri, 25 Apr 2008 13:24:31 +0000 (UTC), Bertie the Bunyip
wrote: "Maxwell" luv2^fly99@cox.^net wrote in news:YbkQj.67982$y05.56887 : "Bertie the Bunyip" wrote in message ... B A R R Y wrote in news:Z%iQj.22374$%41.15539 @nlpi064.nbdc.sbc.com: Shirl wrote: WingFlaps wrote: I've also heard a lot of BS in this thread about not having good palces to put the plane. There is nearly always somewhere flat to put the plane within 90 degrees of the runway centerline -even a road. Malls have big parking lots! I don't know about where you live, but malls here have lots of light poles, concrete islands, park-and-rest benches and ... and ... vehicles everywhere. And having gone through it once, I'm no longer fooled by what *looks* "flat" at 500, or even 50 feet. I'd rather hit a bus shelter or light poles @ 40-50 MPH than go in inverted after a stall/spin @ 200-300 AGL. Exactly. Bertie One doesn't equal the other moron. Obviously, fjukktard. Figured out that maze on the back of your froot loops box yet? Bertie lol Jade |
#108
On Fri, 25 Apr 2008 11:15:25 +0000 (UTC), Bertie the Bunyip
wrote: WingFlaps wrote in : On Apr 25, 8:50*pm, Bertie the Bunyip wrote: Larry Dighera wrote innews:3ui2149cg0sac5dsdsi4f05v8t42 : On Fri, 25 Apr 2008 01:27:52 +0000 (UTC), Bertie the Bunyip wrote in : The best way to do it is with a steep bank. Very steep. The bank angle may be quantified: Good grief Larry, you really are an idiot. Of course it can be quatified, but the numbers only tell a minute part of the story. I can categorically state that I can do a 180 with 70 deg bank at VSO 1.2 deadstick and come out the other end in one piece. Can you? Try it using those figures and send my the answer via my Ouiji board. Well I cannot understand you you can load the plane up like that and not raise stall speed beyond 1.2Vs so you must be using a wing drop to acclerate the turn? Do you could just stall out of the turn -but how much height do you loose in the stall and it's recovery? No, you have to lower the nose continuously to offload as you go around the bend. You will end up fairy nose low at the end of the turn alright but you can recover that as you level the wings. The turn is pretty rapid at that speed so you won't be in it too long. It's as about "on the edge" as you can get. It's the only way it can be done unles you have an airplane with an outrageous climb. If you're proficient in spins try it at a bit of altitude and a reduced bank angle. You can increase the bank in subsequent attempts as you become more comfortable. just don't get the idea that this will make you good enough to try it in anger on it's own! Bertie Is that a good description of how Bob Hoover used to fly his engine out performance in the Shrike commander? His energy management routine was one of the best parts of an airshow. Kirk |
#109
Stefan wrote in
: WingFlaps schrieb: In everyday's language, the word velocity stands for the _magnitude_ of the vector. Nope. Not even at high school. The magnitude is "speed". Maybe where you live. Not where I live. BS. This is stated in any basic physics text book -even Wiki knows it: "In physics...The scalar absolute value (magnitude) of velocity is speed." What part of "everyday's language" wasn't clear? Who's everyday? is he on first or is he the shortstop? Bertie |
#110
Daedalus wrote in
: On Fri, 25 Apr 2008 13:24:31 +0000 (UTC), Bertie the Bunyip wrote: "Maxwell" luv2^fly99@cox.^net wrote in news:YbkQj.67982$y05.56887 : "Bertie the Bunyip" wrote in message ... B A R R Y wrote in news:Z%iQj.22374$% 41.15539 @nlpi064.nbdc.sbc.com: Shirl wrote: WingFlaps wrote: I've also heard a lot of BS in this thread about not having good palces to put the plane. There is nearly always somewhere flat to put the plane within 90 degrees of the runway centerline -even a road. Malls have big parking lots! I don't know about where you live, but malls here have lots of light poles, concrete islands, park-and-rest benches and ... and ... vehicles everywhere. And having gone through it once, I'm no longer fooled by what *looks* "flat" at 500, or even 50 feet. I'd rather hit a bus shelter or light poles @ 40-50 MPH than go in inverted after a stall/spin @ 200-300 AGL. Exactly. Bertie One doesn't equal the other moron. Obviously, fjukktard. Figured out that maze on the back of your froot loops box yet? Bertie lol Jade $:*0" Bertie |
lancair crash scapoose, OR | gatt | Piloting | 10 | October 26th 06 03:34 PM |
Lancair IV | Dico Reyers | Owning | 6 | October 19th 04 11:47 PM |
Lancair 320 ram air? | ROBIN FLY | Home Built | 17 | January 7th 04 11:54 PM |
Lancair 320/360 kit wanted!!! | Erik W | Owning | 0 | October 3rd 03 10:17 PM |
Lancair IVP | Peter Gottlieb | Home Built | 2 | August 22nd 03 03:51 AM |
