Folks, could anyone tell me what the part number/description is for the
fitting that screws into the bottom of the PIK-20 ballast dump tube for filling. My PIK's ballast system appears to be in good repair but I can't seem to find what fitting to use. I'm sure it is some kind of metric fitting w/25mm or so threads? Thanks. Glen Kelley PIK-20 "HL" |
On my PIK 20B the fill tube thread fitting is 3/4 inch water pipe. I
use the plastic garden hose fittings with the internal bore drilled out to provide a slightly greater water flow. These screw-in fittings then accept the push-on hose fittings that connect to 1/2 inch bore hose. All very cheap, convenient and readily available, at least in Australia. Regards, Geoff Vincent Grampians Soaring Club Sat, 26 Apr 2008 00:23:28 GMT, "Glen Kelley" wrote: Folks, could anyone tell me what the part number/description is for the fitting that screws into the bottom of the PIK-20 ballast dump tube for filling. My PIK's ballast system appears to be in good repair but I can't seem to find what fitting to use. I'm sure it is some kind of metric fitting w/25mm or so threads? Thanks. Glen Kelley PIK-20 "HL" |
Brass Compression Fitting Brass Thread Fitting Sale on good price | valvetom | Piloting | 0 | November 28th 06 02:26 AM |
$640.00 to fill the tanks... | Jay Honeck | Piloting | 304 | August 29th 06 02:16 PM |
$640.00 to fill the tanks... | Jay Honeck | Piloting | 53 | August 21st 06 07:22 PM |
New Orleans, fill it with dirt | Doug | Piloting | 18 | September 2nd 05 01:52 AM |
How to fill out a logbook. | Scott | Soaring | 3 | February 8th 04 05:41 PM |
