limit of trim = limit of travel?
Old April 26th 08, 09:02 PM posted to rec.aviation.piloting
Mxsmanic
Default limit of trim = limit of travel?
WingFlaps writes:
No, that doesn't sound right.
The stall horn is supposed to sound before the stall speed is reached.
It does, but only a second or two before (assuming that airspeed is still
falling). If I take remedial action instantly the stall does not occur.
  #24
Old April 26th 08, 09:24 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Mxsmanic wrote in
news
WingFlaps writes:
A stall will never occur. Computers don;'t stal.
Bertie
  #25
Old April 26th 08, 11:09 PM posted to rec.aviation.piloting
Buttman wrote in
WingFlaps wrote:
On Apr 27, 7:03Â*am, Mxsmanic wrote:
I just tried a few experiments
reached.
Cheers
"supposed to", but doesn't always. I've flown planes (especially
cessnas with their crappy cereal-box-toy-quality plastic stall horns)
that don't go off at all, but will test fine on the ground.
What, you didn't stick chewing gum in them to fail them so your students
would learn what it was like when they failed?
Bertie
  #26
Old April 26th 08, 11:13 PM posted to rec.aviation.piloting
Buttman wrote in news:4813a805$0$30167
Stealth Pilot wrote:
oxygen is a valuable resource. please stop wasting it.
Stealth Pilot
someones grumpy...
There you go again. There's a deserving cockroach not getting his fair
share.
Bertie
  #27
Old April 26th 08, 11:19 PM posted to rec.aviation.piloting
Buttman wrote in news:4813aa40$0$30228
Bertie the Bunyip wrote:
Buttman wrote in
reached.
Cheers
Bertie
Oh bertie, you're such a card
I know. And you're such an idiot.
Bertie
  #28
Old April 27th 08, 12:13 AM posted to rec.aviation.piloting
On Apr 26, 1:50 pm, Bertie the Bunyip wrote:
Actually, there are plenty of airplanes with tabs not much bigger than trim
tabs that use them to fly the airplane. There is no connection whatsoever
between the surface and the stick. All done by the tab. I don;'t think
anyone is making any of them these days. Last new design I can think of is
the DC-8.
Bertie
Servo tabs. Sometimes with a spring onto the surface itself, for
low-speed control, and sometimes with no connection other than the
tab's hinge to the surface. But it does move the control surface,
which is what controls the airplane. The tab itself doesn't fly the
airplane. It actually moves in the opposite direction to the surface.
  #29
Old April 27th 08, 12:14 AM posted to rec.aviation.piloting
On Apr 26, 12:37 pm, WingFlaps wrote:
The idea was that if he looked at the area of the trim tab he would
realize it cannot generate full surface deflection. I've not tried
winding in full trim with power on to see if a stall results. I would
have guessed that Mr Cessna would not make the trim that powerful...
It's that powerful. With the trim centered, at full power, you're in
a climb. Rolling in full up trim will make the climb steep enough to
stall the airplane.
Dan
  #30
Old April 27th 08, 12:29 AM posted to rec.aviation.piloting
wrote in
than trim tabs that use them to fly the airplane. There is no
connection whatsoever between the surface and the stick. All done by
the tab. I don;'t think anyone is making any of them these days. Last
new design I can think of is the DC-8.
Bertie
That's right. Lots of biggies used them in the old days. There are also
balance which just aid a conventionally controlled surface in a similar
way. Those I have flown. Generally htey also have a spring tab which is
adjacent and gears down the action of the servo or balance tab. Without the
spring tab the servo or balance tab would make the control surface more
sensitive at higher speeds, so the spring tab acts as a kind of artificial
feel.
Bertie
The Sky is Their Limit [email protected] Soaring 7 November 13th 06 02:44 AM
speed limit in class B Andrey Serbinenko Piloting 0 July 23rd 06 04:05 AM
Pegasus life limit Mark628CA Soaring 2 March 30th 06 10:37 PM
Aft CG limit(s) Andy Durbin Soaring 13 November 26th 03 05:10 AM
Pushing the limit Dan Shackelford Military Aviation 20 September 14th 03 10:27 PM
