limit of trim = limit of travel?
Old April 27th 08, 08:29 PM posted to rec.aviation.piloting
Mxsmanic
Default limit of trim = limit of travel?
Tina writes:
If you show significant climb rate with a single piston your sim is
smoking tobacco substitute.
How much is significant, and which single pistons?
  #43
Old April 27th 08, 09:39 PM posted to rec.aviation.piloting
WingFlaps
On Apr 28, 1:16*am, Clark wrote:
WingFlaps wrote in news:1cd20dfa-3cfb-489a-9fee-
On Apr 27, 6:14*am, wrote:
On Apr 26, 11:33 am, WingFlaps wrote:
Look at the size of a trim surface and the size of the elevator. Think
about which one is more powerful. You can't stall a 182 with full
trim, but you can with the yoke. OK?
Cheers
*Don't give the impression that the trim tab is doing the flying. It's
not. Trim tab down moves the elevator up, and the elevator controls
the pitch.
The idea was that if he looked at the area of the trim tab he would
realize it cannot generate full surface deflection. I've not tried
winding in full trim with power on to see if a stall results. I would
have guessed that Mr Cessna would not make the trim that powerful...
The trim stall is on the Jeppesen syllabus to be demonstrated as part of PPL
training...
Yes that's for full power which is not what I was thinking MX was
talking about.
Cheers
  #44
Old April 27th 08, 10:07 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Mxsmanic wrote in
Tina writes:
However many you are smoking, it's obviously too much.
Bertie
  #45
Old April 28th 08, 01:58 AM posted to rec.aviation.piloting
Dave[_19_]
Umm..
A guy here is bulding a plane called a "Rocket" (similar to an RV,
single engine piston).
Specs indicate it has an ROC of 3000 fpm..
With the freakin engine they are shoehorning in it, it will be
ballistic.
That's not "significant"?
Dave
Thats not On Sun, 27 Apr 2008 07:07:56 -0700 (PDT), Tina
  #46
Old April 28th 08, 03:23 AM posted to rec.aviation.piloting
On Apr 27, 6:58 pm, Dave wrote:
Umm..
ballistic.
Dave
Harmon Rocket. I've seen one fly. Makes almost any other
piston single look anemic.
http://www.harmonrocket.com/specsprofnew.htm
Dan
  #47
Old April 28th 08, 04:04 AM posted to rec.aviation.piloting
Dave[_19_]
That's the one, and this one is getting ALL the toys... nothing being
spared, and the the engine is being "breathed upon" as well
Actually, I find there are several (SEL, piston) that will do 2000
FPM +.
Dave
On Sun, 27 Apr 2008 19:23:15 -0700 (PDT),
Dan
  #49
Old April 28th 08, 05:00 AM posted to rec.aviation.piloting
Maxwell[_2_]
Mxsmanic wrote in
Bertie the Bunyip writes:
I've flown a few that couldn't even be trimmed for slow flight or
approach ( pre war stuff) The trim was apparently only considered to
be useful for cruise.
Interesting. I was flying my simulated Cessna 182 and it didn't seem
like the pitch trim fully deflected the elevators even with the trim
all the way over (that is, I could still move the yoke to get even
further deflection). It sounds like this is true to life.
Nothing about a sim is true to life. It's a toy. Different airplanes have
different authorits. i can loop my Citabira with the pitch trim.
Bertie
YEAH!!!! Sure ya can lamer.
  #50
Maxwell[_2_]
"Buttman" wrote in message
Bertie the Bunyip wrote:
Buttman wrote in
WingFlaps wrote:
On Apr 27, 7:03 am, Mxsmanic wrote:
I just tried a few experiments
No, that doesn't sound right.
The stall horn is supposed to sound before the stall speed is
reached.
Cheers
"supposed to", but doesn't always. I've flown planes (especially
cessnas with their crappy cereal-box-toy-quality plastic stall horns)
that don't go off at all, but will test fine on the ground.
What, you didn't stick chewing gum in them to fail them so your students
would learn what it was like when they failed?
Bertie
Oh bertie, you're such a card
Na, not really. Just a self made prick.
The Sky is Their Limit [email protected] Soaring 7 November 13th 06 02:44 AM
speed limit in class B Andrey Serbinenko Piloting 0 July 23rd 06 04:05 AM
Pegasus life limit Mark628CA Soaring 2 March 30th 06 10:37 PM
Aft CG limit(s) Andy Durbin Soaring 13 November 26th 03 05:10 AM
Pushing the limit Dan Shackelford Military Aviation 20 September 14th 03 10:27 PM
