Airplanes and Conveyor Belts - Mythbusters
Old May 1st 08, 08:31 PM posted to rec.aviation.soaring
tommytoyz
Default Airplanes and Conveyor Belts - Mythbusters
Question: Can a conventional powered airplane take off from a conveyor
belt which is moving at the same speed but in an opposite direction?
You asked the question wrong. In the Video the question is:
belt which is moving at the take off speed of the airplane in the
opposite direction?
Old May 1st 08, 09:03 PM posted to rec.aviation.soaring
opposite direction?
Exactly.
Old May 2nd 08, 04:12 AM posted to rec.aviation.soaring
Michael Ash
Werner Schmidt wrote:
Hallo Michael Ash, Du schriebst am 01.05.2008 17:42
2.) If both begin to accelerate at the same time, it makes no
significant difference to a usual start. The rolling drag of the
undercarriage wheels pulls the airplane a *little* backwards, but this
effect is negligible. - The wheels just turn faster (as above).
In standard Newtonian dynamics, rubbing (or rolling) friction is
independent of speed, so long as you're moving at all. So the extra speed
of the wheels is no penalty at all, barring problems with extra heat as
you mentioned.
But same friction at higher speed releases more energy (=heat).
Right, that's why I mentioned extra heat.
Why does a spaceship need a heat shield and a ASK13 doesn't? And special
gearboxes do need cooling (air may suffice). Bearings become hot if
rotation speed is high and cooling not adequate. A too hot bearing may jam.
The comparison with the spaceship isn't quite apt. Aerodynamic friction
increases with the square of the speed so the total rate of generated heat
increases with the cube of the speed. Rolling friction is constant so the
total rate increases linearly. In any case, if the extra heat is enough to
cause problems then that would certainly make a difference, but I think
the original question more or less assumes that it's not a factor.
Michael Ash
Rogue Amoeba Software
Old May 2nd 08, 05:44 AM posted to rec.aviation.soaring
Werner Schmidt
Hello Michael Ash, you wrote at 02.05.2008 05:12
Correct.
I just wanted to mention that a jamming wheel bearing (caused by extra
heat due to higher rotation speed) might cause an accident.
Regards
Werner
Old May 2nd 08, 05:22 PM posted to rec.aviation.soaring
Kloudy via AviationKB.com
Jim Logajan wrote:
The answer is in the wing!!! :-)
Maybe it would help by simply saying "The answer is in the air."
The answer
My friend
is blowin' over the wing
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...aring/200805/1
Old May 6th 08, 12:13 AM posted to rec.aviation.soaring
opposite direction?
The wheel steering will get a bit touchy!
MythBusters airplane on a conveyor belt Peter Clark Piloting 56 February 3rd 08 10:05 PM
Mythbusters Rich S.[_1_] Home Built 7 February 1st 08 12:03 PM
Two conveyor belt scenarios [email protected] Piloting 24 September 27th 06 05:32 AM
MythBusters Hilton Piloting 7 February 4th 04 03:30 AM
