A Camcorder for Homebuilders
Old May 4th 08, 06:56 PM posted to rec.aviation.homebuilt
Default A Camcorder for Homebuilders
Samsung SC-MX10-XAA. Type that into Google, they'll show you a
picture of it. But it is smaller than it looks -- it's about the size
of a small Russet potato... about 5" long by 2.5" in diameter.
Street price is about $180 (as of May 2008)
If you're an accomplished videographer you'd never give this camera a
second glance. It lacks the bells & whistles. In fact, it's about as
complicated as a box-camera; it doesn't even have a view-finder. It
has no moving parts. Instead of tapes or disks, it records on those
plug-in memory chips, the ones about the size of a postage stamp. And
at barely six ounces, it's too light; not enough mass. Hold it in
your hand, the resulting video shows every breath you take.
But at six ounces, it doesn't take a rocket scientist to see you can
pull some g's with the thing, as in attaching it to your airplane.
(It has the usual 1/4-20 tripod mount, plus the indexing hole for shoe-
type tripods.)
Press the red button, it starts taking pictures. If you're using the
Automatic focus and electronic damping, you'll get a pretty good
image, one that's a bit sharper than most because it uses 720x480
pixels. That fills up your memory chip pretty fast but you can buy
chips having up to 8 Gigabytes of capacity... and even 4G will give
you TWO HOURS of recording, which is about the life of your battery.
The battery is a plug-in brick and they'll sell you a spare.
The camera uses MPEG4 format, which is different from most other video
cameras. But after passing the images through your PC you can convert
them into anything you want, assuming your PC has the Right Stuff (ie,
fast CPU and lotsa RAM, plus lots of disk space).
But it's light. It's small. Poke it in your pocket or hang it around
your neck, you can wear it all day and never notice. And it takes
only a minute to plug-in a fresh battery and a new memory chip. The
used ones go into a zip-loc along with your notes -- names & addresses
of the people you've been bothering :-) (Leave the LCD screen closed,
hold the camera UNDER your arm, most folks never even notice you're
recording.)
The camera comes with all the cabling needed to recharge the battery,
connect to your computer or play the images through a TV set. Samsung
also includes a fairly comprehensive suite of video editing software.
It's not Adobe 'Premiere' but it is more than adequate at the Basic
Training Film level.
Today is the 4th of May 2008. I've a hunch the price of this unit
will drop significantly in the coming year. (I paid over $300 for the
thing a few months ago and the price has already fallen by about 40%.)
I've found this little video camera to be a very useful tool. I've a
hunch some of you will too.
-R.S.Hoover
Old May 12th 08, 02:56 PM posted to rec.aviation.homebuilt
Mark Hickey
snip
Nice camera for the money. But if you want something REALLY small and
light, check out the Sanyo Xacti series camcorders. The thing is
smaller than my PDA (a lot smaller, actually), and slips into a shirt
pocket easily (since it's also smaller than a pack of cigarettes).
It also uses a chip and produces MP4 movies (and JPG images with a 6
megapixel camera). The form factor makes it easier to point and shoot
than a "brick" camcorder.
http://www.shopcartusa.com/P_Sanyo_X...PC-CG6_VPCCG6/
Costs a little more than the Samsung (though a whole lot less than I
paid for mine a couple years ago), but the ability to slip it into a
pocket or wear it like a pager/cellphone is invaluable.
YMMV.
Mark "Hollywood" Hickey
Old May 12th 08, 03:30 PM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
snip
YMMV.
What is the lens like?
I'm a big fan of optical zooms over software zoom.
Richard
(remove the X to email)
Now just why the HELL do I have to press 1 for English?
John Wayne
Old June 1st 08, 03:27 PM posted to rec.aviation.homebuilt
Mark Hickey
YMMV.
I don't know the technical specs (which are "odd" for camcorders
apparently, since they're converted into "SLR lens equivalents". It's
certainly a small lens - not the greatest choice for low-light
situations (the jpeg compression starts getting pretty grainy as the
light goes away). But still, it's a 5X optical zoom, and is passably
wide in its "zoomed out mode".
Mark Hickey
Camcorder mic input of intercom audio? Doug Vetter Owning 6 July 9th 05 12:37 PM
Headset -> Camcorder audio adapter DK Piloting 9 April 19th 05 12:17 AM
camcorder recording Cessna intercom audio question Marty from Sunny Florida Owning 7 November 15th 04 04:26 PM
Is this the place for Homebuilders? Gilan Home Built 2 September 23rd 04 02:06 PM
Best Homebuilders Books? [email protected] Home Built 5 January 21st 04 01:06 AM
