glider simulators
Old May 5th 08, 01:49 PM posted to rec.aviation.soaring
Peter Wyld[_2_]
Default glider simulators
"noel.wade" wrote in message
Joystick features that are nice to have: A "hat" for view control,
and a "throttle" control for moving the spoilers. I also like a
joystick with at least 5 or 6 buttons (so I can put flap and trim
controls on the joystick).
Optional extra for the technologically advanced: NaturalPoint
"TrackIR" (http://www.naturalpoint.com/trackir/). This is an infrared
camera that you put on your computer monitor. It watches a reflective
head-band or headset-clip that you wear, and uses your head movements
to let you "look around" freely.
..... so while you are looking at the wall instead of your wingtip, someone
else in the room can see what you ought to be looking at?
This would only be useful if you have Circlorama screens (whatever happened
to Circlorama?) or a pair of VR glasses.
Old May 5th 08, 02:51 PM posted to rec.aviation.soaring
Paul Remde
Hi,
You would think so, I asked the same question to a user. He said that the
IR units work OK with a single monitor. You can turn your head a little to
the left and keep your eyes on the screen. It doesn't seem like it would
work well to me, but it supposedly works better then you would think.
Paul Remde
"Peter Wyld" wrote in message
news
happened to Circlorama?) or a pair of VR glasses.
Old May 5th 08, 04:17 PM posted to rec.aviation.soaring
noel.wade
The TrackIR amplifies your head movements. So a tiny turn of your
head can equate to looking out the side of the aircraft in the
simulator. Its a little odd at first to keep your eyes on the screen
while you turn your head - but if you set the amplification rate up to
the right level its really not a problem (we're talking maybe 5 or 10
degrees of head movement) - just takes about 5 minutes to get used
to.
Check out the demo videos on the NaturalPoint website.
Also note that I *do* state its best to get comfortable with the
simulator and everything before adding this piece. But the ability to
easily look around adds a lot if you have the patience to set it up
properly.
On a slightly different note: I have done a lot of experimenting and
found that longtime pilots have a *much* harder time with simulators
than new pilots. After doing some unscientific research and gathering
feedback, I have come to believe that pilots who have flown for a long
time and never used a simulator get easily frustrated by the lack of
physical / kinesthetic feedback, and the lack of familiarity of flying
over strange terrain in a strange glider. They're so used to
"feeling" the aircraft and flying in their local airspace with known
references that they have a hard time just flying the plane based on
the sight-picture and the instruments and the visible angles to the
ground. Becuase they're so used to being good pilots flying in a
skilled manner, having a hard time in the simulator tends to frustrate
and/or embarrass these experienced pilots - and as a result they have
a dislike or disdain for the simulator.
Take care,
--Noel
Old May 5th 08, 04:20 PM posted to rec.aviation.soaring
noel.wade
Here's a demo of the TrackIR and explains how it works:
http://www.youtube.com/watch?v=_AO0F5sLdVM
--Noel
P.S. Condor doesn't fully support "6 degrees of freedom" like they
talk about. But it does support looking up, down, left, and right.
Old May 5th 08, 05:05 PM posted to rec.aviation.soaring
Michael Ash
I've had a similar experience to this, except sort of backwards.
I used to do a lot of flying in X-Plane, in all kinds of different
aircraft. (X-Plane isn't really the best at simulating anything, but it
simulates almost everything, which is its big advantage.) I was pretty
good at it, although I'm sure I did a lot of non-standard things. And in
fact flying the gliders in X-Plane is one of the things that got me into
real soaring. I had a lot of fun doing crazy things in the simulator, then
thought, hey, this is something I could actually enjoy in real life.
I don't use X-Plane that much anymore. Somehow doing regular flying in
reality makes the sim seem less fun than it once was....
But I still fire it up on occasion. And the thing that always amuses me
when I do is that I'm really *bad* at it. Even flying gliders, even flying
types that I fly in reality, in locations that I fly in reality, I
totally stink up the place.
Part of this is because my controls setup is very poor. I didn't put in
very much money at all, so the result reflects that. But I used the same
controls before and was much better! I certainly have trouble with the
lack of physical feedback, poor control feel, and narrow field of view,
even though I was more or less fine with them before.
In the end they're just two different skills. You can make them closer by
putting in more money to have a better setup, but it still ends up being
different skills. An experienced pilot who jumps into a sim thinking that
he should be able to instantly master it will likely be disappointed
because of this.
Michael Ash
Rogue Amoeba Software
Old May 5th 08, 05:19 PM posted to rec.aviation.soaring
Bill Daniels
someone
to.
properly.
Take care,
--Noel
Same experience here.
My take on the frustrations of experienced pilots is that they have never
learned to use their eyes correctly. Somewhat counterintuitively, it's
posible to fly a glider largely by feel and with little reliance on visual
inputs for anything other than navigation. Frustration with a PC flight
simulator simply discloses this shortcoming.
A computer flight simulator forces a pilot to use vision for things like
instrument scan and attitude control. This can be very frustrating until
the pilots visual skills come up to speed.
A second issue is that, to a greater degree than in a real glider, a PC
flight simulator requires the pilot to anticipate the aerodynamic response
of the simulated glider. For example, knowing that raising the nose
relative to the horizon WILL result in lower airspeed provides for very
precise airspeed control. Fortunately the flight dynamics model used in
Condor is VERY VERY good.
Bill D
IFR simulators Tony Owning 8 October 27th 03 08:42 PM
IFR simulators Richard Kaplan Instrument Flight Rules 3 July 24th 03 03:53 AM
