tricycle undercarriage
Old November 26th 03, 02:58 PM
G. Stewart
Default tricycle undercarriage
From late WW2 onwards, many aircraft designs started using the
tricycle undercarriage scheme. Prior to this, most used the other one
(you know, two large wheels up in front, with the plane tilted back
onto a small support wheel).
Why the change? Well, good visibility (while taxing/take-off/etc.)
would seem to be a huge advantage of the tricycle undercarraige ... so
I suppose the question really should be - why did most aircraft NOT
use the tricycle undercarriage design until late WW2?
Old November 26th 03, 03:03 PM
QDurham
Weight, drag, expense. Of course the Wright Flyer had tricycle gear.
Quent
Old November 26th 03, 03:12 PM
Steven P. McNicoll
"G. Stewart" wrote in message
m...
The tricycle gear has more drag and weight, but the primary reason was
generally poor runways prior to 1950 or so.
Steven P. McNicoll
"QDurham" wrote in message
The Wright Flyer had skids.
Old November 26th 03, 04:40 PM
Tex Houston
m...
Are you referring to those 'late' designs such as
Bell P-39, Production 1939
Douglas A-20, Production 1939
Douglas C-54, Production 1942
Martin B-26, Production 1940
North American B-25, Production 1940
Consolidated PBY-5, Production 1939
Consolidated B-24, Production 1941
ERCO Ercoupe, Production 1937
Fairchild AT-13, AT-14, At-21 Production ??? but early
I really do not think they were as rare as you say and I only included USA
aircraft.
Regards,
Tex Houston
Old November 26th 03, 04:53 PM
QDurham
I stand corrected. But I think the first wheeled Wright plane was tricycle.
Q
Old November 26th 03, 06:48 PM
WDA
Tail draggers are prone to ground loop whereas the trike configuration makes
for less destructive landings by tyro pilots.
WDA
end
m...
Old November 26th 03, 08:43 PM
killfile
Early landing gear was heavy, because materials technology dictated that it
had to be big, and thick to solid. In addition to this it was, of course,
another thing to fail. One of the other big, big factors was that the nose
gear needs to go into the nose - which on on piston engined fighters, was
usally full of ... engine. (Bar the P-39, which was rear-engined.)
One of the best illustrations of why the switch was made was the Me-262,
which originally had a tail-dragger configuration. On the initial test
flight, they found that the jet wash headed straight for the tailplanes and
pinned the aircraft to the ground - to get it airbourne, the pilot had to
take the horrendously dangerous manouver of tapping the brakes to bring up
the tail.
Matt
Old November 26th 03, 09:13 PM
Cub Driver
Cost, weight, and the fact that "conventional" (tailwheel) landing
gear was a matter of pride with the Old Pilots.
(Still is. There's a sign at Hampton Airport: "Real Men Fly
Taildraggers".)
Actually, trikes came in a bit earlier than you suggest. The Bell P-39
Airacobra and the Douglas A-20 (DB-9) were two examples of trikes
designed and put into service at the end of the 1930s.
Weight was a fairly significant matter. The Douglas AD / A-1 "Spad"
was designed toward the end of World War II and served through the
Vietnam War. It was a taildragger because Douglas had to meet a
stringent weight requirement from the navy. I forget how many hundred
ponds a trike would have added, but it was significant.
For a while there, also, taildraggers were considered a requirement
for carrier landings, since they could be caught by the tail and
slammed down onto the deck in their normal landing position.
Personally, I like to fly a taildragger. A two-wheel landing, well
performed, is a very satisfying act. I'm always amused at the thought
that I fly a taildragger but fly the plane right onto the ground,
while the guys in the trikes have to make a stall-down landing.
all the best -- Dan Ford
email: (put CUB in subject line)
see the Warbird's Forum at
www.warbirdforum.com
and the Piper Cub Forum at www.pipercubforum.com
Old November 26th 03, 10:14 PM
QDurham
Dan wrotre in part:
Personally, I like to fly a taildragger. A two-wheel landing, well performed,
is a very satisfying act. I'm always amused at the thought that I fly a
taildragger but fly the plane right onto the ground, while the guys in the
Well said. Couldn't agree more. A good wheels landing is a total delight --
particularly in that miserable (in landing) Twin Beech.
Quent
Tricycle Midget Thought Dick Home Built 4 March 26th 04 11:12 PM
