OK, I've been googling, wikiing, and reading FAR gobbledygook all morning
and I still don't have a clear picture of what the nav light requirements (in both azimuth and elevation) are as regards brightness. If anybody has a point to a clear post of the brightness requirements, I'd sure be interested in seeing it. Sarangen's article on wingtip lights is about the best I can find, but he duplicates the alpha graph and says nothing about the theta graph. Jim -- "If you think you can, or think you can't, you're right." --Henry Ford |
"RST Engineering" wrote in message m... OK, I've been googling, wikiing, and reading FAR gobbledygook all morning and I still don't have a clear picture of what the nav light requirements (in both azimuth and elevation) are as regards brightness. If anybody has a point to a clear post of the brightness requirements, I'd sure be interested in seeing it. Sarangen's article on wingtip lights is about the best I can find, but he duplicates the alpha graph and says nothing about the theta graph. Jim -- "If you think you can, or think you can't, you're right." --Henry Ford Jim: I found the following to have quite a bit of information regarding nav lite intensities. FAR Part 25 sub part F and Sec. 25.1391 and beyond. I hope this is of some use -- Stuart & Kathryn Fields, Publishers Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell (760) 608-1299 technical cell www.experimentalhelo.com www.vksupportservice.com |
A couple of things, Stu. One, Part 25 has to do with transport category
aircraft. Two, the corresponding sections in Part 23 (light aircraft) are what I was referring to when I mentioned "gobbledygook" in my original post. My hit is that they gave this section to a newly graduated engineer with a specialty in optics and (s)he wanted to show the boss how much a good engineer can obfuscate matters. A simple set of graphs would make things SO much easier to interpret. Jim -- "If you think you can, or think you can't, you're right." --Henry Ford "Stuart & Kathryn Fields" wrote in message .. . Jim: I found the following to have quite a bit of information regarding nav lite intensities. FAR Part 25 sub part F and Sec. 25.1391 and beyond. I hope this is of some use -- Stuart & Kathryn Fields, Publishers Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell (760) 608-1299 technical cell www.experimentalhelo.com www.vksupportservice.com |
On May 6, 3:09*pm, "RST Engineering" wrote:
A couple of things, Stu. *One, Part 25 has to do with transport category aircraft. *Two, the corresponding sections in Part 23 (light aircraft) are what I was referring to when I mentioned "gobbledygook" in my original post. |
Have a look at
http://www.sarangan.org/aviation/eur...tip-Lights.pdf "RST Engineering" a écrit dans le message de m... OK, I've been googling, wikiing, and reading FAR gobbledygook all morning and I still don't have a clear picture of what the nav light requirements (in both azimuth and elevation) are as regards brightness. If anybody has a point to a clear post of the brightness requirements, I'd sure be interested in seeing it. Sarangen's article on wingtip lights is about the best I can find, but he duplicates the alpha graph and says nothing about the theta graph. Jim -- "If you think you can, or think you can't, you're right." --Henry Ford |
Have a look at what I wrote.
Jim -- "RESO / Claude GUTH" wrote in message ... Have a look at http://www.sarangan.org/aviation/eur...tip-Lights.pdf "RST Engineering" a écrit dans le message de m... Sarangen's article on wingtip lights is about the best I can find, but he duplicates the alpha graph and says nothing about the theta graph. Jim |
Because IDK WTF or WTF the SAE is or WTF the AS docs are.
Why do you persist in using contractions that are not commonly understood? Jim -- "If you think you can, or think you can't, you're right." --Henry Ford wrote in message ... Why don't you just buy the AS documents from the SAE. They state the requirements pretty clearly... |
On May 7, 9:44*am, "RST Engineering" wrote:
Because IDK WTF or WTF the SAE is or WTF the AS docs are. Why do you persist in using contractions that are not commonly understood? Jim -- "If you think you can, or think you can't, you're right." * * * * --Henry Ford wrote in message ... Why don't you just buy the AS documents from the SAE. *They state the requirements pretty clearly... SAE is the Society for Automotive Engineers. I thought all engineers knew that one, it is on every oil can out there. Know what a TSO is? Read the TSO's and you find the AS documents. |
Because he's got a whole library shelf full of TSOs that he's been designing
to for about forty years now. Most TSOs are comprehensible; the FAR is not. Regarding the SAE documents, sixty bucks for a couple of simple line graphs seems a little on the high side, and since you can't get the documents until you pay the fee, you have no idea if those graphs are even included. Jim He doesn't know the difference between an acronym and a contraction so how would he figure out TSO????? |
"Ernest Christley" wrote Is this any help? http://ernest.is-a-geek.org/Delta/Ex...iment_LED.html This link does not work, but the one below, should. Geeze, not even the author can get his own link right! g http://ernest.isa-geek.org/Delta/Experiments/Dyke_Experiment_LED.html -- Jim in NC |
| FSX best graphic card | Syucomm | Simulators | 5 | December 4th 06 11:37 PM |
| Two monitors and graphic card set up | Stephen Ford | Simulators | 2 | January 18th 05 08:00 PM |
| great graphic card | Shaun | Products | 0 | November 14th 04 01:43 AM |
| graphic card for sale | Shaun | Aviation Marketplace | 0 | November 14th 04 01:42 AM |
| Radeon Graphic drivers for laptops | Blue | Simulators | 0 | October 31st 03 09:25 AM |
