FAA Is Not The Sole Flight Regulatory Authority
Old May 8th 08, 12:13 AM posted to rec.aviation.piloting
Larry Dighera
Default FAA Is Not The Sole Flight Regulatory Authority
On Wed, 07 May 2008 23:32:01 -0700, Airbus wrote in
You are probably
already aware of the requirement to fly at least 2,000
feet above ground level (AGL) over wildlife preserves
depicted on sectional aeronautical charts.
I thought this was a "recommendation" not a requirement.
Has this changed, or is the expert author very out of touch with her purported
specialty?
That is an excellent question. The same thought crossed my mind when
I read that excerpt from the story also.
I find on reference to 'wild' nor 'preserve' in Part 91:
http://ecfr.gpoaccess.gov/cgi/t/text...1.3.10&idno=14
Below is some research information. Perhaps there is enough there for
you to find the answer to your question.
The note on the charts reads thus:
REGULATION REGARDING FLIGHTS OVER CHARTED NATIONAL PARK SERVICE
AREAS, U.S. FISH AND WILDLIFE SERVICE AREAS, AND U.S. FOREST
SERVICE AREAS
The landing of aircraft is prohibited on lands or waters
administered by the National Park Service, U.S. Fish and Wildlife
Service or U.S. Forest Service without authorization from the
respective agency. Exceptions include: 1) when forced to land due
to an emergency beyond the control of the operator, 2) at
officially designated landing sites, or 3) on approved official
business of the Federal Government.
All aircraft are requested to maintain a minimum altitude of 2,000
feet above the surface of the following: National Parks,
Monuments, Seashores, Lakeshores, Recreation Areas and Scenic
Riverways administered by the National Park Service; National
wildlife Refuges, Big Game Refuges, Game Ranges and Wildlife
Ranges administered by the U.S. Fish and Wildlife Service; and
Wilderness and Primitive areas administered by the U.S. Forest
Service. FAA advisory Circular (AC) 91-36, "Visual Flight Rules
(VFR) flight Near Noise-Sensitive Areas," defines the surface as:
The highest terrain within 2,000 feet laterally of the route of
flight, or the upper-most rim of a canyon or valley.
Federal regulations also prohibit airdrops by parachute or other
means of persons, cargo, or objects from aircraft on lands
administered by the three agencies without authorization from the
respective agency. Exceptions include: 1) emergencies involving
the safety of human life, or 2) threat of serious property loss.
Here is the Advisory Circular mentioned above:
http://rgl.faa.gov/Regulatory_and_Gu...F?OpenDocument
Advisory Circular Information
AC Number: AC 91-36D
Date: 09/17/2004
Subject: Visual Flight Rules (VFR) Flight Near Noise-Sensitive
Areas
Related Regulation(s):
Part 91 Section Number(s): Unknown Section
Cancels: AC 91-36C
Initiating Office: ATO-R
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/208330d7efad2bf9862570650070769f/$FILE/AC91-36d.pdf
U.S. Department of Transportation
Federal Aviation Administration
Date: September 17, 2004
AC No: 91-36D
Subject: VISUAL FLIGHT RULES (VFR) FLIGHT NEAR NOISE-SENSITIVE
AREAS
Initiated by: ATO-R
ADVISORY CIRCULAR
1. PURPOSE. This Advisory Circular (AC) encourages pilots making
VFR flights near noise-sensitive areas to fly at altitudes higher
than the minimum permitted by regulation and on flight paths that
will reduce aircraft noise in such areas.
2. EFFECTIVE DATE. This advisory circular is effective on
September 17, 2004.
3. CANCELLATION. Advisory Circular 91-36C, Visual Flight Rules
(VFR) Flight Near Noise Sensitive Areas, dated October 19, 1984,
is cancelled.
4. AUTHORITY. The FAA has authority to formulate policy regarding
use of the navigable airspace (Title 49 United States Code,
Section 40103).
5. EXPLANATION OF CHANGES. This AC has been updated to include a
definition of “noise-sensitive” area and add references to Public
Law 100-91; the FAA Noise Policy for Management of Airspace Over
Federally Managed Lands, dated November 1996; and the National
Parks Air Tour Management Act of 2000, with other minor wording
changes.
6. BACKGROUND.
a. Excessive aircraft noise can result in annoyance,
inconvenience, or interference with the uses and enjoyment of
property, and can adversely affect wildlife. It is particularly
undesirable in areas where it interferes with normal activities
associated with the area’s use, including residential,
educational, health, and religious structures and sites, and
parks, recreational areas (including areas with wilderness
characteristics), wildlife refuges, and cultural and historical
sites where a quiet setting is a generally recognized feature or
attribute. Moreover, the FAA recognizes that there are locations
in National Parks and other federally managed areas that have
unique noise-sensitive values. The Noise Policy for Management of
Airspace Over Federally Managed Areas, issued November 8, 1996,
states that it is the policy of the FAA in its management of the
navigable airspace over these locations to exercise leadership in
achieving an appropriate balance between efficiency, technological
practicability, and environmental concerns, while maintaining the
highest level of safety.
b. The Federal Aviation Administration (FAA) receives complaints
concerning low flying aircraft over noise sensitive areas such as
National Parks, National Wildlife Refuges, Waterfowl Production
Areas and Wilderness Areas. Congress addressed aircraft flights
over Grand Canyon National Park in Public Law 100-91 and
commercial air tour operations over other units of the National
Park System (and tribal lands within or abutting such units) in
the National Parks Air Tour Management Act of 2000.
c. Increased emphasis on improving the quality of the environment
requires a continuing effort to provide relief and protection from
low flying aircraft noise.
d. Potential noise impacts to noise-sensitive areas from low
altitude aircraft flights can also be addressed through
application of the voluntary practices set forth in this AC.
Adherence to these practices is a practical indication of pilot
concern for the environment, which will build support for aviation
and alleviate the need for any additional statutory or regulatory
actions.
7. DEFINITION. For the purposes of this AC, an area is
“noise-sensitive” if noise interferes with normal activities
associated with the area’s use. Examples of noise-sensitive areas
include residential, educational, health, and religious structures
and sites, and parks, recreational areas (including areas with
wilderness characteristics), wildlife refuges, and cultural and
historical sites where a quiet setting is a generally recognized
feature or attribute.
8. VOLUNTARY PRACTICES.
a. Avoidance of noise-sensitive areas, if practical, is preferable
to overflight at relatively low altitudes.
b. Pilots operating noise producing aircraft (fixed-wing,
rotary-wing and hot air balloons) over noise-sensitive areas
should make every effort to fly not less than 2,000 feet above
ground level (AGL), weather permitting. For the purpose of this
AC, the ground level of noise-sensitive areas is defined to
include the highest terrain within 2,000 feet AGL laterally of the
route of flight, or the uppermost rim of a canyon or valley. The
intent of the 2,000 feet AGL recommendation is to reduce potential
interference with wildlife and complaints of noise disturbances
caused by low flying aircraft over noise-sensitive areas.
c. Departure from or arrival to an airport, climb after take-off,
and descent for landing should be made so as to avoid prolonged
flight at low altitudes near noise-sensitive areas.
d. This advisory does not apply where it would conflict with
Federal Aviation Regulations, air traffic control clearances or
instructions, or where an altitude of less than 2,000 feet AGL is
considered necessary by a pilot to operate safely.
9. COOPERATIVE ACTIONS. Aircraft operators, aviation associations,
airport managers, and others are asked to assist in voluntary
compliance with this AC by publicizing it and distributing
information regarding known noise-sensitive areas.
Signed
________________________________
Sabra W. Kaulia
Director of System Operations & Safety
Page 2
Advisory Circular Information Number: AC 91-36D mentions under 8.
VOLUNTARY PRACTICES those situations where voluntary compliance is
expected.
Here is Public Law 100-91 mentioned in the AC above under 5.
EXPLANATION OF CHANGES:
http://www.nps.gov/grca/naturescienc...d/PL100-91.pdf
The National Parks Overflight Act of 1987
Public Law 100-91
SECTION 1. STUDY OF PARK OVERFLIGHTS.
(a) Study by Park Service.—The Secretary of the Interior
(hereinafter referred to as the ‘Secretary’), acting through the
Director of the National Park Service, shall conduct a study to
determine the proper minimum altitude which should be maintained
by aircraft when flying over units of the National Park System.
The Secretary of Transportation, acting through the Administrator
of the Federal Aviation Administration (hereinafter referred to as
the ‘Administrator’), shall provide technical assistance to the
Secretary in carrying out the study.
(b) General Requirements of Study.—The study shall identify any
problems associated with overflight by aircraft of units of the
National Park System and shall provide information regarding the
types of overflight which may be impacting on park unit resources.
The study shall distinguish between the impacts caused by
sightseeing aircraft, military aircraft, commercial aviation,
general aviation, and other forms of aircraft which affect such
units. The study shall identify those park system units, and
portions thereof, in which the most serious adverse impacts from
aircraft overflights exist.
(c) Specific Requirements.—The study under this section shall
include research at the following units of the National Park
System: Cumberland Island National Seashore, Yosemite National
Park, Hawaii Volcanoes National Park, Haleakala National Park,
Glacier National Park, and Mount Rushmore National Memorial, and
at no less than four additional units of the National Park System,
excluding all National Park System units in the State of Alaska.
The research at each such unit shall provide information and an
evaluation regarding each of the following:
(1) the impacts of aircraft noise on the safety of the park system
users, including hikers, rock-climbers, and boaters;
(2) the impairment of visitor enjoyment associated with flights
over such units of the National Park System;
(3) other injurious effects of overflights on the natural,
historical, and cultural resources for which such units were
established; and
(4) the values associated with aircraft flights over such units of
the National Park System in terms of visitor enjoyment, the
protection of persons or property, search and rescue operations
and firefighting.
Such research shall evaluate the impact of overflights by both
fixed-wing aircraft and helicopters. The research shall include an
evaluation of the differences in noise levels within such units of
the National Park System which are associated with flight by
commonly used aircraft at different altitudes. The research shall
apply only to overflights and shall not apply to landing fields
within, or adjacent to, such units.
(d) Report to Congress.—The Secretary shall submit a report to the
Congress within 3 years after the enactment of this Act [Aug. 18,
1987] containing the results of the study carried out under this
section. Such report shall also contain recommendations for
legislative and regulatory action which could be taken regarding
the information gathered pursuant to paragraphs (1) through (4) of
subsection (c). Before submission to the Congress, the Secretary
shall provide a draft of the report and recommendations to the
Administrator for review. The Administrator shall review such
report and recommendations and notify the Secretary of any adverse
effects which the implementation of such recommendations would
have on the safety of aircraft operations. The Administrator shall
consult with the Secretary to resolve issues relating to such
adverse effects. The final report shall include a finding by the
Administrator that implementation of the recommendations of the
Secretary will not have adverse effects on the safety of aircraft
operations, or if the Administrator is unable to make such
finding, a statement by the Administrator of the reasons he
believes the Secretary’s recommendations will have an adverse
effect on the safety of aircraft operations.
(e) FAA Review of Rules.—The Administrator shall review current
rules and regulations pertaining to flights of aircraft over units
of the National Park System at which research is conducted under
subsection (c) and over any other such units at which such a
review is determined necessary by the Administrator or is
requested by the Secretary. In the review under this subsection,
the Administrator shall determine whether changes are needed in
such rules and regulations on the basis of aviation safety. Not
later than 180 days after the identification of the units of the
National Park System for which research is to be conducted under
subsection (c), the Administrator shall submit a report to
Congress containing the results of the review along with
recommendations for legislative and regulatory action which are
needed to implement any such changes.
(f) Authorization.—There are authorized to be appropriated such
sums as may be necessary to carry out the studies and review under
this section.
SEC. 2. FLIGHTS OVER YOSEMITE AND HALEAKALA DURING STUDY AND
REVIEW.
(a) Yosemite National Park.—During the study and review periods
provided in subsection (c), it shall be unlawful for any fixed
wing aircraft or helicopter flying under visual flight rules to
fly at an altitude of less than 2,000 feet over the surface of
Yosemite National Park. For purposes of this subsection, the term
‘surface’ refers to the highest terrain within the park which is
within 2,000 feet laterally of the route of flight and with
respect to Yosemite Valley such term refers to the upper-most rim
of the valley.
(b) Haleakala National Park.—During the study and review periods
fly at an altitude below 9,500 feet above mean sea level over the
surface of any of the following areas in Haleakala National Park:
Haleakala Crater, Crater Cabins, the Scientific Research Reserve,
Halemauu Trail, Kaupo Gap Trail, or any designated tourist
viewpoint.
(c) Study and Review Periods.—For purposes of subsections (a) and
(b), the study period shall be the period of the time after the
date of enactment of this Act [Aug. 18, 1987] and prior to the
submission of the report under section 1. The review period shall
comprise a 2-year period for Congressional review after the
submission of the report to Congress.
(d) Exceptions.—The prohibitions contained in subsections (a) and
(b) shall not apply to any of the following:
(1) emergency situations involving the protection of persons or
property, including aircraft;
(2) search and rescue operations;
(3) flights for purposes of firefighting or for required
administrative purposes; and
(4) compliance with instructions of an air traffic controller.
(e) Enforcement.—For purposes of enforcement, the prohibitions
contained in subsections (a) and (b) shall be treated as
requirements established pursuant to section 307 of the Federal
Aviation Act of 1958 [see 49 U.S.C. 40103 (b)]. To provide
information to pilots regarding the restrictions established under
this Act, the Administrator shall provide public notice of such
restrictions in appropriate Federal Aviation Administration
publications as soon as practicable after the enactment of this
Act [Aug. 18, 1987].
SEC. 3. GRAND CANYON NATIONAL PARK.
(a) Noise associated with aircraft overflights at the Grand Canyon
National Park is causing a significant adverse effect on the
natural quiet and experience of the park and current aircraft
operations at the Grand Canyon National Park have raised serious
concerns regarding public safety, including concerns regarding the
safety of park users.
(b) Recommendations.—
(1) Submission.—Within 30 days after the enactment of this Act
[Aug. 18, 1987], the Secretary shall submit to the Administrator
recommendations regarding actions necessary for the protection of
resources in the Grand Canyon from adverse impacts associated with
aircraft overflights. The recommendations shall provide for
substantial restoration of the natural quiet and experience of the
park and protection of public health and safety from adverse
effects associated with aircraft overflight. Except as provided in
subsection (c), the recommendations shall contain provisions
prohibiting the flight of aircraft below the rim of the Canyon,
and shall designate flight free zones. Such zones shall be flight
free except for purposes of administration and for emergency
operations, including those required for the transportation of
persons and supplies to and from Supai Village and the lands of
the Havasupai Indian Tribe of Arizona. The Administrator, after
consultation with the Secretary, shall define the rim of the
Canyon in a manner consistent with the purposes of this paragraph.
(2) Implementation.—Not later than 90 days after receipt of the
recommendations under paragraph (1) and after notice and
opportunity for hearing, the Administrator shall prepare and issue
a final plan for the management of air traffic in the air space
above the Grand Canyon. The plan shall, by appropriate regulation,
implement the recommendations of the Secretary without change
unless the Administrator determines that implementing the
recommendations would adversely affect aviation safety. If the
Administrator determines that implementing the recommendations
would adversely affect aviation safety, he shall, not later than
60 days after making such determination, in consultation with the
Secretary and after notice and opportunity for hearing, review the
recommendations consistent with the requirements of paragraph (1)
to eliminate the adverse effects on aviation safety and issue
regulations implementing the revised recommendations in the plan.
In addition to the Administrator’s authority to implement such
regulations under the Federal Aviation Act of 1958 [see 49 U.S.C.
40101 et seq.], the Secretary may enforce the appropriate
requirements of the plan under such rules and regulations
applicable to the units of the National Park System as he deems
appropriate.
(3) Report.—Within 2 years after the effective date of the plan
required by subsection (b)(2), the Secretary shall submit to the
Congress a report discussing—
(A) whether the plan has succeeded in substantially restoring the
natural quiet in the park; and
(B) such other matters, including possible revisions in the plan,
as may be of interest.
The report shall include comments by the Administrator regarding
the effect of the plan’s implementation on aircraft safety.
(c) Helicopter Flights of River Runners.—Subsection (b) shall not
prohibit the flight of helicopters—
(1) which fly a direct route between a point on the north rim
outside of the Grand Canyon National Park and locations on the
Hualapai Indian Reservation (as designated by the Tribe); and
(2) whose sole purpose is transporting individuals to or from boat
trips on the Colorado River and any guide of such a trip.
SEC. 4. BOUNDARY WATERS CANOE AREA WILDERNESS.
The Administrator shall conduct surveillance of aircraft flights
over the Boundary Waters Canoe Area Wilderness as authorized by
the Act of October 21, 1978 (92 Stat. 1649–1659) for a period of
not less than 180 days beginning within 60 days of enactment of
this Act [Aug. 18, 1987]. In addition to any actions the
Administrator may take as a result of such surveillance, he shall
provide a report to the Committee on Interior and Insular Affairs
and the Committee on Public Works and Transportation of the United
States House of Representatives and to the Committee on Energy and
Natural Resources and the Committee on Commerce, Science, and
Transportation of the United States Senate. Such report is to be
submitted within 30 days of completion of the surveillance
activities. Such report shall include but not necessarily be
limited to information on the type and frequency of aircraft using
the airspace over the Boundary Waters Canoe Area Wilderness.
SEC. 5. ASSESSMENT OF NATIONAL FOREST SYSTEM WILDERNESS
OVERFLIGHTS.
(a) Assessment by Forest Service.—The Chief of the Forest Service
(hereinafter referred to as the ‘Chief’) shall conduct an
assessment to determine what, if any, adverse impacts to
wilderness resources are associated with overflights of National
Forest System wilderness areas. The Administrator of the Federal
Aviation Administration shall provide technical assistance to the
Chief in carrying out the assessment. Such assessment shall apply
only to overflight of wilderness areas and shall not apply to
aircraft flights or landings adjacent to National Forest System
wilderness units. The assessment shall not apply to any National
Forest System wilderness units in the State of Alaska.
(b) Report to Congress.—The Chief shall submit a report to
Congress within 2 years after enactment of this Act [Aug. 18,
1987] containing the results of the assessments carried out under
this section.
(c) Authorization.—Effective October 1, 1987, there are authorized
to be appropriated such sums as may be necessary to carry out the
assessment under this section.
SEC. 6. CONSULTATION WITH FEDERAL AGENCIES.
In conducting the study and the assessment required by this Act,
the Secretary of the Interior and the Chief of the Forest Service
shall consult with other Federal agencies that are engaged in an
analysis of the impacts of aircraft overflights over
federally-owned land.”
Section 307 of the Federal Aviation Act of 1958 [see 49 U.S.C. 40103
(b)] is mentioned in Public Law 100-91 above:
http://law.justia.com/us/codes/title49/49usc40103.html
§ 40103. — Sovereignty and use of airspace.
From the U.S. Code Online via GPO Access
[wais.access.gpo.gov]
[Laws in effect as of January 7, 2003]
[Document not affected by Public Laws enacted between
January 7, 2003 and December 19, 2003]
[CITE: 49USC40103]
TITLE 49--TRANSPORTATION
SUBTITLE VII--AVIATION PROGRAMS
PART A--AIR COMMERCE AND SAFETY
subpart i--general
CHAPTER 401--GENERAL PROVISIONS
Sec. 40103. Sovereignty and use of airspace
(a) Sovereignty and Public Right of Transit.--(1) The United
States
Government has exclusive sovereignty of airspace of the United States.
(2) A citizen of the United States has a public right of transit
through the navigable airspace. To further that right, the Secretary
of
Transportation shall consult with the Architectural and Transportation
Barriers Compliance Board established under section 502 of the
Rehabilitation Act of 1973 (29 U.S.C. 792) before prescribing a
regulation or issuing an order or procedure that will have a
significant
impact on the accessibility of commercial airports or commercial air
transportation for handicapped individuals.
(b) Use of Airspace.--(1) The Administrator of the Federal
Aviation Administration shall develop plans and policy for the use of
the navigable airspace and assign by regulation or order the use of
the airspace necessary to ensure the safety of aircraft and the
efficient use of airspace. The Administrator may modify or revoke an
assignment when required in the public interest.
(2) The Administrator shall prescribe air traffic regulations on
the flight of aircraft (including regulations on safe altitudes) for--
(A) navigating, protecting, and identifying aircraft;
(B) protecting individuals and property on the ground;
(C) using the navigable airspace efficiently; and
(D) preventing collision between aircraft, between aircraft
and land or water vehicles, and between aircraft and airborne objects.
(3) To establish security provisions that will encourage and allow
maximum use of the navigable airspace by civil aircraft consistent
with national security, the Administrator, in consultation with the
Secretary of Defense, shall--
(A) establish areas in the airspace the Administrator decides
are necessary in the interest of national defense; and
(B) by regulation or order, restrict or prohibit flight of
civil aircraft that the Administrator cannot identify, locate, and
control with available facilities in those areas.
(4) Notwithstanding the military exception in section 553(a)(1) of
title 5, subchapter II of chapter 5 of title 5 applies to a regulation
prescribed under this subsection.
(c) Foreign Aircraft.--A foreign aircraft, not part of the armed
forces of a foreign country, may be navigated in the United States as
provided in section 41703 of this title.
(d) Aircraft of Armed Forces of Foreign Countries.--Aircraft of
the armed forces of a foreign country may be navigated in the United
States only when authorized by the Secretary of State.
(e) No Exclusive Rights at Certain Facilities.--A person does not
have an exclusive right to use an air navigation facility on which
Government money has been expended. However, providing services at an
airport by only one fixed-based operator is not an exclusive right
if--
(1) it is unreasonably costly, burdensome, or impractical for
more than one fixed-based operator to provide the services; and
(2) allowing more than one fixed-based operator to provide the
services requires a reduction in space leased under an agreement
existing on September 3, 1982, between the operator and the
airport.
(Pub. L. 103-272, Sec. 1(e), July 5, 1994, 108 Stat. 1101.)
Historical and Revision
Notes
Revised Section Source (U.S. Code)
Source (Statutes at Large)
40103(a)(1)........................... 49 App.:1508(a) (1st
sentence). Aug. 23, 1958, Pub. L. 85-726, Secs.
307(a), (c), (d), 308(a) (3d
sentence), 1108(a), 1201, 1202, 72
Stat. 749, 750, 751, 798, 800.
40103(a)(2)........................... 49 App.:1304. Aug. 23, 1958,
Pub. L. 85-726, Sec.
104, 72 Stat. 740; Oct. 4, 1984, Pub.
L. 98-443, Sec. 14, 98 Stat. 1711.
49 App.:1551(b)(1)(E). Aug.
28, 1958, Pub. L. 85-726, 72 Stat.
731, Sec. 1601(b)(1)(E); added Oct.
4, 1984, Pub. L. 98-443, Sec. 3(e),
98 Stat. 1704.
40103(b)(1)........................... 49 App.:1348(a).
49 App.:1655(c)(1). Oct. 15,
1966, Pub. L. 89-670, Sec.
6(c)(1), 80 Stat. 938; Jan. 12, 1983,
Pub. L. 97-449, Sec. 7(b), 96 Stat.
2444.
40103(b)(2)........................... 49 App.:1348(c).
49 App.:1655(c)(1).
40103(b)(3)........................... 49 App.:1521.
49 App.:1522.
49 App.:1655(c)(1).
40103(b)(4)........................... 49 App.:1348(d).
40103(c).............................. (no source).
40103(d).............................. 49 App.:1508(a) (last
sentence).
40103(e).............................. 49 App.:1349(a) (3d sentence).
49 App.:1349(a) (last Aug. 23,
sentence). 731, Sec. 308(a)
(last sentence);
added Sept. 3, 1982, Pub. L. 97-248,
Sec. 524(a)(1), 96 Stat. 695.
In subsection (a)(1), the word ``has'' is substituted for ``is
declared to possess and exercise complete and'' to eliminate surplus
words. The word ``national'' is omitted as surplus. The text of 49
App.:1508(a) (1st sentence words after 1st comma) is omitted as
surplus.
In subsection (a)(2), the words ``of the United States'' are
omitted for consistency in the revised title and because of the
definition of ``navigable airspace'' in section 40102(a) of the
revised title. The words ``or amending'' are omitted as surplus.
In subsection (b), the word ``Administrator'' in section 307(a),
(c), and (d) of the Federal Aviation Act of 1958 (Public Law 85-726,
72 Stat. 749, 750) is retained on authority of 49:106(g).
In subsection (b)(1) and (3)(B), the word ``rule'' is omitted as
being synonymous with ``regulation''.
In subsection (b)(1), the words ``under such terms, conditions,
and limitations as he may deem'' are omitted as surplus. The words
``In the exercise of his authority under section 1348(a) of this
Appendix'' in 49 App.:1522 are omitted as unnecessary because of the
restatement.
In subsection (b)(2), before clause (A), the word ``shall'' is
substituted for ``is further authorized and directed'' for consistency
in the revised title and to eliminate unnecessary words.
In subsection (b)(3), before clause (A), the words ``In the
exercise of his authority under section 1348(a) of this Appendix'' in
49 App.:1522 are omitted as surplus. The word ``navigable'' is added
for clarity and consistency. In clause (A), the words ``such zones
or'' are omitted as surplus.
In subsection (b)(4), the words ``the military exception'' are
substituted for ``any exception relating to military or naval
functions'' to eliminate unnecessary words and because ``naval'' is
included in ``military''. The words ``applies to a regulation
prescribed under'' are substituted for ``In the exercise of the
rulemaking authority . . . the Secretary of Transportation shall be
subject to'' to eliminate unnecessary words and because ``rules'' and
``regulations'' are synonymous.
Subsection (c) is added for clarity.
In subsection (d), the words ``including the Canal Zone'' are
omitted because of the Panama Canal Treaty of 1977.
In subsection (e), before clause (1), the words ``any landing
area'' are omitted as being included in the definition of ``air
navigation facility'' in section 40102(a) of the revised title. The
word ``only'' is added for clarity. In clause (2), the words ``on
September 3, 1982'' are added for clarity.
Regulations
Pub. L. 85-726, title VI, Sec. 613(a), (b), as added by Pub.
L.101-508, title IX, Sec. 9124, Nov. 5, 1990, 104 Stat. 1388-370,
provided that:
``(a) National Disaster Areas.--Before the 180th day following the
date of the enactment of this section [Nov. 5, 1990], the
Administrator, for safety and humanitarian reasons, shall issue such
regulations as may be necessary to prohibit or otherwise restrict
aircraft overflights of any inhabited area which has been declared a
national disaster area in the State of Hawaii.
``(b) Exceptions.--Regulations issued pursuant to subsection (a)
shall not be applicable in the case of aircraft overflights involving
an emergency or a ligitimate [sic] scientific purpose.''
National Airspace Redesign
Pub. L. 106-181, title VII, Sec. 736, Apr. 5, 2000, 114 Stat. 171,
provided that:
``(a) Findings.--Congress makes the following findings:
``(1) The national airspace, comprising more than 29 million
square miles, handles more than 55,000 flights per day.
``(2) Almost 2,000,000 passengers per day traverse the United
States through 20 major en route centers, including more than 700
different sectors.
``(3) Redesign and review of the national airspace may produce
benefits for the travelling public by increasing the efficiency and
capacity of the air traffic control system and reducing delays.
``(4) Redesign of the national airspace should be a high
priority for the Federal Aviation Administration and the air
transportation industry.
``(b) Redesign.--The Administrator [of the Federal Aviation
Administration], with advice from the aviation industry and other
interested parties, shall conduct a comprehensive redesign of the
national airspace system.
``(c) Report.--Not later than December 31, 2000, the Administrator
shall transmit to the Committee on Commerce, Science, and
Transportation of the Senate and the Committee on Transportation and
Infrastructure of the House of Representatives a report on the
Administrator's comprehensive national airspace redesign. The report
shall include projected milestones for completion of the redesign and
shall also include a date for completion.
``(d) Authorization.--There is authorized to be appropriated to
the Administrator to carry out this section $12,000,000 for each of
fiscal years 2000, 2001, and 2002.''
Section Referred to in Other Sections
This section is referred to in sections 106, 40106, 40109, 44101,
44502, 46301, 46307, 46316 of this title.
Old May 8th 08, 12:44 AM posted to rec.aviation.piloting
Bob Noel
WingFlaps wrote:
I'm puzzled, how would you know where to direct the high power
targeting beam if the search beam had not already identified a target?
sonar bouy?
Bob Noel
(goodness, please trim replies!!!)
Old May 8th 08, 01:09 AM posted to rec.aviation.piloting
John T
"Larry Dighera" wrote in message
I wrote and asked her about the published exception in the regulation
she cited, but has not yet received a response from her.
I very much doubt you will.
We obviously differ in our inference of the meaning of the exception
cited in (iv) above. I see no mention of "unaware or uninterested
that the whale is below them." anywhere in the entire regulation Title
50 Code of Federal Regulations section 224.103, so I'm wondering how
you reached your conclusion.
Simple logic, Larry. The point of such restrictions is to limit the
disturbance to endangered animals. Flights hovering overhead or repeatedly
passing over the animals could stress them or cause them to take (perhaps
dangerous) evasive maneuvers attempting to get away. When you re-read the
exclusion you quoted you'll see the rules apply only to those aircraft
engaged in whale watching (or even your dreaded "whale watch") and I'm
pretty sure the pilot of a whale watch/watching flight would know he's on
such a mission.
It is the wording "whale watch" as opposed to 'whale watching' that
leads me to believe there may be a formal definition of the term, or a
formal permitting process to which it refers.
See above. Your assumption only reinforces my point that folks on such
missions would know they're on such missions and the rules you cited would
apply to them - not to the transient pilot travelling from Point A to Point
B.
Old May 8th 08, 07:32 AM posted to rec.aviation.piloting
Airbus[_4_]
says...
On Tue, 6 May 2008 20:30:35 -0400, "John T"
wrote in
m
Since the beginning
of the year, the National Oceanic and Atmospheric
Administration (NOAA) has documented several
private aircraft off the coasts of Georgia and Florida
circling in close proximity to right whales, which are
a critically endangered species in the baleen whale
family.
Apparently the author of the above article that appeared on page 28 of
FAAAviation News May/June 2008, Ms. Susan Parson, overlooked Title 50
Code of Federal Regulations section 224.103(c))(iv):
(iv) Paragraphs (c)(1) and (c)(2) of this section do not apply to
an aircraft unless the aircraft is conducting whale watch
activities.
I don't think what she said is contrary to the exception you listed. The
exception applies to folks unaware or uninterested that the whale is below
them.
You are probably
specialty?
AIM is pseudo-regulatory rps Piloting 9 October 26th 05 06:16 PM
GA headed for regulatory trouble [email protected] Piloting 183 July 9th 05 02:43 PM
FAA Inspector overstepping his authority (I think) Screwed Owning 7 May 2nd 05 03:52 PM
What is regulatory? Bob Gardner Piloting 11 March 21st 05 11:04 PM
FAA authority over military B2431 Military Aviation 14 August 25th 03 04:58 PM
