Nav Light Graphic
Old May 6th 08, 08:10 PM posted to rec.aviation.homebuilt,rec.aviation.owning
RST Engineering
Default Nav Light Graphic
OK, I've been googling, wikiing, and reading FAR gobbledygook all morning
and I still don't have a clear picture of what the nav light requirements
(in both azimuth and elevation) are as regards brightness.
If anybody has a point to a clear post of the brightness requirements, I'd
sure be interested in seeing it. Sarangen's article on wingtip lights is
about the best I can find, but he duplicates the alpha graph and says
nothing about the theta graph.
"If you think you can, or think you can't, you're right."
--Henry Ford
Old May 6th 08, 09:52 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Stuart & Kathryn Fields
"RST Engineering" wrote in message
m...
--Henry Ford
Jim: I found the following to have quite a bit of information regarding nav
lite intensities. FAR Part 25 sub part F and Sec. 25.1391 and beyond.
I hope this is of some use
Stuart & Kathryn Fields, Publishers
Experimental Helo magazine
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478 ph
(760) 408-9747 publication cell
(760) 608-1299 technical cell
www.experimentalhelo.com
www.vksupportservice.com
Old May 6th 08, 10:09 PM posted to rec.aviation.homebuilt,rec.aviation.owning
RST Engineering
A couple of things, Stu. One, Part 25 has to do with transport category
aircraft. Two, the corresponding sections in Part 23 (light aircraft) are
what I was referring to when I mentioned "gobbledygook" in my original post.
My hit is that they gave this section to a newly graduated engineer with a
specialty in optics and (s)he wanted to show the boss how much a good
engineer can obfuscate matters.
A simple set of graphs would make things SO much easier to interpret.
--Henry Ford
"Stuart & Kathryn Fields" wrote in message
nav lite intensities. FAR Part 25 sub part F and Sec. 25.1391 and beyond.
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478 ph
Old May 7th 08, 05:35 AM posted to rec.aviation.homebuilt,rec.aviation.owning
On May 6, 3:09*pm, "RST Engineering" wrote:
A couple of things, Stu. *One, Part 25 has to do with transport category
aircraft. *Two, the corresponding sections in Part 23 (light aircraft) are
Old May 7th 08, 07:35 AM posted to rec.aviation.homebuilt,rec.aviation.owning
RESO / Claude GUTH[_2_]
Have a look at
http://www.sarangan.org/aviation/eur...tip-Lights.pdf
"RST Engineering" a écrit dans le message de
m...
--Henry Ford
Old May 7th 08, 04:29 PM posted to rec.aviation.homebuilt,rec.aviation.owning
RST Engineering
Have a look at what I wrote.
"RESO / Claude GUTH" wrote in message
Have a look at
m...
Sarangen's article on wingtip lights is about the best I can find, but he
duplicates the alpha graph and says nothing about the theta graph.
Old May 7th 08, 04:44 PM posted to rec.aviation.homebuilt,rec.aviation.owning
RST Engineering
Because IDK WTF or WTF the SAE is or WTF the AS docs are.
Why do you persist in using contractions that are not commonly understood?
--Henry Ford
Why don't you just buy the AS documents from the SAE. They state the
requirements pretty clearly...
Old May 7th 08, 06:59 PM posted to rec.aviation.homebuilt,rec.aviation.owning
* * * * --Henry Ford
Why don't you just buy the AS documents from the SAE. *They state the
SAE is the Society for Automotive Engineers. I thought all engineers
knew that one, it is on every oil can out there.
Know what a TSO is? Read the TSO's and you find the AS documents.
Old May 8th 08, 12:26 AM posted to rec.aviation.homebuilt,rec.aviation.owning
RST Engineering
Because he's got a whole library shelf full of TSOs that he's been designing
to for about forty years now. Most TSOs are comprehensible; the FAR is not.
Regarding the SAE documents, sixty bucks for a couple of simple line graphs
seems a little on the high side, and since you can't get the documents until
you pay the fee, you have no idea if those graphs are even included.
He doesn't know the difference between an acronym and a contraction so how
would he figure out TSO?????
Old May 8th 08, 05:15 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Morgans[_2_]
"Ernest Christley" wrote Is this any help?
http://ernest.is-a-geek.org/Delta/Ex...iment_LED.html
This link does not work, but the one below, should. Geeze, not even the author
can get his own link right! g
http://ernest.isa-geek.org/Delta/Experiments/Dyke_Experiment_LED.html
Jim in NC
FSX best graphic card Syucomm Simulators 5 December 4th 06 10:37 PM
Two monitors and graphic card set up Stephen Ford Simulators 2 January 18th 05 07:00 PM
great graphic card Shaun Products 0 November 14th 04 12:43 AM
graphic card for sale Shaun Aviation Marketplace 0 November 14th 04 12:42 AM
Radeon Graphic drivers for laptops Blue Simulators 0 October 31st 03 08:25 AM
