#21
The FAA cannot dictate where you will annual an airplane. And yes, you can get a ferry permit to fly coast to coast if neccessary.
On May 6, 7:19*am, Newps wrote:
4 hours of wrench turning just to get at a part? * Bwaaaaaaahhhhhhhh *I thought my 182 was bad when it took 15 minutes to get both cowl halves off.. Oh, I wasn't considering the cowl. It takes at least 1 hr of labor to drop the cowl and put it back on in a Mooney. That's with a very experienced A&P. It takes me more than an hour just to drop it. Depending on the IA you can sometimes get away with leaving it on and doing the muff inspection with a bunch of mirrors. -Robert |
rotor&wing wrote:
Newps;627949 Wrote: It also depends on how far you want to ferry the plane. 50 or 100 miles then probably no problem. No FSDO is going to give you a ferry permit to go 1000 miles back to your home airport for an annual. They'll just tell you to get the annual locally. The FAA cannot dictate where you will annual an airplane. And yes, you can get a ferry permit to fly coast to coast if neccessary. [/i][/color] Sure they CAN, all they have to do is not issue the ferry permit. And yes most FSDOs will give fairly long distance permits. |
![]() Quote:
The FAA will not withhold a ferry permit "because we want to". As long as an A&P confirms AD's are complied with and signs the logbook as well as the ferry permit the FAA could care less. |
rotor&wing wrote:
The FAA will not withhold a ferry permit "because we want to". As long as an A&P confirms AD's are complied with and signs the logbook as well as the ferry permit the FAA could care less. BS. The FAA can and does withhold a ferry permit so you can get an annual 1000 miles away. There's no reason to issue a ferry permit for an annual that far away. Get it done closer. You have no inherent right to have your plane annualled at a certain location. One location is as good as the next. |
![]() Quote:
Go ahead and believe what you want, but it's simply not true. BTW, years ago I picked up an Aztec in Arizona (out of annual) and ferried it (on a ferry permit) to Tennessee. [/quote]You have no inherent right to have your plane annualled at a certain location. One location is as good as the next.[/quote] You have a right to take your airplane anywhere you want. Once again, please provide the reference to back up such an inane remark. Last edited by rotor&wing : May 10th 08 at 01:12 PM. |
![]() wrote in message ... So, If I read that right, the annual for a privately- registered aircraft must take place by the last day of the 12th month following the last inspection. Therefore, an annual that last occurred on, say, 12th May '07 must next be done by 31 May '08. Right? Maybe the FARs have something similar. Most time intervals specified by the FAA work that way, they expire at the end of the month. If you play your cars right and are systematic, you can legally get an annual every 13 months. Generally, you have your mechanic start your annual early and then "finish" it (sign it off) on the first day of the month after your current annual expires. Vaughn Dan |
#28
Vaughn Simon wrote:
Generally, you have your mechanic start your annual early and then "finish" it (sign it off) on the first day of the month after your current annual expires. Or use the 13 month loophole to rotate the annual to a spot on the calendar that is convenient for you. I get mine to February or March for that reason. |
#29
I had to get a mechanic to inspect my Seneca prior to the issuance of a
ferry permit. In addition, the 100 hr rear seat retention mechanism AD had to be complied with. PLUS, when I took the logbooks over to the FSDO office, they noticed that AD on my Seneca 1's turbochargers was never signed off, and I had to get the mechanic to attest that my plane didn't have turbochargers (as if I didn't know ![]() that the AD applied to the turbochargers and not the airframe. (Several FAA approved shops still insisted that the AD didn't apply ,but nonetheless, I got the sign-off) In short, make it your business to get an annual done before expiration date. "Peter Clark" wrote in message ... On Mon, 05 May 2008 22:06:24 +0800, Stealth Pilot wrote: On Sun, 04 May 2008 12:22:42 -0400, Peter Clark wrote: On Sun, 4 May 2008 08:48:01 -0700 (PDT), Larry wrote: The ferry permit is basically a formality. The A&P gets one, signs off that the aircraft is safe to move, and hands it to you to go get the aircraft. Takes about 1/2 hour to arrange assuming the guy from the FSDO is near his desk. actually the thing about a ferry permit is that the pilot is the one who determins whether the aircraft is flyable, the permit is basically an own recognisance waiver to fly an "unairworthy" aircraft. unless you yanks do it differently than in australia the A&P's opinion doesnt come into it. Stealth Pilot I guess it's another FSDO bizzarity. "§ 21.199 Issue of special flight permits. (a) Except as provided in §21.197(c), an applicant for a special flight permit must submit a statement in a form and manner prescribed by the Administrator, indicating- (1) The purpose of the flight. (2) The proposed itinerary. (3) The crew required to operate the aircraft and its equipment, e.g., pilot, co-pilot, navigator, etc. (4) The ways, if any, in which the aircraft does not comply with the applicable airworthiness requirements. (5) Any restriction the applicant considers necessary for safe operation of the aircraft. (6) Any other information considered necessary by the Administrator for the purpose of prescribing operating limitations. (b) The Administrator may make, or require the applicant to make appropriate inspections or tests necessary for safety." I guess under paragraph B the FSDO here made me get a mechanic to sign a box saying it was safe to move for the annual. |
#30
On Sat, 10 May 2008 16:52:50 -0400, "tom418"
wrote: I had to get a mechanic to inspect my Seneca prior to the issuance of a ferry permit. In addition, the 100 hr rear seat retention mechanism AD had to be complied with. PLUS, when I took the logbooks over to the FSDO office, Why'd you do that? they noticed that AD on my Seneca 1's turbochargers was never signed off, and I had to get the mechanic to attest that my plane didn't have turbochargers (as if I didn't know ![]() that the AD applied to the turbochargers and not the airframe. (Several FAA approved shops still insisted that the AD didn't apply ,but nonetheless, I got the sign-off) My last 5 annuals were late. I called the FSDO, they sent me the papers, (I don't have a fax machine), My mechanic said, "looks OK, signed it, and I flew it to the other airport for the annual. There was no inspection of logs, or anything else by the FSDO. By the time they received the paperwork the annual was already complete. Roger (K8RI) ARRL Life Member N833R (World's oldest Debonair) www.rogerhalstead.com |
old days | Airman | Rotorcraft | 23 | January 2nd 07 01:36 PM |
60 Days for Calibration | [email protected] | Soaring | 7 | May 1st 06 03:00 AM |
Days as a hanger rat | Jack Allison | Owning | 33 | May 12th 05 03:01 AM |
Just a few more days | Louis L. Perley III | Owning | 1 | December 31st 04 01:36 PM |
Two bad days... | Yeff | Military Aviation | 0 | July 3rd 04 09:31 PM |
