Jet turbine starting equipment ?
Old May 9th 08, 09:30 PM posted to rec.aviation.piloting
Externet
Default Jet turbine starting equipment ?
Hi. Could not find a proper group to ask, sorry :
The old Boeing 707 and perhaps others had a tiny 3000+ psi air
compressor on board driven by a hydraulic motor to start engines with
NO ground equipment assist.
Which current aircraft have a similar compressed air starting system
on board ?
Thanks.
Old May 9th 08, 11:44 PM posted to rec.aviation.piloting
Mxsmanic
Externet writes:
What drove the hydraulic motor?
Old May 10th 08, 12:11 AM posted to rec.aviation.piloting
F. Baum
The Transfunctioner G. Transport jets use both engine driven and
electric hydraulic pumps. I have never started a jet with compressed
air. Have you BTB ?
Frank
Old May 10th 08, 01:40 AM posted to rec.aviation.piloting
Morgans[_2_]
"Robert Moore" wrote
I have done numerous "high pressure" starts in the old B-707. The air
compressor filled a "high pressure tank" and the tank then was sufficient
to start just one engine. After that, that engine's bleed air was used to
start the remaining engines.
Did the 707 not have an onboard APU?
Jim in NC
Old May 10th 08, 02:00 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
"Morgans" wrote in
sufficient to start just one engine. After that, that engine's bleed
air was used to start the remaining engines.
Some did. Most not.
Bertie
Old May 10th 08, 02:59 AM posted to rec.aviation.piloting
Robert Moore wrote in
46.128:
None in regular airline service. I have seen a couple of
707s converted to corporate service where the forward cargo
hold was converted to hold a retractable APU that was pulled
outside the cargo door for engine starts and then shut-down
and stowed away.
I've een told, but haven't seen, that some have the 727 type installation.
Bertie
Old May 10th 08, 03:19 AM posted to rec.aviation.piloting
F. Baum
and stowed away.
Bertie
I understand the 727 was originaly designed without an APU and they
squeezed one into the wheel well. This was the main reason it couldnt
be used inflight. This was from a systems instructor who had alot of
folklore on the 727 (Including the picture of 30 or so people hanging
on the airstair inflight during the fall of Siagon).
FB
Old May 10th 08, 03:48 AM posted to rec.aviation.piloting
"F. Baum" wrote in
and stowed away.
installation.
Bertie
Could be. I only flew th e200 and they all had them. Of course, you
didn't really need one in flight anyway. There were plenty of electrics
available from the three engines anyway.
Bertie
MINI 500, Rinke, Turbine, Helicopter for sale, Helicopter, Revolution, Turbine Power TurbineMini Richard Rotorcraft 2 January 28th 09 07:50 PM
An-2 starting Jaroslaw Manek Aviation Photos 0 May 27th 07 08:30 PM
Starting at the right age Photoplasm Aviation Photos 4 April 24th 07 08:37 PM
Turbine Duke or turbine Baron? Montblack Piloting 1 December 13th 05 04:54 PM
Turbine Duke or turbine Baron? [email protected] Piloting 26 December 13th 05 07:50 AM
