#41
Dudley Henriques wrote:
Mxsmanic wrote: Dudley Henriques writes: Not a moment's hesitation.......An angle of attack indicator. I can understand that. Why are angle-of-attack indicators so rare in aircraft? Is it something that is difficult to measure? I should think it would be far more useful than trying to figure out what combination of speed, weight, pitch angle, etc., is likely to produce a stall. You are absolutely correct. The military for years has used AOA to determine cruise, climb, descent, and approach speeds. Almost all high performance aircraft performance charts use AOA to determine performance criteria. For example, a T38 is flown on approach at an optimum AOA of .6 units. This optimizes the aircraft at whatever approach airspeed the GW dictates. (remaining fuel). The aircraft can also be flown manually on approach using an IAS of 155kts plus fuel, which is an additional 1kt for every l00lbs remaining over 1000lbs. You can fly the approach either way but as you can see, it's a lot easier using AOA. Some T38's BTW, incorporate an AOA indexer on the glare shield that will automatically keep you on speed if you fly the airplane in the on speed green "donut". The top of the indexer is a red chevron pointing downward to indicate you're too slow on the approach. The bottom is a red chevron pointing upward showing too high an airspeed. Keeping the airplane right on speed in the green donut gives you .6 units AOA regardless of the gross weight of the airplane. To expand just a bit on the T38, the AOA indicator shows up as arbitrary "units" ranging from 0 to 1.0 based on the angle range of the AOA vane. Some other helpful data supplied by the AOA indicator if I remember right for the Talon is a maximum range at about .2 units, and a maximum endurance at .3 units. Initial stall buffet is t about .9 units. In light civilian airplanes, AOA indicators can be quite useful although the low speeds involved don't necessarily produce the same advantages found in much higher performance airplanes where the slightest difference between optimum and off optimum AOA for a specific configuration can mean big differences in performance. Personally, I like the idea of basing even light airplane performance on AOA. If this format is begun at the manufacturer's level and proper testing on the aircraft done at that point, the end user has a simple and precise instrument on which to base the aircraft's performance. This decreases cockpit workload which is a good thing in itself. It is my understanding after talking to some ATR (ATP) friends of mine flying for major air carriers that their companies have been engaged with manufacturers on better ways to use AOA in their aircraft operations. Correction on the indexer. The lower chevron should read yellow and not red. -- Dudley Henriques |
#42
#43
On May 15, 4:16*pm, Dudley Henriques wrote:
I gave up years ago trying to figure out why things that make flying safer and better are not made standard. :-))) AOA indication has always as far as I know been considered an option on light civilian aircraft. There are costs involved as well as performance testing to determine optimum parameters....another step in the process. The main reason I believe is the fact that light civilian airplanes fly in the area of lowest performance where the raw data already existing using basic instrumentation is sufficient. They're somewhat more common on experimentals (i.e., homebuilts), and I agree, I wish I had one on even my lowly Cherokee. |
#44
For plain vanilla flying, D, (point to point in an M20J) what
improvement might we expect using aoa instead of what we use now in takeoff, cruise, or landing phases? I can appreciate aoa's utility in higher performance a/c, or maybe when flying close to some edge, but am not sure how it would improve, for example, our take off (best rate for the first few hundred feet, that's less than 30 seconds of flying) , then a prudent cruise climb to our en route altitude. En route, usually as high as possible consistent with the trip length and winds, we go to the lowest rpm we can, and maintain the same ias going lower until approaching the OM. |
#45
Benjamin Dover wrote:
Shirl wrote in news:Xmnushal8y- : Isn't "Pee - take" on every pilot's pre-flight check list? Dunno 'bout you but I tend to "Pee- Leave" Unless I'm in need of some ballast. Ya know, we glider guys already have this stuff figgered out. I learned the hard way that if the guy above you opens the gear doors while on cruise... : ) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200805/1 |
#46
HARRY POTTER wrote:
Mxsmanic wrote: Dudley Henriques writes: Not a moment's hesitation.......An angle of attack indicator. I can understand that. Why are angle-of-attack indicators so rare in aircraft? Is it something that is difficult to measure? I should think it would be far more useful than trying to figure out what combination of speed, weight, pitch angle, etc., is likely to produce a stall. It's my understanding that AOA indicators are not on most singles because there is no place to put it. The prop creates circling air currents all through the fuselage, making any kind of AOA indication incorrect. You can't put it on the wing, because whenever you banked the aircraft, the AOA would move. This makes me wonder, do high performance aerobatic singles, like the Extra 300 have AOA's? If so, how? Out on the wing is where most singles have them. http://www.aircraftspruce.com/menus/...ndicators.html Dynon who has the indicator built into their EFIS puts the probe out on the pitot tube. http://dynonavionics.com/docs/D180_Feature_AOA.html |
#47
On May 16, 9:11 am, Gig 601Xl Builder
wrote: HARRY POTTER wrote: Mxsmanic wrote: Dudley Henriques writes: Not a moment's hesitation.......An angle of attack indicator. I can understand that. Why are angle-of-attack indicators so rare in aircraft? Is it something that is difficult to measure? I should think it would be far more useful than trying to figure out what combination of speed, weight, pitch angle, etc., is likely to produce a stall. It's my understanding that AOA indicators are not on most singles because there is no place to put it. The prop creates circling air currents all through the fuselage, making any kind of AOA indication incorrect. You can't put it on the wing, because whenever you banked the aircraft, the AOA would move. This makes me wonder, do high performance aerobatic singles, like the Extra 300 have AOA's? If so, how? Out on the wing is where most singles have them. http://www.aircraftspruce.com/menus/...ndicators.html Dynon who has the indicator built into their EFIS puts the probe out on the pitot tube. http://dynonavionics.com/docs/D180_Feature_AOA.html An AoA is an interesting instrument. For me (in a sim with a customized AoA indicator), I had difficulty due to information overload, probably because I rely on my Attitude indicator, IAS, Rate of Descent and Altimeter, with an ear alert for a stall buzzer. On top of that, (in real flying), is radio, traffic, weather such as cross-winds, flap settings, RPM, seat belt, mooses on the runway bla-bla-bla. All those instruments need to jive and are vital to make a safe landing. I've tried using modified instrument panels with some limited success gauged subjectively, but an AoA was a "recreational instrument", fun to watch during stalls. Ken |
#48
Tina wrote:
For plain vanilla flying, D, (point to point in an M20J) what improvement might we expect using aoa instead of what we use now in takeoff, cruise, or landing phases? I can appreciate aoa's utility in higher performance a/c, or maybe when flying close to some edge, but am not sure how it would improve, for example, our take off (best rate for the first few hundred feet, that's less than 30 seconds of flying) , then a prudent cruise climb to our en route altitude. En route, usually as high as possible consistent with the trip length and winds, we go to the lowest rpm we can, and maintain the same ias going lower until approaching the OM. Generally, even in high performance airplanes, you don't reference AOA on takeoff during rotation. If the airplane, (any airplane) has been tested and charted for optimum climb AOA, you could set that up after rotation for best rate for example. The bottom line for light airplanes concerning AOA is that if it's available, it can optimize performance for you referencing one instrument. You can of course, as you have correctly noted, accomplish these things manually as well. I'm simply used to using AOA for various performance references so it's normal for me to think in these terms. For most pilots in light airplanes, using AOA would simply be another option. -- Dudley Henriques |
#49
HARRY POTTER wrote:
Mxsmanic wrote: Dudley Henriques writes: Not a moment's hesitation.......An angle of attack indicator. I can understand that. Why are angle-of-attack indicators so rare in aircraft? Is it something that is difficult to measure? I should think it would be far more useful than trying to figure out what combination of speed, weight, pitch angle, etc., is likely to produce a stall. It's my understanding that AOA indicators are not on most singles because there is no place to put it. The prop creates circling air currents all through the fuselage, making any kind of AOA indication incorrect. You can't put it on the wing, because whenever you banked the aircraft, the AOA would move. This makes me wonder, do high performance aerobatic singles, like the Extra 300 have AOA's? If so, how? It's true the port should be placed in an area of undisturbed airflow. This is usually out on the wing upper surface somewhere near the leading edge but will vary from type to type. Thus placed, prop circulation shouldn't be an issue. Can't say I've seen an Extra with an AOA system, but there's no reason at all the aircraft shouldn't have one if the owner so desired as far as I can see. -- Dudley Henriques |
#50
On May 16, 12:14 pm, Dudley Henriques wrote:
HARRY POTTER wrote: Mxsmanic wrote: Dudley Henriques writes: Not a moment's hesitation.......An angle of attack indicator. I can understand that. Why are angle-of-attack indicators so rare in aircraft? Is it something that is difficult to measure? I should think it would be far more useful than trying to figure out what combination of speed, weight, pitch angle, etc., is likely to produce a stall. It's my understanding that AOA indicators are not on most singles because there is no place to put it. The prop creates circling air currents all through the fuselage, making any kind of AOA indication incorrect. You can't put it on the wing, because whenever you banked the aircraft, the AOA would move. This makes me wonder, do high performance aerobatic singles, like the Extra 300 have AOA's? If so, how? It's true the port should be placed in an area of undisturbed airflow. This is usually out on the wing upper surface somewhere near the leading edge but will vary from type to type. Thus placed, prop circulation shouldn't be an issue. Can't say I've seen an Extra with an AOA system, but there's no reason at all the aircraft shouldn't have one if the owner so desired as far as I can see. Dudley Henriques What an SOB like myself would do flying a low wing monoplane is tape fluff on the the upper surface to observe turbulence variation over wing's lifting surface. Maybe not the AoA you want, but it's a proportional effect, and easy to see at a glance. That's SOP filmed using X-craft during maneuvers. Ken |
Favorite Airlines | Kloudy via AviationKB.com | Piloting | 0 | May 7th 08 06:20 PM |
density altitude calculator and wind calculator on web site and asGoogle gadget | Howie | Piloting | 3 | August 5th 07 11:52 PM |
density altitude calculator and wind calculator on web site and asGoogle gadget | virtuPIC[_2_] | General Aviation | 0 | August 4th 07 05:55 PM |
Favorite picture of my favorite airplane. | russell[_2_] | Aviation Photos | 3 | August 4th 07 04:39 PM |
Weather gadget | Bill Daniels | Soaring | 1 | November 19th 03 03:38 PM |
