rudder pedal springs
Old May 17th 08, 02:48 AM posted to rec.aviation.homebuilt
Dick[_1_]
Default rudder pedal springs
a fellow kind of remembered there was an alternative to springs between the
firewall and each rudder pedal for keeping tension on the rudder cables.
Thought something about 2 pullies...
anybody know about this?
Thanks, Dick
Old May 17th 08, 08:26 AM posted to rec.aviation.homebuilt
Philippe[_2_]
between the firewall and each rudder pedal for keeping tension on the
rudder cables. Thought something about 2 pullies...
And one cable, two nicopress abd two AN100 cable thimbles.
by
Volem rien foutre al païs!
Philippe Vessaire Ò¿Ó¬
** Posted from http://www.teranews.com **
Old May 17th 08, 12:50 PM posted to rec.aviation.homebuilt
Dick[_1_]
He remembered some concern over the pullies needing to be mounted loosely
enough to accommodate a pedal being pushed forward without having the cable
come out of the sheave...
I can't get my head around a good way to accomplish this?
"Philippe" wrote in message
news:2698813.KXLH25hIIj@GastonCoute...
by
Old May 20th 08, 02:36 AM posted to rec.aviation.homebuilt
With two springs. Lighter, cheaper, self-adjusting.
Dan
Old May 20th 08, 05:11 AM posted to rec.aviation.homebuilt
Drew Dalgleish
On Mon, 19 May 2008 22:30:50 -0400, Ernest Christley
Dan
If one spring breaks, the other will pull the rudder to one side.
http://www.ronpaultimeline.com
Only if the pilot has no feet. I have 2 springs on my right rudder and
1 spring on the left. It still takes a little right rudder to keep the
ball centred at cruise but I'm not worried about any or all springs
breaking. Dan's right the springs can be eliminated with a cable,
turnbuckle, swages, thimbles, pulleys, brackets, etc. I fail to see
what the gain is over a nice light self adjusting system is.
Old May 20th 08, 08:23 PM posted to rec.aviation.homebuilt
Yup. Just as it does in a Cessna 150 or 172 or any one of
dozens of other airplanes. The pilot will notice it, will have to keep
constant pressure on one pedal, and will snag it after he lands if he
has any sense at all. There have been pilots on the RAP group who
complain that the local rental clunker needs constant right or left
pedal pressure to keep the ball anywhere near centered. That airplane
will most likely have a busted spring. Most likely the left spring,
since it's the one that gets stretched the most often and for the
longest time: right rudder on takeoff and climb stretches the left
spring.
Dan
VNAV placard in DA-40, and pedal adjustment? Roy Smith Owning 4 January 14th 07 05:23 AM
Need Grob 103 Twin II left front rudder pedal Mike McCarron Soaring 1 May 15th 06 03:16 PM
Piper Rudder Pedal Pads Mike Spera Owning 1 November 4th 05 04:31 AM
flew an R22 today for the first time, hover and pedal turns were easy! Heli-Chair Rotorcraft 15 May 19th 05 02:02 AM
ASA OnTop 8 Pedal Problem Kevin Instrument Flight Rules 1 August 21st 03 06:42 PM
