Mylar seals for elevator
Old May 18th 08, 09:00 PM posted to rec.aviation.soaring
Default Mylar seals for elevator
Hey guys, what's your opinion on the use of mylar seals at the
horizontal stab/elevator gap? Specifically for LS ships. Do people opt
not to use them for fear of "lifting" tape or mylar and causing
elevator effectiveness issues? Losing elevator effectiveness is
certainly a valid concern, but does it warrant not using mylar seals
there altogether?
Thanks,
Dave
Old May 18th 08, 09:45 PM posted to rec.aviation.soaring
JJ Sinclair
Dave,
I recommend using mylar on all control surfaces and have added it to
the LS-3/4/6/7/8 without a problem. I sand the inside of the mylar
where the stickie will go with 220 and do the same to the horizontal
(just the 10mm area), then wipe both down with acetone before laying
down the stickie and mylar. Next, roll it down with considerable
pressure to insure a good bond, followed by the transition tape over
the leading edge of the mylar. Some have had mylar come loose because
they didn't do the above and or didn't remove all wax from the
affected area. Treat this with the respect it deserves, or take it to
a glider repair shop. We have had a bail-out caused by lifting mylar
on the stab.
JJ
there altogether?
Thanks,
Dave
Old May 18th 08, 11:12 PM posted to rec.aviation.soaring
On May 18, 3:45*pm, JJ Sinclair wrote:
Dave,
on the stab.
JJ
there altogether?
Thanks,
Dave- Hide quoted text -
- Show quoted text -
Here's the text from the flight manual for my ship (LS1f): "Taping of
upper aileron and elevator gaps, as well as the fuselage wing
connection, is necessary for rudder effectiveness and performance."
How do you interpret that? Are they recommending the equivalent of
mylar seals? Only on the top?
Old May 18th 08, 11:31 PM posted to rec.aviation.soaring
Eric Greenwell
JJ Sinclair wrote:
Dave,
I've always used the mylar with the adhesive already in place (I'm
curious why JJ doesn't). That's a lot easier, and one less thing to go
wrong, since you don't have to worry about contaminating the mylar
surface and getting a bad bond. I've never had the adhesive separate
from the mylar, though I've had problems with the adhesive not making a
good bond everywhere on the glider. That was due to poor preparation,
probably not enough sanding.
on the stab.
Add "mylar and tape inspection" to your preflight: look for unbonded
spots and safety/transition tape thats brittle, peeling, or loosens
easily when you pick at it. It's easy to replace if you do it every year
or two, before it begins to deteriorate. The top side goes bad first.
* Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4
* New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more
Old May 18th 08, 11:42 PM posted to rec.aviation.soaring
Maybe I should have mentioned. I have mylars on all surfaces. I did
them last season using all the specified procedures; wax removal,
scuffing/sanding, pressure applied with roller, sately tape, etc. They
are well bonded and in perfect shape. The real question here is
whether to remove the mylar on the elevator as a precaution.
I also inspect them thoroughly every time I rig.
Old May 19th 08, 01:23 AM posted to rec.aviation.soaring
Bob Kuykendall
curious why JJ doesn't)...
I've seen that stuff. Whoever puts it together doesn't sand the
underside of the mylar as JJ suggests. Your call.
Thanks, Bob K.
Old May 19th 08, 08:14 AM posted to rec.aviation.soaring
Bert Willing[_2_]
.. The real question here is
The answer is definitively no.
Old May 19th 08, 02:09 PM posted to rec.aviation.soaring
JJ Sinclair
Hi Eric,
I used some Mylar provided by the factory with adhesive already in
place on the flaps on an ASW-20 and the heat inside the trailer caused
the mylar to peal off between the mylar and the adhesive. The Mylar
was slick and had not been roughened up. This brings up another point,
recommend control locks on control surfaces while in the trailer,
especially flaps that won't otherwise stay in neutral.
I believe the main purpose of adding Mylar is to reduce drag, but if
you want added control authority, one can think about the combination
of Mylar and zig-zag. I use it on most rudders, but be careful adding
zig-zag to the elevator. I did on my LS-7 and the stall was the mose
abrupt I have ever seen..................took off the zig-zag!
Cheers,
JJ
Old May 19th 08, 03:53 PM posted to rec.aviation.soaring
noel.wade
I'm arguably the least experienced pilot on this thread, so I'll try
to tread respectfully - but I was under the impression that mylars are
placed over control gaps for three reasons:
1) To prevent (or at least reduce) high pressure air below the wing
from being sucked up through the control gap to the low-pressure air
on top, disturbing or separating the airflow right at the control
surface. If designed to flow properly, such airflow can be beneficial
in certain flight regimes (see "slotted flap") - but for glider
control surfaces its bad news.
2) To lessen the drag as the low-pressure air goes down the top
surface through the pressure-recovery zone and hits a big lip or gap
or sharp angle that might cause the air to separate, tumble, swirl,
etc. In other words, the mylar helps smooth the transition between
the wing and the control surface no matter what angle the control
surface is at (relative to the rest of the wing).
Take care,
--Noel
Old May 19th 08, 06:09 PM posted to rec.aviation.soaring
kirk.stant
Not primarily - seals are used for that. Either tape (for top or
bottom hinged) or rolling seals (for center-hinged) control surfaces.
Mylar without seals will probably slow the crossflow, but probably not
completely stop it. My LS6 manual specifically shows how and where to
install both rolling seals and Mylar gap covers on all control
surfaces.
Mylar without the rolling seals made my LS6 sound like an RC airplane
at full throttle at about 130 knots - I figure the crossflow was
"buzzing" the mylar on the flaperons. Could turn it on or off within
a couple of knots. Made sneaky low passes a bit difficult! Quickly
fixed by properly installing seals, BTW!
etc. *In other words, the mylar helps smooth the transition between
What was #3? ;)
Cheers,
Kirk
Mylar seals for PIK20D culverflyer Soaring 5 May 19th 04 06:25 PM
Mylar seals installation John W Soaring 2 May 5th 04 09:03 PM
mylar seals wing to flap/ Aileron culverflyer Soaring 2 May 5th 04 02:52 PM
ZZ Mylar seals Mike Soaring 3 March 29th 04 03:45 PM
mylar seals D.A.L Soaring 1 February 23rd 04 07:15 PM
