I give up, after many, many years!
Old May 18th 08, 11:48 PM posted to rec.aviation.piloting,rec.aviation.student
Bertie the Bunyip[_25_]
Default I give up, after many, many years!
"Jay Honeck" wrote in
news:jgVXj.115081$TT4.973@attbi_s22:
Your point that seat of the pants pressure sensations are used during
instrument flight does not disprove MX's point about the necessity of
relying primarily on your instruments for accurate information in
IMC.
Actually my point does!
The fly by the seat of my pants did not feel like I had a 20 to 30
degree pitch up which my horizon indicator showed (which was
waaaaaaaaay more then Vx pitch).
Again, you're arguing about a different topic -- flight in IMC without
a vacuum system. This is often classified as an "emergency", and you
must use everything you can to get out of it -- including your "seat
of the pants".
In normal instrument flight, pilots are trained to ignore what their
body is telling them.
No, they aren't, they re trained to ignore their inner ear., period.
Bertie
  #383
Old May 18th 08, 11:50 PM posted to rec.aviation.piloting,rec.aviation.student
news:lMVXj.169277$yE1.70867@attbi_s21:
Third, and most likely alternative: he's just stupid.
MX is many things. Persistent, stubborn, blunt, thick-skinned, willing
to argue that black-eyed-peas are really black-eyed-beans, yes.
Occasionally annoying, often entertaining (mostly because of the
responses he obtains), always willing to come back for more. He's
like a Weebil that won't fall down.
But stupid? I don't think so.
Well, relative to you, of course not.
Bertie
  #384
Old May 18th 08, 11:51 PM posted to rec.aviation.piloting,rec.aviation.student
news:mIVXj.169271$yE1.120501@attbi_s21:
Fortunately, MSFS handles engine
sounds in a fairly consistent and predictable way.
Yep, consistently unrealistic, with no prop noise at all.
The sound quality in MSFS is remarkably good -- in SOME of the
aircraft, and with the proper equipment.
For example, our sim set-up at the hotel has a full surround-sound
system with sub-woofer. When you wind up the Merlin in the P-51, it
sings. When you pull it back to idle, you can hear wind noise. When
you kill the engine, you can hear the prop windmilling.
And the rumble of the big radial engines in the Grumman Goose is
wonderfully done.
An indication of the importance of sound in the sim -- it's MUCH
harder to fly the sim with the sound turned off. You don't realize
how often you use aural cues in flight until they're not there.
(Which, BTW, makes me really admire the deaf pilots of the world.
Back before the troll wars reduced this group, there used to be a
regular poster here named Henry Kisor who belonged to the deaf pilot's
association, and I was always impressed that he was able to fly so
well without aural cues. But I digress...)
Of course, if you're relying on your desktop computer's speaker,
you're absolutely correct -- the sounds are not there. But the sim
software *is* creating the proper sounds, mostly, but it does require
a good quality system to hear it.
Bull****.
Bertie
  #386
Old May 19th 08, 03:40 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Bertie the Bunyip writes:
And i fly instruments almost every day.
How do you fly instruments that don't work?
  #387
Old May 19th 08, 04:08 AM posted to rec.aviation.piloting,rec.aviation.student
Dave Doe
says...
writes:
Airliners us FULL MOTION sims, not a desktop MSFS. HUGE difference.
One of the reasons why full-motion sims work is that it's very easy to fool
human senses. Remember, full-motion sims don't actually go anywhere, but to
the people inside, they certainly feel as though they do.
To equate a desktop MSFS to any type of IMC flying is reckless IMHO.
One advantage to MSFS is that it forces you to use instruments in IMC.
Depending heavily on instruments isn't necessarily an advantage for VFR, but
it's very important for IFR.
To not depend on senses and totally rely on instruments without an
expectation that **they could fail** is reckless.
Not at all. If you're unwilling to put complete trust in your instruments,
you shouldn't be flying IFR. If they fail, well, you might never get back
home.
If you fly a real
plane, you should know this. Nobody expects the unexpected to happen,
but if you fly your plane like **it could happen** then you are better
prepared. I call it an insurance policy that you hope you don't have
to cash in.
Given the fact that losing instruments in IMC is extraordinarily dangerous, it
would be better advised to take care to minimize the chances that they will
fail than to fantasize that it will be possible to fly and land safely without
them if they do fail.
Who remembers the crash in the States where an aircraft engineer had
left the pitot and or static air vents taped up.
Crashed into the sea I think - all dead.
Basically - pilots failed to correctly interpret the instruments. Had
they determined what insruments were reading correctly, they could've
put the thing down (they were attempting to return to the field).
IIRC, they could have used the GPS for airspeed (IIRC, the airspeed
indicator partly worked (they got an airspeed active out of it!) - and
probably thought it was correct - during flight it was all over the
place IIRC. And the radar altimeter would have been working just fine.
Several navs would have been good, VOR, DME, ILS etc. Shaker of course
too!
Anyone remember some more details?
Duncan
  #389
Old May 19th 08, 04:18 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Dave Doe writes:
too!
The GPS would only give ground speed, not airspeed, but that would be better
than nothing. The RA would only be useful below 2500 feet AGL. But the other
stuff would be working.
Aeroperu had a problem with this.
  #390
Old May 19th 08, 04:19 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Dave Doe writes:
You can't make such a basic statement like that. You *need* to say yer
straight and level.
Satisfied?
DC-3 parts to give away Robert Little Restoration 2 November 23rd 06 03:30 AM
Who can give a checkout? Mark S Conway General Aviation 2 May 9th 05 12:15 AM
Winch give-away KP Soaring 6 January 11th 05 08:04 PM
Did you ever give up on an IR? No Such User Piloting 24 November 26th 03 02:45 PM
FS 2004 give away Ozzie M Simulators 0 November 23rd 03 03:50 PM
