Diesel in a homebuilt?
Old May 20th 08, 03:42 PM posted to rec.aviation.homebuilt
Peter Dohm
Default Diesel in a homebuilt?
"Morgans" wrote in message
news
One thing that everyone should keep in mind, is that automotive diesels
run on diesel fuel, and everyone wanting diesel engines for their
airplanes is going to want to use jet fuel.
Jet fuel does not have the good lubricating properties that diesel fuel
has, and may tend to wear out the automotive fuel pumps in short order.
I read somewhere that Thielert spent half of what they spent on
modifications to the engine, in designing a fuel pump that would be
durable enough.
Something to keep in mind.
Jim in NC
As of a few months ago, lubricity was a very serious problem in Ultra Low
Sulpher Diesel fuel, because the quickly implemented refining process tended
to strip most of the lubricants from the fuel. I have no idea whether that
caused it to have better, or worse, lubricity than Jet-A, but there are a
couple of high pressure lubricants offered specifically to solve the
problem--plus some "home brew" fixes.
BTW, the solution mentioned elsewhere in this thread is new to me; but
diesel airport vehicles have run on Jet-A as long as I can recall and AFAIK
all of the military Hummers are specified as diesel.
Comments???
Peter
Old May 20th 08, 04:49 PM posted to rec.aviation.homebuilt
jan olieslagers[_2_]
stol schreef:
they are able to purchase 10,000 gallons of jet at about half the cost of diesel
????!!!! In what part of the world is Jet A1 cheaper than (uncoloured)
diesel ????
Old May 20th 08, 09:15 PM posted to rec.aviation.homebuilt
Lou
On May 20, 10:49 am, jan olieslagers
diesel ????
Wow, I'm learning a lot.
Lou
Old May 21st 08, 12:28 AM posted to rec.aviation.homebuilt
stol
On May 20, 9:49*am, jan olieslagers
diesel ????
The USA ..............
Old May 21st 08, 01:05 AM posted to rec.aviation.homebuilt
Jim Logajan
cost of
diesel
(uncoloured) diesel ????
In what year? ;-)
The facts, as best I can find:
Airnav provides an average retail price for Jet-A on a per state basis:
http://www.airnav.com/fuel/greatdeals/pocket?type=A
National average for Jet-A appears to be around $5.25/gal or so.
The U.S. DOE provides an average retail price for diesel on a regional and
national basis:
http://tonto.eia.doe.gov/oog/info/wohdp/diesel.asp
National average for diesel appears to be around $4.74/gal or so.
Of course that is retail price. No clue on wholesale. Still, Jet-A appears
to be more expensive at retail so I'd be surprised if wholesale prices for
for both would invert that relationship to the extent claimed. Not
impossible, just not credible absent supporting material.
Old May 21st 08, 02:09 AM posted to rec.aviation.homebuilt
On May 20, 12:08 am, "Morgans" wrote:
"Peter Dohm" wrote
Your location is not obvious from your email. In most of the world,
diesels are available in a wide variety. In the US, where fuel
consumption is only estimated from total mass flow and emission content at
the exhasut, the choices are currently quite limited, and I am really not
very happy with any of the choices. The 2 liter VW (Passat) is an all
iron engine, and about all I know is that it is about 100 pounds heavier
than its gasoline stablemate--which is partially aluminum. There are also
V6 diesels offered in the Mercedes E320 and the Jeep Liberty, but I know
even less about them. There are probably others that I haven't seen, and
Isuzu has said that they will be back in the diesel market when the
regulations have stabilized.
Personally, I really do like the diesel idea--so I plan to take a very
close look if/when any of the lighter small diesels (such as the 2 liter
Mercedes) become available here.
One thing that everyone should keep in mind, is that automotive diesels run
on diesel fuel, and everyone wanting diesel engines for their airplanes is
Jet fuel does not have the good lubricating properties that diesel fuel has,
modifications to the engine, in designing a fuel pump that would be durable
enough.
Jim in NC
Jim in NC
Not I,
And I dare say there are a few other fellows on this board who are
looking at SVO, Biodiesel, and Ethanol as practical alternatives.
Ethanols lower energy density means you have to carry more of it, but
since it is more resistant to detonation you can run substantially
higher compression ratios. I don't imagine it will be too long before
the bean patch is replanted with corn or rape seed and fuel is boot-
legged right on the tarmac.
In central and south america ethanol has been in aviation use for a
while. Biodiesel has better temperature tolerances than SVO, but it
still isn't serviceable without additional engineering due to gelling.
Given that is the case, there is basically no gain from using
biodiesel over SVO so personally, I think SVO is the way to go. It has
better energy density than ethanol, the flip side of course is that it
has a very high and variable gel temperature. But an engine designs
specifically for SVO _can_ design around this problems, and would
still accept biodiesel and pump-diesel easily. kerosene.... once in a
while. But not recommended.
Germany has a national fuel standard for SVO, and Elsbett has done
extensive work in solving injector coking problems associated with
SVO. So with SVO the engine is heavier, but offset by lower fuel
load, and a slightly shorter TBO, but given the price of 100LL, the
shorter TBO is offset by the fuel savings. Fuel availability would
actually be easier logistically speaking than the current system, once
it is adopted.
The only issue, is that the _only_ company to design an engine
specifically for SVO at this point is Elsbett. There are dozens of
kludges being sold for cars, but no ground-up designs. Funny that
people go to all the trouble of innovating a new engine, and don't
innovate where the fuel is concerned.
-Matt
Old May 21st 08, 02:22 AM posted to rec.aviation.homebuilt
clare at snyder dot ontario dot canada
On Tue, 20 May 2008 15:49:09 +0000, jan olieslagers
diesel ????
Stale dated jet A is often available at a discount.Apparently.
** Posted from http://www.teranews.com **
  #28
Old May 21st 08, 11:40 AM posted to rec.aviation.homebuilt
Philippe[_2_]
Lou wrote:
Not that I plan to do this but I was wondering, if one was going to
plan to install a diesel in a homebuilt, what diesel would one put
in?
Diesel, yes but automotive conversion are at the heavy side.
Some homebuilt wilksch equiped are in progress in France. I know one
Murphy Rebel.
Smaller, the GazAile II but you can't find the small engine outside of
Europe.
Delta hawk V4 if you want bigger is the alternate choice.
Volem rien foutre al païs!
Philippe Vessaire Ò¿Ó¬
  #29
Old May 23rd 08, 02:43 PM posted to rec.aviation.homebuilt
Bill Daniels
"Lou" wrote in message
in?
Lou
FWIW, I'm heading down to the hangar this morning to work on a 10 liter
Cummins 360HP 2100RPM aviation turbo diesel. Of course, we leave the
engine on the ground while using it to launch gliders.
Diesel Jodel information..........and .........diesel plane groups Roland M General Aviation 1 January 4th 04 04:04 AM
Diesel Jodel information..........and .........diesel plane groups Roland M Owning 1 January 4th 04 04:04 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M General Aviation 2 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Rotorcraft 2 September 13th 03 12:44 AM
