#281
On Thu, 22 May 2008 10:52:15 -0500, Michael Ash wrote:
In rec.aviation.student Gig 601Xl Builder wrote: Mxsmanic wrote: Stealth Pilot writes: aeroplanes fly because of lift generated by pressure differences on the wing surfaces. Airplanes fly because the wings divert the air through which they pass downwards, creating a downwash and exerting a force in doing so that engenders an opposite force that is lift. ... these pressure differences are caused by the shape of the aerofoil of the wing ... The air is diverted because the wing has a positve angle of attack. It can be perfectly flat and it will still generate lift. If that were the case a 747 would have to be producing over 250,000 pounds of force straight down. Why then am I not crushed when a 747 flies over me? At sea level the atmosphere pushes down with about 14.7 pounds of force for every square inch of exposed surface. On the average man, this works out to about 43,000 pounds, all the time. Why aren't your crushed by this? Because I eat beans? |
#282
#283
BDS writes:
I agree that a flat wing will produce lift at a positive AOA even without an airfoil shape - it just won't be as efficient as it would otherwise be if it were shaped like an airfoil, and talk about pitch divergent... Non-flat airfoil shapes help to increase the range of usable AOAs and reduce drag, but a positive AOA is still required to generate lift. Oh yeah, the article also pretty much discounts Bernoulli as having anything to do with why a wing produces lift. It is a common misconception. |
#284
downwash occurs after the wing has passed. Downwash is the result of the wing's passing. The wing accelerates air above it downwards. That downward movement continues after the wing has passed, and it is called downwash. It is the acceleration that produces the downwash that is responsible for lift. |
#285
Gig 601Xl Builder writes:
If that were the case a 747 would have to be producing over 250,000 pounds of force straight down. It does. The downward force is equal to the weight of the aircraft. Why then am I not crushed when a 747 flies over me? Because the entire force is not concentrated on the top of your head. |
#286
Jim Stewart writes:
I'm wondering why the airlines, FAA and the military don't seem to be particularly concerned about this.... It's too difficult to enforce in a culture where this type of substance abuse is an institution. |
#287
Mxsmanic wrote:
Gig 601Xl Builder writes: If that were the case a 747 would have to be producing over 250,000 pounds of force straight down. It does. The downward force is equal to the weight of the aircraft. Why then am I not crushed when a 747 flies over me? Because the entire force is not concentrated on the top of your head. Chuckle for the day :-) -- Dudley Henriques |
#288
Mxsmanic wrote:
Jim Stewart writes: I'm wondering why the airlines, FAA and the military don't seem to be particularly concerned about this.... It's too difficult to enforce in a culture where this type of substance abuse is an institution. Don't fsking quote me out of context. |
#289
#290
Jim Stewart writes:
Don't fsking quote me out of context. I quote as I see fit. |
Apology re mxsmanic | terry | Piloting | 96 | February 16th 08 05:17 PM |
I saw Mxsmanic on TV | Clear Prop | Piloting | 8 | February 14th 07 01:18 AM |
Mxsmanic | gwengler | Piloting | 30 | January 11th 07 03:42 AM |
Getting rid of MXSMANIC | [email protected] | Piloting | 33 | December 8th 06 11:26 PM |
Feeling aircraft sensations | Ramapriya | Piloting | 17 | January 12th 06 10:15 AM |
