#31
#32
On Jun 4, 5:23*pm, ZL wrote:
What's the fundamental difference between the towplane's controls and a properly assembled glider's controls? The fundamental difference is that the tow-plane isn't being disassembled and reassembled all the time. And the tow-planes control systems aren't designed with disassembly in mind; whereas a glider's are. It creates some fundamental differences in the engineering... Do you really know how much load is safe to apply to a control surface? Ok, so let me get this straight - you'd rather risk your LIFE (and the lives of those around you) instead of risking damage to your control surface? Common sense should work for figuring out how to do the PCC without damage, just as common sense should encourage us to DO a PCC in the first place. --Noel |
#33
Do you really know how much load is safe to apply to a control surface? Is it in your operators manual? Airloads on modern tiny control surfaces can be quite small in comparison to what an enthusiastic human hand can apply... Actually, it's not that hard to reverse-engineer estimated maximum hinge moments from (rho*v^2)/2 and the suggested loading schedules in the old FAA pub "Basic Glider Criteria." The total forces can be pretty great, especially the accumulated torsion for something like a c*.17, 2-drive full-span flaperon like yours. As you observe, the maximum hinge moment and normal loading on something like your LS6 elevator is pretty small. However, JAR22 and FAR23 both require a fair bit of margin over the flight loads. They also specify some pretty hefty minimum input loads between the control stick and the stops, though by the looks of the European marques they tend to weasel out of the default input forces with the "unless lower can be rationally justified" clause. Thanks, Bob K. |
#34
Guys you are missing the point! There is a difference between a
Critical Assembly Check and a Positive Control Check. A PCC would NOT have helped Clem. With the elevator connecting bolt taped over, the glider would have most likely passed the PCC! I am all in favor of doing the Critical Assembly Check. I always do mine twice, first after rigging, second before launch. Of all of the accidents described, most would have been avoided by doing a proper CAC, not PCC! On Jun 4, 8:56*am, Andreas Maurer wrote: On Tue, 3 Jun 2008 19:43:51 -0700 (PDT), wrote: Please name one accident of a glider with auto hookups that could have been prevented by a positive control check. I sure don't know any. A seized bearing will be detected by simply moving the stick. In all gliders I know there is no scenario of control failure that would necessitate a positive control check for detection. There have been SEVERAL incidents and accidents of DG gliders where the automatic hookup of the elevator was not connected correctly. Not to mention several (unfortunately usually fatal) crashes of gliders where the auto hookups were connected correctly, but the horizontal tail was not. Ernst-Gernot Peter and Clem Bowman come to my mind... You are making a slippery slope argument. Should we mandate annual stress tests of wings in the name of safety? Overhaul all tost releases every 100 cycles? Nope... but to do a simple 2 minute check before the flight... Bye Andreas |
#35
On 4 Jun, 20:27, "noel.wade" wrote:
On Jun 3, 7:18*pm, wrote: After all, he's going to be the one in trouble if he's wrong. But it Let's tackle that statement once and for all, shall we? I know this wasn't Ian's main point in his post - but its important to mull this over before you think that "its OK becuase I'm the one who will pay if I screw up". *You can't be that certain. OK, I will happily amend that to "He's the one person who will certainly be in trouble if he screws up..." P.S. *Contrary to popular belief, its possible to be safe AND still have a ton of fun. *Being safe doesn't mean being nasty or boring - it just means taking 5 minutes to be responsible! Of course. That's why I do positive control checks. But one of the best ways to reduce safety is to make checks and routines /too/ automatic. I think it is much better to have people follow routines they've thought about than follow a checklist blindly. I think, for example, of all the pilots trained by BGA instructors in K21s (or K13s or Bocians or ...) to say "...strapstightinstrumentsoknoflapsfittedcanopyclo sed..." pre take-off or "windslightlycrossfromtherightundercarriagefixeddo wnspeedappropriate ...." while downwind. Ian |
#36
On Jun 3, 8:13 pm, ContestID67 wrote:
A recent accident (disconnected aileron) got me thinking about positive control checks. I searched the RAS archives and didn't find any details on how people do this. I was trained by my CFIG, like most of you I hope, to do a positive control check every day. Actually it was more like it was drilled into me. This was even done on club ships that remain assembled for the season. As a beginning pilot I would sit in the cockpit and move the controls as someone more experienced put their hands on the flight surfaces. Later I found that anyone can handle the controls, it's the hands on the surfaces that was much more telling if things were connected properly or not. My ship does not have automatic hookups so this is especially important to me. I got into the habit of having my assistant move the control one way, then the other, then back again with full deflection. All the while I was putting pressure on the surface and, at the same time, wiggling the surface to simulate take off vibration. So far, no incidents, knock on wood. So, the question is, how do *YOU* do your positive control check? John "67" DeRosa John, Your topic is an old favorite of mine. When starting glider flying in this country many years ago I was appalled by the way positive control checks were done. The pilot was in the cockpit, in line for getting towed and a more or less hapless assistant was asked to lock a particular control surface or the airbrakes with their hands. The pilot would then bang the stick around and declare the airplane safe for flight (leaving the assistant with pinched and bruised fingers). You already described well a better way to do this. Put the assistant into the cockpit, yes, sitting in it, not just standing outside. Have her move control surfaces on your command, slowly and deliberately. The pilot will put pressure on those surfaces simulating in-flight forces around the center position but also test full deflections. Walking around the glider doing this also allows for a full assembly check, looking for mylar seals, hinge conditions, gap tape, tire inflation etc. My wife and I have done this for many years with me calling out the control movements (in German) and her repeating them and executing. It's been a source for amusement for many bystanders but I believe it kept me safe. Now, I can teach you to do this in German (with a Colonel Klink voice) but that's not really necessary... Herb, J7 |
#37
![]() Now, I can teach you to do this in German (with a Colonel Klink voice) but that's not really necessary... Herb, J7- Please, Herb! That would make it much more fun. More seriously, missing in much of this discussion is the approach that US contests have taken to this whole question. We don't call it a "posiitve control" check, we call it a "critical assembly" check. Whatever you think of the value of pushing around control surfaces on gliders with automatic hookups, "critical assembly" includes making sure the bolt is in the horizontal stab (Schleicher) or stub pushed in (Schempp), the mylar isn't falling off the tail, the main pins are in and locked. John Cochrane |
#38
![]() My wife and I have done this for many years with me calling out the control movements Just had a terrible thought, check out this scenario......... My whife doesn't come to the airport much anymore, so I ask the pretty little thing who's been interrupting my assembly to help with a control check. She says sure and jumps in the cockpit (like Herb recommends). We go through the left aileron, left spoiler, elevator, right spoiler, right aileron...................she hasn't missed a beat. Then I say, Oh I forgot the flaps. Which one of these handles does that, she asks sweetly? It's that little black one down on the left side.................BAM the ships alams to the ramp as the landing gear retracts! Errrrrr, the OTHER little black handle down there on your left!!!! Here's how I handle the control check (solo for above reasons) I have automatic hook-ups. I assemble with the aileron control locks in place. When she's together, I attach a stiff bungee from the stick to the left rudder pedal, which keeps the stick full forward and rudder full left. Then I move out to the left aileron, remove the control lock and try to move the aileron. If I can't move the aileron, it's connected. I then replace the control lock and try the same thing with the right aileron, If I can't move it, it's hooked up also. Next I pull full spoilers and check to see they're both wide open and that the wheel brake is locked. Then I close and lock the spoilers and check to see that both spoiler caps are down and flush, indicating ther're hooked up. Then I go to the rear and try to move the elevator and rudder. If I can't move them, ther're hooked up also. JJ PS, I have seen a pilot retract the gear when asked to do a control check.........it can happen! |
#39
JJ Sinclair wrote:
.... PS, I have seen a pilot retract the gear when asked to do a control check.........it can happen! Interesting, thanks for that detail. I've always wondered if it's possible to retract the gear with weight on the wheel - that is, on the ground. One'd think it possible to design an over-center mechanism that would make that impossible, or at least *really* hard to do. But it is experiment I've never been willing to try. Sarah |
#40
On Jun 5, 7:54*pm, Sarah Anderson wrote:
JJ Sinclair wrote: ... PS, I have seen a pilot retract the gear when asked to do a control check.........it can happen! Interesting, thanks for that detail. *I've always wondered if it's possible to retract the gear with weight on the wheel - that is, on the ground. * One'd think it possible to design an over-center mechanism that would make that impossible, or at least *really* hard to do.. But it is experiment I've never been willing to try. Sarah I have tried it. With the plane assembled, but still in the 'cradle', extend the undercarriage, then lower the cradle until the weight is all on the wheel, but it can only drop an inch (or less). Get in, and try to retract the gear. In the Speed Astir, I can't do it with a very firm pull on the gear handle. |
Some more positive GA News | Jay Honeck[_2_] | Piloting | 22 | February 4th 08 01:46 AM |
USA Today .. Positive GA Pub | Jay Beckman | Piloting | 65 | February 14th 07 10:36 PM |
Positive, All-Comers Welcome. | Jim Culp | Soaring | 4 | January 2nd 05 06:18 AM |
some positive press for GA | Dave Butler | Piloting | 1 | January 28th 04 03:07 PM |
