Ok, normally this is soaring, but I know there are a lot of really
capable computer folks who read this group and this item might actually help some of the other folks out there in the future as well. I have a Dell, set up with RAID 1. For those unaware, RAID 1 utilizes two hard drives. The same data is simultaneously written to both hard drives at the same time and is read from both hard drives at the same time. The benefit of this is that should one drive "die" the second one soldiers on and all you have to do is replace the dead drive and the computer will automatically recreate a copy of the good drive and therefore you have a full time backup. Ok, when I ordered my dell, I got twin 160 Gigabyte drives. I've had a couple of drive failures over the last couple of years and when the drives failed I found it very inexpensive to buy 300 and 400 Gigabyte drives. However, the computer still sees only 160 Gigabytes of usable space. I'm hoping that someone can offer a suggestion on how I can upsize the available storage to take advantage of the actual storage area on the two drives. While I have a couple of thoughts as how to do this, I'll stop here and not taint a clean thought process for those who know this best. Keep in mind that I am prepared to not only buy an additional 400 Gig drive so that both drives are 400's (keeping the 300 as a backup) and I'm also happy to go buy a large USB drive in case having a separate external drive is useful in this process. I'm down to only 10 Gigs of usable space on the 160Gig original format, so I need to tackle this problem sooner rather than later. I also have an older (don't have the version handy) copy of Norton Ghost. It probably isn't important, but the drives are SATA. I do not know if I have any way to add another drive to the motherboard. I kind of suspect I don't. Many thanks Gary |
Gary Emerson wrote:
Ok, when I ordered my dell, I got twin 160 Gigabyte drives. I've had a couple of drive failures over the last couple of years and when the drives failed I found it very inexpensive to buy 300 and 400 Gigabyte drives. However, the computer still sees only 160 Gigabytes of usable space. RAID 1 always limits your capacity to the smallest drive in the pair. So, if you want to continue using RAID 1 and increase capacity, you'll need to replace both drives. By the way, RAID 1 does a decent job of protecting against hard drive failures, but it will not protect against Windows screwups, operator error, etc. Backups are still a good idea... Marc |
On Jun 19, 3:45*pm, Marc Ramsey wrote:
Gary Emerson wrote: Ok, when I ordered my dell, I got twin 160 Gigabyte drives. *I've had a couple of drive failures over the last couple of years and when the drives failed I found it very inexpensive to buy 300 and 400 Gigabyte drives. *However, the computer still sees only 160 Gigabytes of usable space. RAID 1 always limits your capacity to the smallest drive in the pair. So, if you want to continue using RAID 1 and increase capacity, you'll need to replace both drives. *By the way, RAID 1 does a decent job of protecting against hard drive failures, but it will not protect against Windows screwups, operator error, etc. *Backups are still a good idea.... Marc Also, if you simply "clone" the drive or the RAID array with most software, it will set the size of the new array or drive partition to the old size. If you've replaced both drives with a new (larger) set of disks (which should be identical in a RAID 1 array), then you will probably need to rebuild the array (or partition) to the larger size. Note that rebuilding the array can destroy the data on it - this very much depends on the software and tools you use to reconfigure the array. Good luck, take care, --Noel (who's a RAID 5 kinda guy) |
I love this group!!!
A guy asks a question way off topic (being up front about it of course) and gets great help. I tried to do the same thing on another group last week and got flamed, roasted and skewered. ~ted/n2O ps can anyone recommend a good commercial wiki product, for team collaboration and internal C++ project documentation? ![]() |
On Jun 19, 3:32 pm, Gary Emerson wrote:
Keep in mind that I am prepared to not only buy an additional 400 Gig drive so that both drives are 400's (keeping the 300 as a backup) Good idea. Get a 400 GB drive, replace the 300 GB drive with it and let the system rebuild the RAID. Keep the 300 GB disk safe - it will prove invaluable if things go wrong. Then, get a tool called Partition Magic. It is not very expensive - I got it almost for free in a set with Norton Antivirus and Ghost. It should indicate that you have one 160 GB partition and 240 GB of free space. Either resize the partition or create a new one in the free space (the safer option). And you can add another drive to your system if you have a free PCI slot and are willing to spend about $30 for a SATA controller. Bartek |
On Jun 19, 8:46 pm, Tuno wrote:
ps can anyone recommend a good commercial wiki product, for team collaboration and internal C++ project documentation? ![]() Ted - Try MediaWiki (for collaboration) and Doxygen (for internal documentation)... |
On Jun 20, 1:53*pm, brtlmj wrote:
Then, get a tool called Partition Magic. It is not very expensive - I got it almost for free in a set with Norton Antivirus and Ghost. It should indicate that you have one 160 GB partition and 240 GB of free space. Either resize the partition or create a new one in the free space (the safer option). I tried Partition Magic for a cloning exercise recently (to upgrade a laptop from one HD to a larger HD) and the tool didn't do the trick (though it has worked perfectly for expanding a partition and other functions). I then used Acronis True Image (http://www.acronis.com) which cloned perfectly. A fully functional trial copy can be downloaded from the web site. Highly recommended. To repeat a common thread - have a really good backup before entering these troubled waters. Good Luck, John DeRosa |
Aviation related videos | [email protected][_2_] | General Aviation | 0 | November 28th 07 01:24 AM |
Slightly related | Denny | Piloting | 1 | August 23rd 07 08:05 PM |
Seaplane Base - 2 - Busy Base-2.jpg (1/1) | john smith[_2_] | Aviation Photos | 0 | August 2nd 07 05:09 AM |
Pitss S-1S related questions | Sascha Schott | Aerobatics | 3 | March 24th 05 08:50 PM |
Commercial Pilot FAA Knowledge Exam - Includes Gleim TestPrep & Commercial Pilot FAA Knowledge Exam book | Cecil Chapman | Products | 1 | November 15th 04 04:22 PM |
