Rocket Racing League First Exhibition Race August 1st and August 2nd, 2008
Old July 2nd 08, 03:56 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Default Rocket Racing League First Exhibition Race August 1st and August 2nd, 2008
On Tue, 1 Jul 2008 14:55:40 -0700 (PDT), BobR wrote:
Not sure why everyone keeps making the comment about dead stick
landings. Rutan demonstrated the rocket plane at Oshkosh a couple of
years back with the full ability to start, stop, and restart the
engines.
When Rutan flew, he was the only plane up there. When he hit the "go" button,
all he was expected to do was fly around the airport at least once, then land.
He could keep some fuel back in case he had to go around, or "blip" the rocket
to correct for an undershoot.
In contrast, of course, the RRL pilots will be busy flying the invisible course
and keeping from running into up to nine other rocket planes. It's a little
different problem....
According to the RRL web page, they're going to stagger the takeoffs, so that
should reduce the chances for simultaneous deadsticks. However, it's going to be
interesting if (for instance) a landing gear collapses and the plane stops on
the runway. I'm sure they'll have a backup runway, but the guys aloft may have
to scramble a bit. Trouble is, unless there's a second backup runway, racing
will have to stop until they get the primary cleared.
I surfed around the RRL web page, and found some technical data that I hadn't
noticed the last time I checked, several months back.
"...1,500 pound thrust rocket engine burning liquid oxygen (LOX) and kerosene...
Each X-Racer will be a single-pilot vehicle with an empty weight of roughly
1,000 lbs and a propellant weight of 1,000 lbs..."
Lox/Kerosene has a Specific Impulse of about 300 seconds, so this comes out to
200 seconds of engine run time (web page says 4 minutes of intermittent powered
flight, so that ties in). Ten minutes of glide time, Pit times are listed as
5-10 minutes. So that makes less than four minutes of powered flight per
aircraft every twenty to twenty-five minutes.
"...the Rocket Racing League will feature multiple races pitting up to 10 Rocket
Racers going head to head in a 4-lap, multiple elimination heat format on a
5-mile "Formula One"-like closed circuit raceway in the sky."
It's a twenty-mile course (five miles around, four laps). The planes should be
able to complete the course WITHOUT a pit stop...the plane has to average just
80 MPH during that 15-minute flight.
However, the web page says they have to pit after "3-4 laps." They may be
requiring some sort of fuel reserve. But it seems weird to plan for a 5-10
minute pit stop when the plane could practically *coast* around the course for
that last lap. My guess is that the "pit stops" are more to get planes ready
quickly for the next heat before the spectators wander away.
Still didn't' find anything on the web page about flight altitudes. It might be
something they leave up to the teams to decide...either go up high and coast
downhill at high speeds, or stay low and run the engine in short blips.
Old July 2nd 08, 12:44 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Vaughn Simon
On Mon, 30 Jun 2008 07:06:27 -0700 (PDT), Harry K
... of course a plane
just out of the pits will be a lot slower and have less acceleration than
those
already aloft (due to still carrying a heavy fuel load).
Reduced acceleration yes, but a heavier aircraft has a faster best L/D, (all
else being equal) which is why competition gliders often fly with water ballast.
If you take the time to think about it, the optimum Fuel Consumption vs Gross
Weight vs Altitude vs Speed vs Flight Duration vs Range strategy for these birds
gets more and more complicated.
Vaughn
Old July 2nd 08, 04:57 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Rich S.[_1_]
might be
coast
Something I saw indicated the course would be 3-D. They would have "gates"
with upper, lower, left and right boundaries. So, they would have to climb,
dive, left and right maneuvers. Only the vectors between the gates would be
left up to the pilots, as well as the use of power.
The racers wouldn't be aiming for the same gate. The computer would have
gates for each racer, perhaps laid out side-by-side (with spacing for
safety), so the planes would appear to be racing but in reality flying
parallel courses.
I think that was on a TV spot or perhaps an animated internet movie clip.
Rich S.
Old July 3rd 08, 05:26 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
On Wed, 02 Jul 2008 11:44:03 GMT, "Vaughn Simon"
those already aloft (due to still carrying a heavy fuel load).
You're right, of course. As an engineer, it's a problem that really tickles my
fancy.
However, we're right back to considering how interesting the races will be
(e.g., how willing they are to pay for another) to the average spectator. A
spectator at a NASCAR race or at Reno can easily judge how their favorite racer
is doing...e.g., if he's passing a lot of other vehicles, he's probably a
front-runner.
Not the case with the RRL. For one thing, the planes stagger their
takeoffs...they don't start at the same time. So unless the course length
differs for each aircraft (which is a really, REALLY thorny problem in fuel
planning), the order they cross the "finish line" has nothing to do with their
standings.
Plus, EVERY plane will be getting passed by the other planes in the first half
of their flight, and passing more and more of the other planes as their tanks go
dry and their acceleration increases (a RRL plane has about a 0.75G capability
at takeoff, but is able to accelerate at 1.5Gs just prior to running out of
fuel).
I'm sure the NASCAR and Reno events are complicated enough that to truly
understand how each competitor is doing, the spectator must consult the
scoreboard. But if a guy is a Rare Bear fan, he can probably tell pretty well
how the plane is doing just by watching it.
Not so in the RRL. It doesn't mean a thing if their favorite is passing other
racers; it just means the aircraft has burned more fuel. It doesn't mean a
thing if a racer crosses the finish line in front of others; it may have taken
off minutes before they did. So the spectator's eyes gravitate towards the
video monitors. By the end of the day, he'll probably come to the conclusion
that he could have followed the race better from his computer at home.
The discussion on this thread started when Harry asked if the racers were just
racing against the clock. I corrected him... but the more I think about it, the
more I think he had it right. The rockets are aloft at the same time, but each
is racing against an individual clock.
Old July 3rd 08, 05:57 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Steve Hix
(all
ballast.
Gross
birds
my
fancy.
racer
front-runner.
their
standings.
half
go
capability
fuel).
well
other
taken
just
each
It's beginning to sound more and more like a bicycle time trial.
If it's done right, it could be pretty compelling (look at cycle racing
fans in europe), or it could end up being good for insomniacs.
Old July 3rd 08, 07:56 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
cavelamb himself[_4_]
Default Rocket Racing League First Exhibition Race August 1st and August2nd, 2008
It's beginning to sound more like a made for TV stunt.
$300,000 Flight Competition August 2-10, 2008 Larry Dighera Piloting 0 January 3rd 08 11:31 AM
Rocket Racing League/Zzzz Kyle Boatright Home Built 4 May 7th 07 04:17 AM
Rocket racing at Reno raptor Home Built 2 November 3rd 05 02:48 AM
Rocket Racing League John Ousterhout Home Built 34 October 7th 05 06:30 AM
August 7 Update [email protected] General Aviation 0 August 5th 05 01:03 AM
