It was mentioned during a talk Kai Gertsen gave at the Region 1 contest
this year that it is a good idea to call 911 if you land your glider within sight of a road or other humans. The problem has been in the past that many times the glider outlanding is called in to the authorities as an airplane crash. What happens next is that some well meaning ambulance, fire department, and police personell drive through the crop to help "rescue" the pilot. This of course does much more damage to the poor farmer's crops than your outlanding. When you land out, call 911 and inform those people of your exact position and that everything is fine (assuming you are physically OK) and you are awaiting your retrieve crew. Let them know that no assistance is wanted or required and that all appropriate authorities be notified of same. I have done this myself and the 911 people are only too glad to get this information so that they can save their assistance for those who truly need it. |
"Mike McCarron" wrote in message ... It was mentioned during a talk Kai Gertsen gave at the Region 1 contest this year that it is a good idea to call 911 if you land your glider within sight of a road or other humans. The problem has been in the past that many times the glider outlanding is called in to the authorities as an airplane crash. What happens next is that some well meaning ambulance, fire department, and police personell drive through the crop to help "rescue" the pilot. This of course does much more damage to the poor farmer's crops than your outlanding. When you land out, call 911 and inform those people of your exact position and that everything is fine (assuming you are physically OK) and you are awaiting your retrieve crew. Let them know that no assistance is wanted or required and that all appropriate authorities be notified of same. I have done this myself and the 911 people are only too glad to get this information so that they can save their assistance for those who truly need it. Good Idea! This year at Cordele, GA (USA) 911 was called multiple times - Though the inhabitants of the task area who have lived there a while are fully aware of what gliders do---newcomers are not--. The 911 dispatchers called the Airport multiple times, and finally asked the contesants to call 911 on landing, to assure they are OK. After all, occasionally, someone does get hurt in a landout, so they must respond if called. Could save someone else if the emergency crews are diverted to a non-emegency. Hartley Falbaum DG808C "KF" USA |
On Thu, 3 Jul 2008 19:37:02 -0400, "HL Falbaum"
wrote: "Mike McCarron" wrote in message ... It was mentioned during a talk Kai Gertsen gave at the Region 1 contest this year that it is a good idea to call 911 if you land your glider within sight of a road or other humans. The problem has been in the past that many times the glider outlanding is called in to the authorities as an airplane crash. What happens next is that some well meaning ambulance, fire department, and police personell drive through the crop to help "rescue" the pilot. This of course does much more damage to the poor farmer's crops than your outlanding. When you land out, call 911 and inform those people of your exact position and that everything is fine (assuming you are physically OK) and you are awaiting your retrieve crew. Let them know that no assistance is wanted or required and that all appropriate authorities be notified of same. I have done this myself and the 911 people are only too glad to get this information so that they can save their assistance for those who truly need it. Good Idea! This year at Cordele, GA (USA) 911 was called multiple times - Though the inhabitants of the task area who have lived there a while are fully aware of what gliders do---newcomers are not--. The 911 dispatchers called the Airport multiple times, and finally asked the contesants to call 911 on landing, to assure they are OK. After all, occasionally, someone does get hurt in a landout, so they must respond if called. Could save someone else if the emergency crews are diverted to a non-emegency. Better yet, CD's should contact emergency authorities before a contest starts and give them a briefing about glider outlandings... rj |
Better yet, CD's should contact emergency authorities before a contest starts and give them a briefing about glider outlandings... rj This is a good thought, but it accomplishes nothing. Im an Engineer in our VFD, and if we get a call of an aircraft down from a citizen in our redsponse area, we are obligated to go . A briefing that informs 911 that sailplanes may be raining down in the area does NOT mean that what the citizen reporting to us saw a sailplane. He probably did, but we cant take probably as an answer. The only good answer from the EMS/VFD side of the discussion is to call us every time you land out. It eliminates guessing, and doesn't put EMS/VFD crews at risk rolling code to a non-event....... every time you land out. |
At 04:26 07 July 2008, XYZ wrote:
The only good answer from the EMS/VFD side of the discussion is to call us every time you land out. It eliminates guessing, and doesn't put EMS/VFD crews at risk rolling code to a non-event....... every time you land out. Here's another good idea for avoiding hassles on landing out. Some years back when the Texas Soaring Association was hosting a 1-26 Championships, they got together with someone from the local FSS and produced a letter, from the FAA, to the effect that a glider landing somewhere other than an airport was, to the FAA, a non-event as long as nobody was injured, and no serious property damage resulted. In such cases, the FAA did *not* need to be informed. Each competitor was given a copy to carry along in the gliders. Such a letter would have helped a few years ago at a 1-26 meet out of Blairstown, where a glider made an uneventful outlanding in a corn field (about four inches high). The two young state troopers who eventually showed up got all uptight and refused to let us move the glider until they had gotten permission from the FAA (on a Sunday afternoon). The letter would have helped. Jim Beckman |
| Radio Procedure - Runway ID | Casey Wilson | Piloting | 173 | October 27th 05 01:34 PM |
| FLY-IN & CONVENTION - REGISTRATION PROCEDURE | Don | General Aviation | 0 | May 8th 04 02:01 AM |
| Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 04:27 AM |
| Unusual Procedure at DFW | Toks Desalu | Piloting | 9 | December 17th 03 06:27 PM |
| OAK arrival procedure | ROBIN FLY | Instrument Flight Rules | 5 | October 1st 03 04:05 AM |
