Cover up the face.
The Cambridge 302 vario needle can fail to zero correctly at power up. The instrument uses a light source and photo sensor to find the zero position. If bright light overpowers the light source then the needle can fail to position properly. Sometimes it goes around in circles for a while. Power it up with the face covered. This information is already posted in this newsgroup inside some threads on similar tipics. As far as I can tell it is not documented on the CAI web site or in the manuals. I thought it was worth posting again as its own topic and hope it helps someone. Mark |
Page 21 of the manual.
"MaKoRide" wrote in message ... Cover up the face. The Cambridge 302 vario needle can fail to zero correctly at power up. The instrument uses a light source and photo sensor to find the zero position. If bright light overpowers the light source then the needle can fail to position properly. Sometimes it goes around in circles for a while. Power it up with the face covered. This information is already posted in this newsgroup inside some threads on similar tipics. As far as I can tell it is not documented on the CAI web site or in the manuals. I thought it was worth posting again as its own topic and hope it helps someone. Mark |
| Thread Tools | |
| Display Modes | |
| Power setting table and best economy/best power... | xerj | Piloting | 29 | October 20th 05 03:44 AM |
| Through the eye of the needle (long) | TTaylor07 at cc.usu.edu | Soaring | 2 | September 28th 05 01:48 PM |
| Dead Glideslope needle | Jim Burns | Owning | 3 | September 7th 05 04:03 PM |
| Jumpy needle | Ludovic Launer | Soaring | 3 | April 5th 05 08:26 AM |
| Cessna 172 with Wild Fuel Gauge Needle | jls | Owning | 26 | February 20th 04 06:56 AM |
