German registered glider maintenance: help with LBA doc needed
Old July 18th 08, 05:59 PM posted to rec.aviation.soaring
Ludovic Launer[_2_]
Default German registered glider maintenance: help with LBA doc needed
Could any owner of a german registered glider shed a light on this subject:
As a private owner, and sole operator of a self launcher (DG-808), I'm a bit
confused as to what should be done concerning the:
Application, Declaration and Approval of a Standardized Maintenance
Programme (SIHP) in accordance with Regulation (EC) 2042/2003, Part M,
M.A.302
The document can be found on the LBA website :
http://www.lba.de/cln_010/nn_308444/...20PG+AS_en.doc
Or somewhere here in German:
http://www.lba.de/cln_010/nn_67048/D...e__GenTab.html
I'd just like to make sure I'll still be allowed to carry out the annual
inspections, and then have them checked / certified by our local LBA
inspector. In other words, make sure things will stay as they are, and I
won't have to have the inspections carried out at a certified LBA workshop.
I phoned my local "prufer" who said I shouldn't be doing anything at all,
things haven't changed....yet.
I got in touch with other German registered glider owners who said they
filled out the form and sent it back to the LBA
If there's such a form, why shouldn't it be used ? Should I, or should I not
fill it out and post it ?
It's very confusing having two different answers
Does anyone have more information on that ?
Have you sent the form ?
What have your LBA inspectors told you ?
Thanks for your help,
Ludovic
Old July 18th 08, 06:21 PM posted to rec.aviation.soaring
Markus Graeber
Here some more info from DG (in German): http://www.dg-flugzeugbau.de/camo-d.html
Markus
On Jul 18, 10:59 am, "Ludovic Launer" ludovic.launer(at) free.fr
M.A.302
The document can be found on the LBA website :http://www.lba.de/cln_010/nn_308444/.../Formulare/T5/...
Or somewhere here in German:http://www.lba.de/cln_010/nn_67048/D...Formulare__Gen...
Ludovic
Old July 18th 08, 09:22 PM posted to rec.aviation.soaring
Ludovic Launer[_2_]
I'm sure that would answer a lot of my questions....if I could understand
it...
Any source for the same article in English ?
Regards,
Ludovic
Old July 19th 08, 11:43 AM posted to rec.aviation.soaring
John Smith
The problem is, EASA introduced this in a very tight schedule, and the
proposed requirements have been changed several times in the process.
Litaraly nobody knows at this point exactly how it will work and how to
really deal with it in real life.
Basically, you will need an approved "mainenance programme". With this,
you can as a private owner still do all the maintenance yourself. I
guess your beast chance to get a detailed answer is to contact an
European glider association, they really work on this. Probably your
best starting point would be to contact the British Gliding Association,
for language reasons.
radio permit for german registered glider Andy Smielkiewicz Soaring 6 February 24th 06 02:27 PM
Glider Lease Agreement between two individuals needed Snead1 Soaring 4 November 15th 04 01:34 PM
German "Endoresement" of an FAA Glider Cert? Tim McAllister Soaring 7 January 27th 04 07:14 PM
Joint German-Israeli airforce excersie (Israeli airforce beats German pilots) Quant Military Aviation 8 September 25th 03 06:41 PM
Glider needed Jeff Landfield Soaring 0 July 21st 03 05:39 AM
