Monokote trim patches for covering holes - not recommended
Old July 20th 08, 04:36 AM posted to rec.aviation.soaring
Darryl Ramm
Default Monokote trim patches for covering holes - not recommended
On Jul 18, 1:22*pm, Uncle Fuzzy wrote:
A while back I posted that I had used Monokote trim to cover some of
the larger holes in my Speed Astir fuselage. *They did a nice neat job
of covering the holes, but here's the follow-up. *I removed one a
couple weeks ago that had been in place for a couple months. *The
mylar pulled off cleanly, but left the adhesive behind, and boy howdy
was that stuff difficult to remove! *Perhaps with the RIGHT solvent,
it wouldn't be a pain, but the 3M General Adhesive Cleaner doesn't do
much but make it gooey. *If anybody knows what sort of solvent would
work better on the Monokote trim adhesive, please chime in, cause I'm
sure the 'racing checker' patches made my glider faster!
Oh and I forgot. "Goo Gone" citrus based cleaner will probably knock
this straight off. Maybe followed by a clean wipe of 3M cleaner,
acetone or toluene, etc. I've used Goo Gone to take off residue of
misapplied stripes similar to Monokote.
Darryl
Old July 20th 08, 05:31 AM posted to rec.aviation.soaring
Craig[_2_]
On Jul 19, 8:36 pm, Darryl Ramm wrote:
the larger holes in my Speed Astir fuselage. They did a nice neat job
of covering the holes, but here's the follow-up. I removed one a
couple weeks ago that had been in place for a couple months. The
was that stuff difficult to remove! Perhaps with the RIGHT solvent,
much but make it gooey. If anybody knows what sort of solvent would
Darryl
xylene (xylol) is very effective at removing adhesive goo when all
else fails. It's usually available in pints at the local big box
hardware store.
Craig
Old July 20th 08, 12:56 PM posted to rec.aviation.soaring
Martin Gregorie[_3_]
Darryl
hardware store.
Hexane is good for contact cement removal, assuming its not been banned
as a VOC. It was the best of a fairly unimpressive set of solvents when I
needed to clean double sided tape off some mylar gap seal.
martin@ | Martin Gregorie
gregorie. |
org | Zappa fan & glider pilot
Old July 20th 08, 05:11 PM posted to rec.aviation.soaring
Uncle Fuzzy
On Jul 20, 4:56*am, Martin Gregorie
Darryl
else fails. *It's usually available in pints at the local big box
hardware store.
martin@ * | Martin Gregorie
gregorie. |
org * * * | Zappa fan & glider pilot- Hide quoted text -
- Show quoted text -
Pretty sure it's 'unobtainium' now. I could be mis-remembering, but I
think I used Hexane as an additive to fuel for my compression ignition
engines.
Old July 21st 08, 02:41 AM posted to rec.aviation.soaring
flash
I have had good result removing all kinds of decals and "stuff" off cars and
motorcycles with "GO-JO" hand cleaner. It takes a bit of rubbing, but it
is harmless to whatever is underneath.
And in a hurry, I have used the Go-Jo with pumice - it may leave a slight
haze, if what's underneath is not too tough.
Flash
"Uncle Fuzzy" wrote in message
Old July 21st 08, 06:53 PM posted to rec.aviation.soaring
Monokote is fuelproof so run of the mill methyl and ispropyl wont
work. That's what fuel is(methyl alc). Try Acetone and I recall
there is a TopFlite Monokote solvent that you could probably get at
towerhobbies.com.
If that does not work, let everything evaporate and no longer
flammable and gently use a heat gun and putty knife to scrape it off.
Any remaining residue can be wet sanded off.
Darren
Old July 22nd 08, 11:25 AM posted to rec.aviation.soaring
engines.
That would have been ether, assuming you mean model engines: 40% ether,
20% castor oil, 39% kerosene, 1% amyl nitrate runs pretty well.
Outside a lab I've only seen hexane sold as thinners for Evostik contact
cement.
gregorie. |
Old July 22nd 08, 05:28 PM posted to rec.aviation.soaring
Darryl Ramm
Darryl
hardware store.
Craig
Xylene is one of the main ingredient in the 3M General Purpose
Adhesive Cleaner, and yes it does work well for many things. I think
the 3M blend is pretty handy for removing stuff (including wing tape
residue). However the original poster reported it did not work in
this case. From the material safety data sheet the main ingredients in
3M General Purpose Adhesive Cleaner are
XYLENE 30 - 60%
NONANE 10 - 40%
OCTANES 10 - 30%
ETHYLBENZENE 5 - 20%
I've been able to purchase this even in California, e.g. at my local
Orchard Supply Hardware store.
Darryl
Old July 22nd 08, 10:37 PM posted to rec.aviation.soaring
On Jul 21, 10:53*am, wrote:
Try Acetone ...
BTW, standard disclaimer with all this solvent talk, try on a small
patch first for compatibility... Gelcoat is pretty stable and can
handle Acetone, but not sure if glider in question has polyurethane
and what it would do.
Once had a friend who put some solvent in wax paper cup and set in on
the hood of his 280Z while he worked on some blemish. Meanwhile, this
stuff ate through the cup, and then proceeded to etched the paint job
on his car hood.
Covering holes [email protected] Soaring 9 May 2nd 08 05:57 PM
Going of ver recommended TBO gman Piloting 10 October 11th 06 05:52 AM
Covering an ultralight wing with Monokote Chris Wells Home Built 5 January 10th 06 12:20 AM
When Poorboys drill holes ...was: Drilling holes in steel tubing wright1902glider Home Built 4 November 4th 05 01:19 AM
Anywhere recommended near Rochester MN? Dave Aerobatics 0 April 1st 04 05:18 PM
