After a trailer tire blowout last year, I installed a remote monitoring
system that displays the trailer tire pressure on command, and alerts me automatically if the pressure drops. I don't know how effective this will be in avoiding tire problems, because it's possible tread separation can occur even if the pressure is OK, but at least I won't be driving on under-inflated tires. There are several systems that one can choose from. I'm using PressurePro, which is about $150 for the monitor and $50/tire for the sensors. I also put them on my tow vehicle, so it was $650 for the two trailer wheels and the six RV wheels. It was easy to install and seems to work well. Is anyone else using a trailer tire monitoring system? Has it helped you avoid tire problems? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Eric Greenwell wrote:
Is anyone else using a trailer tire monitoring system? Has it helped you avoid tire problems? Hi Eric. Can't comment directly on trailers. But my wife's Dodge Caliber came with sensors as standard. For the first time that I can recall she has actually requested that I put air in her tire. Prior to that she has been known to drive for days with almost zero air pressure. I think the new sensors are great, on any application. -- Regards, Doug ** Posted from http://www.teranews.com ** |
On Jul 24, 10:47*am, Eric Greenwell wrote:
After a trailer tire blowout last year, I installed a remote monitoring system that displays the trailer tire pressure on command, and alerts me automatically if the pressure drops. I don't know how effective this will be in avoiding tire problems, because it's possible tread separation can occur even if the pressure is OK, but at least I won't be driving on under-inflated tires. There are several systems that one can choose from. I'm using PressurePro, which is about $150 for the monitor and $50/tire for the sensors. I also put them on my tow vehicle, so it was $650 for the two trailer wheels and the six RV wheels. It was easy to install and seems Hi Eric, I tried a similar system on my semi and it didn't work reliably, most likely due to the 70 foot length of the unit. I switched to "Cat's Eyes" which are devices with a clamshell covered by a plexiglass dome. They mounted on the tire studs and connected by a braided hose to the valve-stem. When the pressure was right, the lids were closed, when it dropped, the clamshell opened proportionally. This was easy to see at a glance. They were available in a range of preset pressures and were much cheaper than the systems with electronic senders, but you did have to get out of the truck. They were made by an outfit called Link Manufacturing. There are systems for big trucks that actually maintain correct pressure by means of a hub-mounted centrifical pump, but they were new and unproven at the time. My drivers had frequent tread separations and blowouts (about two a month) in the 10 years before the Cat's Eyes" were installed but only two blowouts in the 10 year period I owned the truck afterwards, both due to striking debris in the road. We had no tread separation incidents during this period. Given that, depending on position, these tires cost anywhere from $ 200 to $ 400 each (Perhaps even more now), the savings were considerable. Correct inflation, in addition to preventing tire and associated vehicle damage, improves fuel economy and prolongs the life of the axles and wheel bearings, Oh yeah, did I mention safety? You haven't really lived 'til you've tried to control a long, unstable vehicle that has suddenly developed a mind of it's own. Blowouts often do that! For anyone interested, Google "tire pressure monitor" and all sorts of information pops up. Ray Warshaw 1LK PS: My current "tire pressure monitor system (tpms)" is an 18 inch truck tire gauge, about $ 20 at most truck stops, which, when coupled to an eyeball and used often, seems to do the job. At my present age, I need to stop frequently anyway. Is anyone else using a trailer tire monitoring system? Has it helped you avoid tire problems? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes"http://tinyurl.com/y739x4 * * * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org |
Raphael Warshaw wrote:
On Jul 24, 10:47 am, Eric Greenwell wrote: After a trailer tire blowout last year, I installed a remote monitoring system that displays the trailer tire pressure on command, and alerts me automatically if the pressure drops. I don't know how effective this will be in avoiding tire problems, because it's possible tread separation can occur even if the pressure is OK, but at least I won't be driving on under-inflated tires. There are several systems that one can choose from. I'm using PressurePro, which is about $150 for the monitor and $50/tire for the sensors. I also put them on my tow vehicle, so it was $650 for the two trailer wheels and the six RV wheels. It was easy to install and seems Hi Eric, I tried a similar system on my semi and it didn't work reliably, most likely due to the 70 foot length of the unit. snip My drivers had frequent tread separations and blowouts (about two a month) in the 10 years before the Cat's Eyes" were installed but only two blowouts in the 10 year period I owned the truck afterwards, It sounds like you've taken care of your problem. PS: My current "tire pressure monitor system (tpms)" is an 18 inch truck tire gauge, about $ 20 at most truck stops, which, when coupled to an eyeball and used often, seems to do the job. At my present age, I need to stop frequently anyway. I went to the remote monitoring after several flats on the motorhome, despite obsesssive pressure checking of the tires. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Jul 24, 7:05*pm, Eric Greenwell wrote:
Raphael Warshaw wrote: On Jul 24, 10:47 am, Eric Greenwell wrote: After a trailer tire blowout last year, I installed a remote monitoring system that displays the trailer tire pressure on command, and alerts me automatically if the pressure drops. I don't know how effective this will be in avoiding tire problems, because it's possible tread separation can occur even if the pressure is OK, but at least I won't be driving on under-inflated tires. There are several systems that one can choose from. I'm using PressurePro, which is about $150 for the monitor and $50/tire for the sensors. I also put them on my tow vehicle, so it was $650 for the two trailer wheels and the six RV wheels. It was easy to install and seems Hi Eric, I tried a similar system on my semi and it didn't work reliably, most likely due to the 70 foot length of the unit. * snip My drivers had frequent tread separations and blowouts (about two a month) in the 10 years before the Cat's Eyes" were installed but only two blowouts in the 10 year period I owned the truck afterwards, It sounds like you've taken care of your problem. PS: My current "tire pressure monitor system (tpms)" is an 18 inch truck tire gauge, about $ 20 at most truck stops, which, when coupled to an eyeball and used often, seems to do the job. *At my present age, I need to stop frequently anyway. I went to the remote monitoring after several flats on the motorhome, despite obsesssive pressure checking of the tires. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes"http://tinyurl.com/y739x4 * * * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org- Hide quoted text - - Show quoted text - Terrific Idea. I check my trailer hubs and tire surfaces at each pit stop along the way. I find that a $4.95 tire pressure guage from Walmart works great. Be sure to follow your tire manufacturer's recommendation. 50 psi for my Goodywar Marathon Radials. Run them on my boats and the glider trailer. Also, be very aware and critical of the sounds and feel of the trailer. Unusual vibrations, noises and handling almost always foretells tire failuer. |
On Jul 24, 4:05*pm, Eric Greenwell wrote:
Raphael Warshaw wrote: On Jul 24, 10:47 am, Eric Greenwell wrote: After a trailer tire blowout last year, I installed a remote monitoring system that displays the trailer tire pressure on command, and alerts me automatically if the pressure drops. I don't know how effective this will be in avoiding tire problems, because it's possible tread separation can occur even if the pressure is OK, but at least I won't be driving on under-inflated tires. There are several systems that one can choose from. I'm using PressurePro, which is about $150 for the monitor and $50/tire for the sensors. I also put them on my tow vehicle, so it was $650 for the two trailer wheels and the six RV wheels. It was easy to install and seems Hi Eric, I tried a similar system on my semi and it didn't work reliably, most likely due to the 70 foot length of the unit. * snip My drivers had frequent tread separations and blowouts (about two a month) in the 10 years before the Cat's Eyes" were installed but only two blowouts in the 10 year period I owned the truck afterwards, It sounds like you've taken care of your problem. PS: My current "tire pressure monitor system (tpms)" is an 18 inch truck tire gauge, about $ 20 at most truck stops, which, when coupled to an eyeball and used often, seems to do the job. *At my present age, I need to stop frequently anyway. I went to the remote monitoring after several flats on the motorhome, despite obsesssive pressure checking of the tires. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes"http://tinyurl.com/y739x4 * * * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org- Hide quoted text - - Show quoted text - The Cat's Eyes we used made it simple for my drivers to look at tire pressure. They were no help when the vehicle was moving. Several of them told me they could estimate pressure to a few pounds by thumping the tires with a "tire thumper", a device that looked like a Billy Club. When I challenged them, they couldn't come w/in 20 psi. I wonder if the problem you're having is due to heat buildup. If the tire pressure is ok when you start, still ok when you arrive where you're going and stilll ok the following morning, you've pretty much ruled out loss of air. Does your motorhome allow decent airflow around the tires? Most of the ones I've looked at cover more than half the tire with the bodywork, particularly the rear duals. Ray Warshaw |
I went to the remote monitoring after several flats on the motorhome, despite obsesssive pressure checking of the tires. I wonder if the problem you're having is due to heat buildup. I don't think so. One was due to a bolt through the tread, another a tear in the sidewall, and two from faulty valve stems. These were all rear tires, on duals, and I never felt any handling changes. By luck, only the one with the tear had to be replaced. I often check the tire temperature right after stopping just by placing a hand on them. It's a good way to see if any tire is running significantly hotter than the others. It's probably not a useful practice, now that I have remote pressure sensors, but you still have to visually examine the tires, regardless of how you measure the temperature. Bulges, partial separation, uneven wear, nails, etc, can often only be caught by eye. I've had the most tread problems with my trailer. I've removed one tire because it was wearing very oddly, two tires because they developed a bulge from partial tread separation, one tire because the steel belt showed through for a few inches on one edge, and one because the tread separated completely, taking the fender with it. This is over 140-150,000 miles of towing in a 10 year period. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
recommendation. *50 psi for my Goodywar Marathon Radials. *Run them on my boats and the glider trailer. *Also, be very aware and critical of the sounds and feel of the trailer. *Unusual vibrations, noises and handling almost always foretells tire failuer.- Hide quoted text - - Show quoted text - My understanding is that the correct tire pressure is recommended by the vehicle manufacturer and not the tire manufacturer. On a car, the correct tire pressure can be found in the operating manual or on the vehicle identification placard located in the driver's side door frame. The tire pressure on the tire sidewall is the pressure to carry the max load that the tire can handle. Following this reasoning, the correct tire pressure on the trailer should be the one the trailer manufacturer recommends even if the tire has a higher pressure listed on the sidewall. I checked this out with my tire store and they confirmed this. I have new ST rated tires that can handle 50PSI, but the store recommended 35 PSI. The trailer is noticeably more stable than the old P-rated tires that were on the trailer when I bought it. |
James D'Andrea wrote:
Be sure to follow your tire manufacturer's recommendation. 50 psi for my Goodywar Marathon Radials. Run them on my boats and the glider trailer. Also, be very aware and critical of the sounds and feel of the trailer. Unusual vibrations, noises and handling almost always foretells tire failuer.- Hide quoted text - - Show quoted text - My understanding is that the correct tire pressure is recommended by the vehicle manufacturer and not the tire manufacturer. On a car, the correct tire pressure can be found in the operating manual or on the vehicle identification placard located in the driver's side door frame. The tire pressure on the tire sidewall is the pressure to carry the max load that the tire can handle. Following this reasoning, the correct tire pressure on the trailer should be the one the trailer manufacturer recommends even if the tire has a higher pressure listed on the sidewall. This is a sensible approach to setting the tire pressure, as long as you are using the tire specified by the trailer manufacturer, AND you are loading the trailer to the same weight. People sometimes have problems getting the identical size (or getting the quality they want), or they didn't like how the original size performed (stability, speed rating, longevity), so they end up with a different type or size of tire. Following the tire manufacturer's recommendations does not mean using the max pressure listed on the sidewall, but using the inflation pressure from their load tables. Even that pressure can be properly exceeded in some circumstances; e.g., ST tires can be run be used over their nominal 65 mph rating (up to 75 mph) by increasing the pressure another 10 psi (assuming the wheel and tire are rated for the higher pressure). -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
| Thread Tools | |
| Display Modes | |
| FA: 1-Day-Left: 3 Books: SPACE SATELLITE and AIRPHOTO INTERPRETATION, REMOTE SENSING, ENVIRONMENTAL MONITORING... | Mike[_18_] | Aviation Marketplace | 0 | July 7th 07 02:14 PM |
| Tire tread wear vs inflation pressure | Ben Jackson | Owning | 22 | October 6th 06 05:35 AM |
| Trailer tire rims | Gary Carter | Soaring | 7 | January 21st 05 04:15 PM |
| Tire inflation pressure | Paul Lee | Home Built | 80 | November 19th 03 08:56 AM |
| Tire Stiffness & trailer swaying | chris | Soaring | 42 | October 22nd 03 04:51 AM |
