SZD-36 Cobra 15
Old July 26th 08, 03:01 AM posted to rec.aviation.soaring
Default SZD-36 Cobra 15
A friend is considering purchasing a SZD-36 Cobra 15 glider. Comments
from anyone having owned or flown this model aircraft would be
appreciated.
Terry/DG800B
Old July 26th 08, 03:14 AM posted to rec.aviation.soaring
Paul Remde
Hi Terry,
I think that it is the type owned by Matthew Sawhill in Ankeny, Iowa. He
would be a good reference. ... Or is it his glider that is for sale? Did
he move up to something else?
Paul Remde
appreciated.
Terry/DG800B
Old July 26th 08, 12:26 PM posted to rec.aviation.soaring
On Jul 25, 9:14 pm, "Paul Remde" wrote:
Hi Terry,
Paul Remde
appreciated.
Terry/DG800B
Sawhill flies a Foka 4.
Old July 26th 08, 03:17 PM posted to rec.aviation.soaring
GK[_1_]
On Jul 25, 10:01*pm, " terry-
appreciated.
Terry/DG800B
Please make sure that you have the translated copy of Polish
Maintenance Manual from SZD!
It is a beautiful wooden glider however as with any construction it
requires preventative maintenance. There has been an accident in
Alabama where a roman screw retracted from the lower spar (due to a
wear of supporting bushing) and wings collapsed during a high speed
pass. Maintenance manual calls for periodical replacement of those
parts and such a glider would not have been airworthy in Poland.
Regards
GK
Old July 26th 08, 07:45 PM posted to rec.aviation.soaring
Martin Gregorie[_3_]
Default Off thread topic: Roman Screw? Que?
pass.
What is a roman screw?
Is it the same type of wing fixing that the SHK used?
I've not seen the term before and a web search failed to find a suitable
definition.
martin@ | Martin Gregorie
gregorie. |
org | Zappa fan & glider pilot
Old July 26th 08, 09:19 PM posted to rec.aviation.soaring
GK[_1_]
On Jul 26, 2:45*pm, Martin Gregorie
pass.
definition.
martin@ * | Martin Gregorie
gregorie. |
org * * * | Zappa fan & glider pilot
- http://pl.wikipedia.org/wiki/%C5%9Aruba_rzymska
Old July 26th 08, 11:07 PM posted to rec.aviation.soaring
Tim Taylor
On Jul 26, 2:19 pm, GK wrote:
On Jul 26, 2:45 pm, Martin Gregorie
pass.
definition.
gregorie. |
-http://pl.wikipedia.org/wiki/%C5%9Aruba_rzymska
In the USA it would be called a Turnbuckle.
Old July 27th 08, 12:41 PM posted to rec.aviation.soaring
pass.
definition.
gregorie. |
Same here, but how, exactly, does that attach the wings? I can understand
that it might pull them together and onto the fuselage pickup pins, but
what locks the spars together?
Martin Simon's 3-view of the Cobra shows the spars apparently meeting at
the fuselage centre line and some sort of circular hatch above their
meeting point: that's why I asked if the Cobra used a similar mechanism to
the SHK.
gregorie. |
Old July 27th 08, 07:46 PM posted to rec.aviation.soaring
I think there is a misunderstanding. There are two main screws at the
spar but non of the similar to the linked element.
On of them is vertical and similar to the IS28B2 main pin mechanism.
This attach and secure the two wings. It's unlikely to have failure
here.
Second one is horizontal behind the pilots head. This mechanism adjust
the wings horizontal play. This has to be fastened and secured after
assembly. One of my friend took off without this step... I can imagine
that high stress together with this mistake can be deadly.
Cobra is a robust plane, designed for aerobatics. Because of this
purpose wings are really heavy. Flight characteristics are friendly,
no bad habit like at stdCirrus (all moving tail). Performance is
around dry stdCirrus, stdJantar.
Wheel retraction system is a tricky rotating mechanism, careful
maintenance is needed for proper operation.
Instrument panel is small, limited space for instruments.
Baggage compartment is big, XC equipment can fit easily.
Not all Cobra is fired with CG hook! Winch launch with nose hook is
much lower.
It's a wooden plane with some composite material. Surface waveness can
change a lot by temperature, humidity. So don't worry if your nice
Cobra looks ugly one day, it will be nice again after a while
Conenction mechanism below the control stick is a bit weak. It's a
screw adjusted conical system and as dusk usually get's into that
place regular adjustment is needed. Usually this adjustment is a
tricky balancing between low control forces and small play.
If you are interested about some pictures here is my Cobra page:
http://bauerj.fw.hu/Cobra15/
Cobra Parts ventus2 Soaring 8 August 19th 05 04:57 PM
COBRA TALON, COBRA SPOT Allen Thomson Military Aviation 0 December 9th 03 06:44 PM
FS-Cobra Ed Hollestelle Soaring 0 November 4th 03 10:24 PM
Cobra Weapons Mike Keown Military Aviation 2 July 30th 03 07:43 PM
