What are the recommended wire sizes for use in a glider?
Power? The only power is a radio and Cambridge Model 20 and LNav Speaker? Push to talk? Boom mic? Thanks for sharing your expertise, Fred |
Use the wire charts in the AC 43.13 to determine wire size and fuse or
circuit breaker. Remember, you're fusing for the wire, not the load. http://rgl.faa.gov/Regulatory_and_Gu...E?OpenDocument Jim |
On Sat, 26 Jul 2008 21:52:30 -0500, Fred Blair wrote:
What are the recommended wire sizes for use in a glider? Power? The only power is a radio and Cambridge Model 20 and LNav I wired mine with 13 amp UK triple flex power cable, denominated Earth (green/yellow stripe), Live (brown) and Neutral (blue). The Earth wire is common and fitted with a 4 amp fuse at the batteries. Live connects one battery to the radio (Filser ATR-500) and T&B via a 4 amp fuse at the panel. Neutral connects the other battery to both varios and the GPS via a 4 amp fuse at the panel. Both switched by a two pole push-on/push-off switch on the panel. I split the circuits so that, if forced to fit a transponder, I can put it, radio and T&B on one side and keep the varios and GPS separate. If push comes to shove, I care about having power for the varios and GPS more than I do about powering the rest. If I need a more flexible setup in future I can achieve that simply by replacing the switch and fuses on the panel. Speaker? One side of a piece of medium quality dual shielded cable. This is the cabling you'd use for a stereo interconnect between CD player and the preamp or between preamp and power amp. Its a figure 8 cable, each side being about 4 mm (5/32") in diameter. Push to talk? Lightweight 3 mm (1/8") diam shielded cable. Boom mic? Other side of the speaker's shielded cable. The speaker enclosure is on the cockpit wall alongside me and doubles as the boom mic mount. HTH -- martin@ | Martin Gregorie gregorie. | org | Zappa fan & glider pilot |
Fred,
1. For power especially, use ONLY Tefzel wire! This is aircraft quality wire with Teflon jacket that melts at a much higher temp than regular wire and does not give off the toxic smoke when it overheats that PVC coated wires do. You can buy it at Wings and Wheels. I would use 14 AWG wire to minimize power losses (or maybe as small as 16 AWG). 2. ABSOLUTELY mount a 3-5 amp fuse on each battery!!!!! If there is a profound short in the power wiring, this fuse will blow and you will not be sitting in a puddle of melted plastic and red hot wires. 3. For all other wires (boom mic, PTT, and speaker), I use 22 AWG single core shielded Tefzel wire in the harnesses that I build. 4. I like to use a master switch and fuses on the instrument panel and a good BUSS system for ease of troubleshooting and visual inspection. Larry "the _real_ cable guy" Goddard "Fred Blair" wrote in message : What are the recommended wire sizes for use in a glider? Power? The only power is a radio and Cambridge Model 20 and LNav Speaker? Push to talk? Boom mic? Thanks for sharing your expertise, Fred |
On Jul 26, 7:52*pm, "Fred Blair"
wrote: What are the recommended wire sizes for use in a glider? Power? *The only power is a radio and Cambridge Model 20 and LNav Speaker? Push to talk? Boom mic? Thanks for sharing your expertise, Fred Check the FAA advisory Circular Circular and elecrical supplies on my installation supplies web page http://www.craggyaero.com/installation_supplies.htm Richard www.craggyaero.com |
On Jul 27, 5:29*am, "01-- Zero One" wrote:
Fred, 1. For power especially, use ONLY Tefzel wire! *This is aircraft quality wire with Teflon jacket that melts at a much higher temp than regular wire and does not give off the toxic smoke when it overheats that PVC coated wires do. You can buy it at Wings and Wheels. *I would use 14 AWG wire to minimize power losses (or maybe as small as 16 AWG). 2. ABSOLUTELY mount a 3-5 amp fuse on each battery!!!!! *If there is a profound short in the power wiring, this fuse will blow and you will not be sitting in a puddle of melted plastic and red hot wires. 3. For all other wires (boom mic, PTT, and speaker), I use 22 AWG single core shielded Tefzel wire in the harnesses that I build. 4. I like to use a master switch and fuses on the instrument panel and a good BUSS system for ease of troubleshooting and visual inspection. Larry "the _real_ cable guy" Goddard "Fred Blair" wrote in message : What are the recommended wire sizes for use in a glider? Power? *The only power is a radio and Cambridge Model 20 and LNav Speaker? Push to talk? Boom mic? Thanks for sharing your expertise, Fred Yes, use Tefzel. However Tefzel is not Teflon, althought they are related and bother are trademarks of Dupont. You want Tefzel aviation wire, not Teflon coated wires you might find at electronic supply stores. Tefzel is more abrasion resistant and tougher than many Teflon insulated wires. Another advantage of aviation Tefzel wire is is it fully tin plated, which avoids corrosion that sometimes happens to untinned copper wire. Personally I would put an aviation circuit breaker right on the battery, 5 Amp or so - no spare fuses to have carry around or loose. 22AWG multi-strand is available and woudl be less prone to damage from the single strand breaking due to flexing or vibration (uckilly not much of that in gliders). Chief Aircraft is also a good source of Tefzel wire in the USA see http://www.chiefaircraft.com/airsec/...pply/Wire.html You should be using crimp connectors on this wire not soldering it. Use good quality, brand name (3M, Amp, etc.) crimp connectors, nylon not PVC jacketed, don't mix connector brands/models where they have to mate (e.g. there are subtle differences in blade connectors), don't use junk from a local auto parts store. Good connectors are available from many electronic supply companies. And using a good quality ratchting crimper. See previous threads on this. Previous posts mention using different types of wires. It s generally cosideered bad form to pull wires with different insulation jackets in the same harness/cable run. This is mostly an abrasion issue in high vibration environment or where pulling the cable bundle is a challenge so may never actually casue problems in gliders. I know different glider manufactures still do this but I cringe when I see a mess of Tefzel, PVC, rubber speaker cable etc. trying to pass for a wiring harness. A nice wiring job should look ultra tidy, use nylon cable ties, have enough slack in it at places so it is easy to connect/ install without damaging it, etc. Also think ahead about what might happen if you add more avionics/toys in future. You might want to avoid using lots of heat shrink to bundle wires since it is harder to add a wire to in future, and don't use cheap PVC heatshrink, use Polyolefin its less flamable and more abrasion resistant. You might want to use color coding or shrink on labels on the wiring to keep track of things. Darryl |
I gave a presentation on this subject of avionics wiring at the 2007
SSA convention. See http://derosaweb.net/aviation/presentations to download the presentation. It looses a little without my voice over but you will get the main points. Darryl - Please critique this if you get a chance. Couldn't agree more on the use of tefzel. It is an FAA requirement, not an option. I have seen lots of incredibly lousey glider wiring so I am on a "jihad" to get the word out to do better. Remember that your local DIY or electronics store does *NOT* have an aviation aisle. http://wingsandwheels.com/page5.htm has a good assortment of Tefzel as well as places like Aircraft Spruce and Wag Aero. Using rules of thumb on wire gauges can lead to mistakes. Should the main line from the batteries to the instruments be 12 gauge? Smaller? Larger? It all depends on the load. In a airplane (versus an glider) this can go from little to massive, so determining the gauge needs some careful analysis. Luckily the load of the avionics package in a typical glider is fairly standard (vario, computer/ recorder, PDA, transceiver) so 12 gauge is generally considered OK. I haven't analyzed the typical loading of a transponder so cannot comment further. Other control (ptt, gear warning) and audio (speaker, microphone) are low current affairs so I typically using 22-24 gauge which you can find in multiple wire bundles. Finally, my disclaimer. I am *NOT* a FAA certified avionics technician. I cannot sign a log book for a repair or perform the installation. You need to get your work done by, or overviewed by, a FAA licensed tech. Nuff said. My $0.02. - John DeRosa |
On Jul 28, 9:10*pm, ContestID67 wrote:
I gave a presentation on this subject of avionics wiring at the 2007 SSA convention. *Seehttp://derosaweb.net/aviation/presentationsto download the presentation. *It looses a little without my voice over but you will get the main points. Darryl - Please critique this if you get a chance. Couldn't agree more on the use of tefzel. *It is an FAA requirement, not an option. *I have seen lots of incredibly lousey glider wiring so I am on a "jihad" to get the word out to do better. *Remember that your local DIY or electronics store does *NOT* have an aviation aisle. *http://wingsandwheels.com/page5.htmhas a good assortment of Tefzel as well as places like Aircraft Spruce and Wag Aero. Using rules of thumb on wire gauges can lead to mistakes. *Should the main line from the batteries to the instruments be 12 gauge? Smaller? *Larger? *It all depends on the load. *In a airplane (versus an glider) this can go from little to massive, so determining the gauge needs some careful analysis. *Luckily the load of the avionics package in a typical glider is fairly standard (vario, computer/ recorder, PDA, transceiver) so 12 gauge is generally considered OK. I haven't analyzed the typical loading of a transponder so cannot comment further. Other control (ptt, gear warning) and audio (speaker, microphone) are low current affairs so I typically using 22-24 gauge which you can find in multiple wire bundles. Finally, my disclaimer. *I am *NOT* a FAA certified avionics technician. *I cannot sign a log book for a repair or perform the installation. *You need to get your work done by, or overviewed by, a FAA licensed tech. *Nuff said. My $0.02. - John DeRosa John, my only comment is I'd encourage people to look for the best quality *ratchting style* crimpers they can afford - for both Coax and for wire connectors. Using these tools often produce a night and day difference from non-ratchting style crimpers, the cheaper ones of which cannot possibly produce enough jaw pressure to create a correct connection. The brand name ratcheting crimpers tend to be just better engineered and the ratcheting mechanism helps ensure the correct pressure is applied (as long as you use the right connector for the wire gauge). There is a good article on crimpers for use in aviation wiring at http://www.aeroelectric.com/articles.html (and he is comparing an already better ratcheting crimper than many people would use with an even fancier one but the good thing is he is showing in detail what a proper crimp joint looks like). That web site also has lots of other interesting information and informed opinion on aviation electrics. While none of this is rocket science by any stretch, I still worry that if people are having to ask basic electrical questions then the best thing may be to find an A&P who can show you how to do professional wiring and look over your shoulder at your work. And to get a really professional job it might turn out to be cheaper to pay a trusted A&P to do it than buy special tools, a stock of Trefzel wire, etc. I know finding that A&P may be the issue in many cases. Darryl (Just an anal retentive glider pilot/owner and electronics geek, and not an A&P) |
On Jul 28, 11:38*pm, Darryl Ramm wrote:
John, my only comment is I'd encourage people to look for the best quality *ratchting style* crimpers they can afford - for both Coax and for wire connectors. I bought this crimper (http://www.westmountainradio.com/PWRcrimp.htm) a couple years ago to make up the Power Pole battery connectors (http://www.flyrc.com/articles/using_powerpole_1.shtml and http://www.westmountainradio.com/order_RC.htm#ppc) I use for making up in-cable connections. Recently I added the die assortment and have had very good results making up antenna cables and installing various terminals. -Tom |
For power especially, use ONLY Tefzel wire! Here we are again. Is Tefzel the best stuff to use these days? Yeah, pretty much, no disagreement there. Is it important to use good materials? Yup, pretty important. Is it the only stuff to use, the stuff that you must use? All-caps and exclamation point aside, it depends. I have only a couple of always/ never rules about aircraft wiring, and they're about fuses, not Tefzel. Comparatively speaking, I happen to think that how you wire things is more important than what you wire them with. Given the choice between organized bundles, well supported, appropriately fused, protected from abrasion, and kept away from moving parts, all executed in Electron Hut automotive wire, versus a rats nest of unmarked white Tefzel going every which way, I'll take my chances with the Electron Hut system. But, that's just me. I've written that all before. But here's some new information content: Be careful about drilling holes around wiring bundles, especially where you're drilling metal. In one of my current projects, we've found chips of aluminum swarf embedded in the Tefzel insulation of wires pretty deep within wiring bundles. We undertook a program to unwrap every accessible wiring bundle and clean out the chips, and now are taking special precautions to keep chips out in the first place. It's certainly a thing to think on. Thanks, Bob K. |
| Caption This !! (2 sizes) | Square Wheels[_2_] | Aviation Photos | 18 | December 18th 06 01:01 AM |
| instrument sizes | Bill Chernoff | Home Built | 9 | September 21st 06 09:28 PM |
| Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | Home Built | 6 | October 15th 04 09:51 PM |
| Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | General Aviation | 0 | October 12th 04 06:11 PM |
| Cockpit sizes of standard Jantar | goneill | Soaring | 2 | December 28th 03 12:29 PM |
