Filing IFR flight Plan in VMC
Old July 29th 08, 03:01 AM posted to rec.aviation.ifr
Cyberfly via AviationKB.com
Default Filing IFR flight Plan in VMC
MArk, thanks for the input ,, I did look at 61.3 but interpreted it
differently as IFR meaning IMC. So I guess the old guy was full of old crap...
lol... THanks for the info on this one. Im almost done with my required
items, hours, approaches, can even do ndb holds, radial holding, etc. The
plane I rent has ADF and VOR (KX155) and DME and also has a Garmin 430 so Im
learning both the old and new methods. I took my written and got a 96 on it..
so am glad to get that out of the way.. I should be ready for a check ride in
Sept.. thanks for the help.. ron..
Mark Hansen wrote:
I have a question for the group. Im working on my IFR ticket, and will be
finished in about another 2-3 months, depending on how much I fly (Im renting.
[quoted text clipped - 14 lines]
Thanks ron..
Ron,
Have a look at FAR 61.3 (e):
(e) Instrument rating. No person may act as pilot in command of a civil
aircraft under IFR or in weather conditions less than the minimums
prescribed for VFR flight unless that person holds:
(1) The appropriate aircraft category, class, type (if required), and
instrument rating on that person's pilot certificate for any airplane,
helicopter, or powered-lift being flown;
(2) An airline transport pilot certificate with the appropriate aircraft
category, class, and type rating (if required) for the aircraft being flown;
(3) For a glider, a pilot certificate with a glider category rating and an
airplane instrument rating; or
(4) For an airship, a commercial pilot certificate with a lighter-than-air
category rating and airship class rating.
Note that it says "under IFR *or* in IMC". There are also regs concerning
your currency of flight experience. I'll let you look those up as a homework
assignment :-)
One thing you *can* do, however, is practice instrument approaches. I suspect
this is what the "old guys" were talking about.
Although not required, you should consider only doing this when you have a
safety pilot, as it is not easy to twiddle with all the dials while still
keeping your eyes outside the cockpit looking for other traffic.
How are things going with your rating otherwise?
Best Regards,
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums.aspx/ifr/200807/1
Old July 29th 08, 03:02 AM posted to rec.aviation.ifr
Thanks everybody for the input on my question... ron..
Robert M. Gary wrote:
On an IFR plan, you are expected to go THROUGH even the occasional
cloud, which you can't do.
I would have thought that until the FAA ruled that helo instrument
students can file an IFR flight plan in a VFR only helicopter for the
purpose of flight training as long as they stay VMC. Go figure.
-Robert, CFII
Old July 29th 08, 03:05 AM posted to rec.aviation.ifr
Newps
Mark Hansen wrote:
You do not have to be under an IFR clearance to practice approaches. In
fact, some controllers will say "Practice Approach Approved" rather than
the normal "Cleared for the approach" to make this point clear.
That has nothing to do with it.
Old July 29th 08, 03:08 AM posted to rec.aviation.ifr
Newps
On Jul 28, 4:17 pm, B A R R Y wrote:
Real requests for approach usually include the "Are you rated and
equipped?" query if you're not arriving on an IFR plan.
I've never, ever been asked that in the US. Its customary in Mexico to
ask that when picking up an IFR clearance (not sure what they would do
if I said no )
-Robert
Controllers are only required to ask if you're rated and equipped if a
pilot flying VFR states he's in weather difficulty and would like an IFR
clearance.
Old July 29th 08, 03:31 AM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
IFR clearance.
Controllers are never required to ask if a pilot is rated and equipped when
he asks for an IFR clearance.
Old July 29th 08, 04:57 PM posted to rec.aviation.ifr
Everett M. Greene[_2_]
"Steven P. McNicoll" writes:
B A R R Y wrote:
That's what I'm talking about. A VFR aircraft arriving at an IFR
airport, so it needs an IFR approach. This is very common on Cape Cod
and the Islands. I hear Cape and Boston approach ask the question so
often, my rarely flying pax even know what it means.
Apparently an unnecessary local custom.
Given the sudden and unexpected weather conditions around
the Cape, it's not a bad idea to ask.
Old July 29th 08, 08:50 PM posted to rec.aviation.ifr
tscottme[_2_]
Yes, filing and flying solo IFR is great practice while working on your IFR
ticket, however it is illegal to accept an IFR clearance without being
qualified with the rating.
I know a guy that filed and flew numerous IFR X-C at night while building
time to qualify for the minimum time requirements for the IFR rating years
ago. All the trips were in VFR conditions at night in benign weather, but
IFR regs require the pilot receiving/flying an IFR flight plan to be
qualified and equipped. You can get away with it unless something goes
wrong, at which point you're either dead or in heap big trouble.
Scott
What Barack Obama learned from the Communist Party http://tinyurl.com/5bgbpu
Democrats to America's drivers: "Let them ride bikes."
http://tinyurl.com/5z5vg7
  #28
Old July 29th 08, 09:20 PM posted to rec.aviation.ifr
Robert M. Gary
Yes, IFR is different than IMC. IFR is "rules", IMC is "conditions".
-Robert
  #29
Old July 29th 08, 09:27 PM posted to rec.aviation.ifr
Bob F.[_2_]
So...when he did all this, did he log it as such and create this illegal
record? How did he justify this to the examiner when his logbook was
checked...or did the the examiner miss it. Did the CFII say anything about
this when the 8710 was filled out?
Regards, BobF.
"tscottme" wrote in message
IFR ticket, however it is illegal to accept an IFR clearance without being
Scott
  #30
Old July 29th 08, 10:02 PM posted to rec.aviation.ifr
Bob
And just to add....IA,"Instrument Airplane" is the rating on the
Airman Certificate. No such thing as an "IFR Rating" or "IFR Ticket".
Bob Moore
Flight plan hell, Tales of filing an ADIZ flight plan Michelle P Piloting 30 July 15th 05 06:28 AM
Vicinity Flight Filing Service Darrel Toepfer Home Built 3 May 12th 05 11:53 PM
filing IFR plan for VFR flight conditions Paul Safran Instrument Flight Rules 53 May 11th 04 03:07 AM
Flight Plan and Flight Log excel spreadsheet. Marco Rispoli Piloting 2 January 14th 04 09:12 PM
IFR flight plan filing question Tune2828 Instrument Flight Rules 2 July 23rd 03 03:33 AM
