Double Eagle + orphaned engine = a winner?
Old July 29th 08, 08:05 AM posted to rec.aviation.homebuilt
Anthony W
Default Double Eagle + orphaned engine = a winner?
After Bob Hoover's recommendation of the double eagle, I fond myself at
the DE website and thinking I've found my first (maybe only) plane.
I already have a stock 1600cc bug engine to use that is ready to put
together other than a few bits but I'd like to try Bob's suggestions and
go with the 78mm crank. Anybody have a good recommendation on a 78mm crank?
I will be turning the engine around and mounting the prop on the big
bearing end of the engine but I'm not sure how I'm going to do that
right now. The Great Planes rear drive looks overly complicated but the
only other system I've seen was on a German website a couple years ago
on a type 4.
I have an 1800cc engine sitting in a friend's basement (assuming he
hasn't tossed it) but I'm not sure if the increase power will balance
out the added weight. Then there's the high price of the 1800cc parts...
Suggestions, comments, slurs? Let me know what you think...
Tony
Old July 29th 08, 08:47 AM posted to rec.aviation.homebuilt
You can canvas the various importers/retailers. I assume you'll want
a VW journal.
Or you give Tony De Mello a call and have him make one up for you.
I hope you realize there will be quite a bit of clearancing with a 78.
You'e also going to need some serious spacers
-R.S.Hoover
Old July 29th 08, 06:03 PM posted to rec.aviation.homebuilt
Bob Kuykendall
On Jul 28, 11:47*pm, " wrote:
...I hope you realize there will be quite a bit of clearancing with a 78....
Oops, I think I slipped a groove somewhere. I thought you wrote in
_The Orphaned Engine_ that with a 78mm crank there was no machining
required:
http://bobhooversblog.blogspot.com/2...ed-engine.html
I also thought that "clearancing" was machining work on the inside of
the crankcase to remove material that would otherwise interfere with
the movement of the connecting rods. Or do you mean some other type of
machining?
Thanks, Bob K.
Old July 29th 08, 06:37 PM posted to rec.aviation.homebuilt
Copperhead144
go with the 78mm crank. *Anybody have a good recommendation on a 78mm crank?
right now. *The Great Planes rear drive looks overly complicated but the
on a type 4.
out the added weight. *Then there's the high price of the 1800cc parts....
Suggestions, comments, slurs? *Let me know what you think...
Tony
Oddly I'd never considered the Double Eagle even after reading about
it, I'd become more fixiated on the Legal Eagle or Texas Parasol
concept, but both of those would end up as LSA in the end for my use
and not UL. This now make's the DE look even nicer, more of that
stepping outside of the box aspect of project development. Thank's
folk's I'll be pondering this a bit.
Joe
Old July 29th 08, 08:37 PM posted to rec.aviation.homebuilt
required:
machining?
In so far as I know, clearancing and other 'hand-work' is not
considered 'machining' in that it is a 'go/no-go' sort of thing. You
simply remove metal until you have adequate clearance.
As a point of interest, the last air-cooled engines made by Volkswagen
were apparently designed to accept a 74mm crankshaft, which will drop
into a 1600 crankcase without any clearancing at all. With 85.5mm jugs
this gives a displacement of 1699cc and appears to reflect
Volkswagen's assumption that the USA would not adopt the stringent
California air-pollution laws.
The normal method of increasing the VW's displacement is to replace
the stock 85.5mm cylinders with those having a larger diameter. This
requires boring a hole, centered on the existing hole in the
crankcase, and a matching hole in the heads Most don't realize it but
the accuracy of these eight is of critical importance to the
durability of the engine. This is a task best done on a milling
machine. Unfortunately, most VW conversions are done with portable
tooling and the accuracy is all over the map.
By increasing the STROKE rather than the bore you not only eliminate
the need to machine the eight holes, you have eliminated a chronic
source of compression leaks that arise from inaccurate spigot bores.
-R.S.Hoover
Old July 30th 08, 12:33 AM posted to rec.aviation.homebuilt
Anthony W
-R.S.Hoover
I was assuming that this was hand work but I wasn't sure. Thanx for
cleaning it up. In the mean time I will be looking for a good deal on a
78mm crank.
Tony
Old July 30th 08, 02:20 AM posted to rec.aviation.homebuilt
78mm crank.
Dear Tony,
A 78mm stroke under a stock jug will give you a displacement of
1791cc.
76mm x 85.5 = 1745
74mm x 85.5 = 1699
You may wish to consider ANY crank having a throw greater than 69 but
less than 82. But your primary qualification is the QUALITY of the
crank. Unless the thing is offered at a give-away price (meaning you
can always pass it along to the dune-buggy crowd) full blue-printing
and NDT must be a condition of sale. (This is why it makes good sense
to have someone like Tony make the crank to your specs.)
For ANY increase in stroke you will see an increase in displacement
AND an iincrease in torque. But what makes this configuration of
value in FLYING VW conversions is that the altered ratio of bore-to-
stroke causes the torque to peak BELOW the rpm. This phenomenon may
be enhanced by careful selection of the cam. In fact, even the stock
cam can provide a significant improvement by simply retarding its
timing by a few degrees. This allows you to use a longer propeller
with a more aggresive pitch, resulting in greater efficiency.
If that sounds too good to be true, it is :-) The greater efficiency
is the product of tailoring your valve-train geometry to take full
advantage of the engine's configuration. This is an alien world to
the typical dune-buggy guru for whom success is defined as maximum
horsepower at high rpm. What you will end up with is an engine that
produces high torque at a relatively LOW rpm, making it the perfect
choice for slinging a prop. You won't find a lot of information on
engines of this configuration... unless you study aircraft engines.
Or industrial engines.
Keep in mind that the changes are relative to the change in
displacement and the ratio of bore to stroke. You will see anything
very dramatic but you will see your usable power coming in at a lower
rpm. That lower rpm will lend itself to the engine's durability. It
may not be much but over the life of the engine, it is signifcant;
more than enough to justify the configuration even if the output is
the SAME as before.
-R.S.Hoover
Old July 30th 08, 06:05 AM posted to rec.aviation.homebuilt
flybynightkarmarepair
All the AFFORDABLE forged cranks come from China these days, and
seemingly from the same supplier. I got my 82mm crank from California
Imports. I also like Aircooled.net for parts. I can't recall if my
engine builder magnafluxed it; I know he balanced it (as an assembly,
with the rods, the prop hub and extension, and the dynamo hub at the
fan end) and he said it took a bit of grinding to get it to come into
balance. All the journals miked out OK.
DeMello will be taking a German forged crank as a core, and welding
and grinding on it to make what you need. His prices are pretty
reasonable, IMHO, but it will be more than a forged ChinCom crank.
You'll have a choice of journal sizes either way. Chevy journals lock
you into new rods (also ChinCom, at pretty attractive prices these
days). But they will mean less clearancing. The smaller journals
also mean a weaker, less stiff crank. A bad thing in a high RPM
engine, where the inertial forces of the rods and pistons try and yank
the pistons out through the top of the heads. A weak crank will, at
high RPM, let the pistons hit the heads...but at our low RPMs, a case
can be made that Chevy Journals are OK. But then we put prop loads on
that crank...you make your choices.
"Clearanced" VW Journal rods are just run through a grinder so they
don't hang up as much. If you're really on the cheap, you can do that
yourself, just make sure you keep them reasonably balanced, both the
whole rod, and the "big end" and "Little end", see later issues of the
Idiot Book, the HiPo pages in the back, for that. Clearancing the
rods in this way weakens them. You may not need to do this for a 78mm
crank, or you may decide to clearance the case a little more, and
leave the rods alone. IF you are clearancing the case yourself,
you'll need a die grinder.
Steve Bennet's book is a really good reference for building any
stroker engine, and I highly recommend it.
Reusing your existing pistons with the longer stroke crank will pop
the pistons right out the top of the jugs at TDC (negative Deck
Clearance), thus the need for the spacers Veeduber alluded to. Or
new pistons; the "B" style for stroker cranks, with the rod pin moved
down. (Although there is not much call for "B" 85.5mm
pistons.....they may be hard to source). My understanding is that
using the "B" pistons, and a 78mm Chevy Journal crank makes a very
nice stroker engine, with little if any clearancing needed, and few if
any spacers, while still keeping the compression low. I've never
built such an engine, and it would require new pistons and cylinders,
a new crank, and new rods. Starting to get Not So Cheap. Maybe better
you should just slap the Flywheel end hub and extension on your 1600
and have done with it...your call.
on a type 4.
Use the new-ish Great Plains "Flywheel Drive" bits. Heavily
influenced by Veeduber.
Old July 30th 08, 06:23 AM posted to rec.aviation.homebuilt
Anthony W
on a type 4.
All great info and thanks for sharing but while I'm cheap, I'm not
overly so. I have a new set of cylinder and most of what I need to
build a 1600, I think an extra $500 or $600 into this engine is going to
be worth it. I just want to cover all my options before I spend another
dime on the project.
I was a motorcycle mechanic for more years than I like to admit but this
airplane stuff is rather foreign to me and I'm glad there is some one
like Bob that is willing to share his knowledge with thick headed folk
like me... Anyway I'm not afraid to do a little grinding on the case to
make things fit.
Tony
Orphaned Engine [email protected] Home Built 17 July 23rd 08 12:41 AM
Westland Wyvern Prototype - RR Eagle Engine - Rolls Royce Eagle 24cyl Liq Cooled Engine.jpg Ramapo Aviation Photos 0 April 17th 07 10:14 PM
Was the Pratt & Whitney Double Wasp the best engine of WW II? Dave Kearton Aviation Photos 18 January 12th 07 08:20 PM
Double Eagle (AEG - Albuquerque NM) Fly-in 8-9 Oct 2005 Ron Lee Piloting 1 October 1st 05 07:52 AM
Double Eagle NM (AEG) Fly in 8-9 Oct 2005; Balloon Fiesta time Ron Lee Piloting 4 September 2nd 05 04:44 PM
