Passed CFI Knowledge Test
Old August 4th 08, 03:11 PM posted to rec.aviation.ifr,rec.aviation.piloting
Kobra
Default Passed CFI Knowledge Test
Flyers,
I just passed the CFI Knowledge test today but I have some questions for the
group. Sure I could look these up, but lets stimulation some discussion.
Here are some questions that I do not know if I answered correctly. The
verbiage may not be word-for-word but you should get the idea:
1) In a rectangular course lesson, how do you (as an instructor or student)
determine the distance to fly from the rectangular field chosen?
a) The wind
b) The size of the field
c) The steepness of the bank required / desired
2) How is VMC affected by an increase in altitude?
a) VMC goes up
b) VMC goes down
c) VMC remains unchanged
3) If taking off from an airport w/o a control tower inside Class C
airspace you are required to?
a) contact ATC before taking off to receive permission to enter controlled
airspace
b) takeoff without permission, but contact ATC as soon as practical
c) contact is not necessary if you are departing the controlled airspace
4) What is the speed limit in Class B airspace
a) 200 Knots
b) 250 Knots
c) Unlimited
Kobra
Old August 4th 08, 06:54 PM posted to rec.aviation.ifr,rec.aviation.piloting
gatt[_5_]
Kobra wrote:
Flyers,
Don't want a wide pattern burning up fuel and keeping you out of glide
range, but you also don't want student pilots pulling 60-degree banks to
fly a tight pattern. (Pax probably don't appreciate it either.)
b) VMC goes down.
Less thrust, although this still confuses me somewhat in terms of
indicated airspeed.
Although, some satellite airports (Pearson, IIRC) have freqs posted to
contact ATC before departure.
b) 250 knots
Tricky question: BELOW Class B is 200 knots.
-c
Old August 4th 08, 07:54 PM posted to rec.aviation.ifr,rec.aviation.piloting
Mark Hansen
It's been a while since I flew there (1985?), but at that time, it was
just a courtesy notification "... Cessna departing runway ...", and
not requesting a clearance.
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
Old August 4th 08, 08:37 PM posted to rec.aviation.ifr,rec.aviation.piloting
Morgans[_2_]
Reason it states "as soon as practical" is because at some airports in the
Class C, you can not raise the Class C on the radio, until you get into the
air a little bit.
Jim in NC
Old August 4th 08, 09:47 PM posted to rec.aviation.ifr,rec.aviation.piloting
Michael Huber[_2_]
gatt wrote:
2) *How is VMC affected by an increase in altitude?
b) VMC goes down.
indicated airspeed.
As I understand it, it's the following: The airplane's behavior is only
dependent on indicated airspeed, as that reflects the forces the air exerts
on the plane. So, at any given _indicated_ airspeed, the forces the rudder
is able to generate are the same. However, the forces the engines are able
to generate decrease with altitude. Thus, VMC indicated is going to be less
the higher you are.
Old August 4th 08, 10:43 PM posted to rec.aviation.ifr,rec.aviation.piloting
Bertie the Bunyip[_25_]
"Kobra" wrote in
Flyers,
for the group. Sure I could look these up, but lets stimulation some
discussion. Here are some questions that I do not know if I answered
correctly. The verbiage may not be word-for-word but you should get
the idea:
student) determine the distance to fly from the rectangular field
chosen?
a) The wind
Depends on the airplane, doesn't it?
try it on one field and if it's not working out, try it on another, but
for most trainers about a mile per leg is probably pretty good.
a) VMC goes up
b) VMC goes down
Best thing here is to think it through. All the elements... power,
aerodynamic authority, etc.. The answer is pretty obvious, really..
Bertie
Old August 4th 08, 11:45 PM posted to rec.aviation.ifr,rec.aviation.piloting
B A R R Y[_2_]
jeremy wrote:
a) 200 Knots
b) 250 Knots
c) Unlimited
That is an incomplete question; which country, what altitude?
I'm guessing he's asking about the FAA CFI test? G
If he is, the same question is on the Private, and as I recall,
Commercial written.
Old August 5th 08, 01:04 AM posted to rec.aviation.ifr,rec.aviation.piloting
B A R R Y[_2_]
jeremy wrote:
That would be 250 then. You have to watch it in Canada the definitions
are different :-)
Does Canada call flight instructors CFI's and CFII's?
Old August 5th 08, 01:28 AM posted to rec.aviation.ifr,rec.aviation.piloting
Bob Moore
Nor do we here in the USofA.
Bob Moore
Flight Instructor, Airplane Single Engine; Instrument Airplane
Old August 5th 08, 06:09 AM posted to rec.aviation.ifr,rec.aviation.piloting
Ron Garret
Are there non-towered airports inside Class C? I thought they all had
little cutouts like CCB has.
rg
knowledge test passed, on to accelerated training [email protected] Instrument Flight Rules 1 September 15th 04 01:08 PM
Private Written Test Passed ! Greg Piloting 3 March 31st 04 05:57 PM
FAA Knowledge test Dave Piloting 15 October 31st 03 06:32 PM
FAA Knowledge Test Results Richard Moore Instrument Flight Rules 4 October 12th 03 07:10 AM
FAA Knowledge Test Results Richard Moore Simulators 3 October 12th 03 04:48 AM
