Best dogfight gun?
Old December 13th 03, 06:04 PM
Greg Hennessy
On Sat, 13 Dec 2003 11:21:41 -0600, Alan Minyard
Your choice of language belies any claim to veracity
on your part.
So tell us about this cannon made by an 'enemy nation' (sic) again. The one
you claimed would be impossible to get spare parts for.
Your inability to make any resembling a cogent argument is noted. Have you
been taking lessons from Tarver ?
greg
Once you try my burger baby,you'll grow a new thyroid gland.
I said just eat my burger, baby,make you smart as Charlie Chan.
You say the hot sauce can't be beat. Sit back and open wide.
  #212
Old December 13th 03, 08:29 PM
Chad Irby
Ed Rasimus wrote:
Absolutely correct, and a remarkable effort. But, the discussion was
regarding the call for strafe. The image that conjures up of a Bone
rolling in and lining up for a blast of maybe eight internal
wing-mounted 20mm Vulcans delivered at 1800 feet slant range.....
Well, if you're looking at serious ground-attack work, why not just put
in some GAU-8s in the mix?
Or if you're really going to be mean, fly a C-5 over at 40,000 feet and
drop a few hundred pallets of lawn darts out the back...
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
  #213
Old December 13th 03, 08:30 PM
Tony Williams
"Brett" wrote in message ...
The RAF dropped the BK27 cannon from their Typhoon's because it was
supposedly "too expensive". The defense budget may be large it isn't
bottomless.
But that wasn't 'too expensive' compared with another gun: that was
'too expensive' to have a gun at all - a very different conclusion.
Tony Williams
Military gun and ammunition website: http://www.quarry.nildram.co.uk
Discussion forum at: http://forums.delphiforums.com/autogun/messages/
  #214
Old December 13th 03, 08:33 PM
Lyle
On Sat, 13 Dec 2003 17:06:33 GMT, Ed Rasimus
On 13 Dec 2003 00:21:53 -0800, (Michael E. Kelly)
Ed Rasimus wrote in message
It wasn't a readily available option when initially called for.
Remember that Afghanistan is a long way from anywhere. At the time of
Anaconda, the primary tactical assets were carrier based and flying
extremely long duration, multiple refueling sorties. The flexibility
for immediate on-call CAS was not available.
Ed,
I take issue with your last statement, unless you're limiting the
scope of your answer to tacair only. My wing flew 300 sorties during
Anaconda and dropped 845 JDAM's and 24 Mk84's providing excellent on
call air power. Granted we're a heavy bomber and could fly 1000 miles
and then loiter for a few hours, which the fighter guys couldn't do.
I'm sure BUFDRVR can chime in with the BUFF's contribution to CAS in
Afghanistan. It only goes to back up what you've been saying, methods
of delivering CAS are changing.
Cheers,
Michael Kelly, Bone Maintainer
Dale Brown will probably install swiveling M-61s in the swing-wing for
his next fictional foray. "Flight of the Young Pup."
Ed,
What is the difference between direct close airsupport, and close
airsupport, or is it just all lumped together and called close air
support.
  #215
Old December 13th 03, 08:38 PM
Tony Williams
(Bertil Jonell) wrote in message ...
Paul J. Adam wrote:
UAVs are going to be really tough gun targets: just look at the size of
them. Aircraft guns aren't a good option, if only because you're going
to need so many rounds per target.
Against so small targets a proximity fuzed shell, or a timed-fuzed
cannister round would be much more effective. The size means that you
don't need direct impacts of 20mm+ to bring it down, and the increased
probability of getting a hit with preformed fragments/subprojectiles
might[1] compensate for the small size.
[1] Well, I think so at least But you'd need to run tests on it to
be sure
Airburst ammo has been available for a long time for Russian 30mm
aircraft guns: it is effectively shrapnel, releasing a cone of
tungsten-alloy subprojectiles once the time fuze detonates, and is
intended for ground attack so the time fuze has a fixed setting. OTOH,
current US airburst experiments in 30x173 involve setting a fuze at
the muzzle, like the Oerlikon AHEAD 35mm round. There would be
technical problems in adapting this to firing from a moving aircraft
at another moving target, but it's basically a matter of FCS
programming. This could be deadly against UAVs (and troops on the
ground, as well).
Tony Williams
  #216
Old December 13th 03, 08:46 PM
Chad Irby
"Paul F Austin" wrote:
"Chad Irby" wrote
The "little bitty" UAVs out there are in the "fly past really quick and
turbulence does the job" category...
There really aren't "a lot" of large UAVs. They (and their payloads) are
quite expensive and the number look limited for the foreseeable future.
Funny, I keep finding quite large ones. Like the Predator, the
Darkstar, the Global Hawk, or one of several Russian designs that are
basically reworked large cruise missiles or former target drones.
A lot of modern UAVs are in the 1000+ lb weight class, which certainly
makes them big enough to shoot down.
The Little Bitty UAVs on the other hand look to be ubiquitous.
Turbulence might do the job or maybe not. These aren't ultralights
with nil control authority. If they're flying low enough to prevent
recovery, then the fighter doing the buzz pass is in fair danger of
CFIT, especially in combat.
Just fly around it and get it in trail. If a 727 can knock a Piper Cub
out of the air at a mile or so lead range, an F-22 should be able to
wipe a small UAV out at a couple of hundred yards or so.
And anything that's too small to shoot down with a gun is *certainly*
too small to shoot down with a modern aircraft missile.
cirby at cfl.rr.com
  #217
Old December 13th 03, 08:47 PM
Brett
| bottomless.
Well that would depend on when during the development process you
determined the cannon you had allocated space for and development effort
on was "too expensive". The conclusion you actually come to with the RAF
Typhoon's is that the RAF did not have an alternative "cheaper" weapon
that would fit in the space formerly occupied by the BK27 without any
airframe development effort and associated increased cost.
  #218
Old December 13th 03, 08:50 PM
Alan Minyard
On Fri, 12 Dec 2003 12:47:55 -0500, "Paul F Austin" wrote:
"Alan Minyard" wrote in message
On Thu, 11 Dec 2003 20:39:51 +0000, Greg Hennessy wrote:
On Thu, 11 Dec 2003 13:21:39 -0600, Alan Minyard
Tony Williams
Military gun and ammunition discussion forum:
You have no idea. The Mauser was an inferior weapon.
Al Minyard
ROFLMAO! How did you draw that stunning conclusion.
greg
Well, if you signature is and indication, you are involved in the use
of serious drugs, not someone that I would assume could make
rational judgements. The fact that the US chose a different system pretty
much tells me that the Mauser was (and is) an inferior system.
Al, I'm as patriotic as any, but...
One of the illuminating moments in my engineering career was when I listened
to five companies worth of very imminent engineering teams bidding to the
same set of requirements, each proving catagorically that their wildly
different offerings were each the_only_solution to the customer's problem,
with utter sincerety and honesty. Then the customer elected to buld
internally rather than buy.
Most selections are_very_closely balanced and most of the offerings will do
the job. The difference between winner and also ran will turn on
features_other than_technical performance. In fact, it's the rare
procurement these days that offers any evaluation points at all for
performance above the "goal" level. Instead heaviest weighting is usually
given to Cost, delivery, cost and oh, yes cost. Did I mention cost?
I would certainly agree, however the Mauser offering was significantly
different from the M-61 derivative. Different design philosophy (revolver
vs "gatling" gun). The ammunition is also significantly different. If both
weapons were designed to a definitive solution (rate of fire, same
ammunition, etc) then your contention would be more accurate.
Al Minyard
  #219
Alan Minyard
On 12 Dec 2003 19:27:40 -0800, (Tony Williams) wrote:
Chad Irby wrote in message m...
Chad Irby wrote:
Part of that "cost effectiveness" appeared to be a lowball pricing
structure that fell through on closer examination.
Do you have a source to support that? You may be right, but I like to
work on hard info rather than forum gossip.
This talks about the cost issue:
http://stage.defensedaily.com/VIP/ddi/previous/ddi0927.htm#A1
"We had a cost-growth problem that forced a recompetition," he said.
"Affordability is a prime concern of the program. Based on that we were
forced to recompete the gun system integration. We selected our
supplier on a best-value case."
Thanks for that link. I had to smile at: "GD had initially offered its
GAU-12 25mm gatling cannon for the JSF in July 1999, but withdrew its
proposal in February 2000." since that was only after L-M had selected
the BK 27 - in the UK, we call that 'spin'
A "cost-growth problem" for an established weapon like the Mauser means
"they tried to stick us for some more cash after they got the contract."
The usual response in that case is to tell the supplier to keep the
price down or lose the contract. With a potentially huge market for
the F-35, Mauser would have to have been mad to throw it away. There
is no inherent reason that I am aware of that the BK 27 should have
been more expensive to make than the GAU-12/U, particularly since both
would have been made in the USA (unless they're planning to save money
on the initial batch by re-using guns from the AV8-B). I remain
suspicious that GD was both the gun integrator and the supplier of the
GAU-12/U; they weren't exactly innocent bystanders.
Tony Williams
The BK-27 that was under consideration for use in the F-35 was a completely
new system. The gun from an AV8 would not work. Linked vs
linkless ammo, etc.
Al Minyard
  #220
Old December 13th 03, 10:15 PM
Kevin Brooks
"Paul J. Adam" wrote in message
In message , Kevin
Brooks writes
Risky, perhaps. Indicative of serious pressure on the EP budget,
certainly. Personally I'd be a little less inclined to abandon a
capability that was actually built in, but it is more expensive than it
seems to maintain (it's not just guns, or even ammunition, but the
training burden)
The training burden? For gosh sakes, you already have to have armorers,
Trained gun-fitters and repair teams, and the logistic pipeline to
support them, cost money.
But you are claiming we would retain the gun pods--don't they already then
have to maintain these skills?
and
I doubt that including a periodic requirement for the pilots to do some
range work would be that great a burden--it is after all what they do
during
peacetime.
Try costing up the aircraft,
They have to bore holes in the sky anyway--having them chunk up hours on the
range instead of doing touch-and-go's seems to be of little impact. Keep in
mind that the strafe mission is not their highest priority training event.
the range,
The range would undoubtedly be a multi-use facility (i.e., unlikely to have
a range dedicated to strafe only), so that is no argument.
the targets (whether air-to-air
or air-to-ground),
Yeah, putting up a target panel of fabric must be extremely expensive...
the equipment to provide useful feedback and training
(because 'pulled trigger, gun made loud noise, came home, landed' is not
useful training) and it adds up with alarming rapidity.
Gee, they have to grade all kinds of exercises already--I'd suspect a bit of
gun camera footage of the strafe pass would be acceptable.
How much of a CAS stack existed that far from the nearest airbase?
Apparently a pretty decent one including F-15E's, F-16's, and A-10's as
well, from what I have read of the reports on Anaconda.
I'd heard the A-10s got pulled early due to hot/high problems, and given
the frequent sniping at the F-16's range I'm surprised to hear it doing
significant long-range loiter.
The 354th FW *did* do "significant long-range loiter" during that operation
with their F-16's, so that argument is meaningless.
How effective were the anecdotal strafing runs? It's a tough problem to
judge. For sure nobody's going to stand up and say "the CAS birds came
in and strafed, but it didn't seem to do much good against the
scattered
and dispersed enemy we were fighting" - when someone takes a risk to
help you, you _don't_ go public saying they endangered themsevles for
little result.
Actually, one senior US Army commander *did* sort of hammer the CAS
effort
after-the-fact, though not specifically directed at the strafe
operations.
Some of his comments were valid, and some were likely as not an attempt
to
shovel off blame that he should have borne on his own shoulders. As to
effect, the reports I read varied, with some indicating that in some
instances they ended up having to resort to using PGM's a lot closer than
they originally cared to in order to finally destroy the target (and in
at
least one case that almost literally "blew up in their face", so to
speak,
yielding a quick, "you almost got us with that last bomb" from the CCT).
I
recall two reports indicated that the strafes were on target and at least
suppressed the bad guys (and sometimes suppression is the best you can
hope
for).
According to
http://www.csis.org/burke/hd/reports...irwar_exec.pdf
the US flew 17,500 combat sorties over Afghanistan, of which you've
heard of several failed strafes ('danger close' sorties where the gun
passes failed to stop the enemy, leading to 'even more dangerously
close' use of other munitions) and two cases where the enemy was
'suppressed'. Guesstimate two aircraft in each case for eight sorties
with a 50% success rate.
Failed to stop the enemy? How much suppression did they achieve? And here
you go with your McNamaresque number crunching again... war cannot always be
resolved into neat little statistical piles. Witness the recognition lately
of the fact that the old attrition models for simulations are just plain
inaccurate as all get out.
It's not an enormously convincing argument that the existing gun
armament is a potent and essential CAS tool, is it?
Your strawman. I have said from the beginning that it is a last resort,
only-when-nothing-else-should-be-tried-first tool, and as such preserves
flexibility for the system beyond that which exists sans guns. But hey, you
tell me what the groundpounder who finds himself with a nasty situation
located in that 25-to-500 meter danger-close gap in CAS coverage that
results when no gun is available is supposed to do.
Either the gun needs
to be made significantly more effective in order to increase its
lethality and utilisation... or it needs replacing with something better
able to provide _effective_ close fire to troops in combat.
But this is, by my own admission, a "niche" capability that probably does
not merit much more resource dedication than it has already received. A
nice-to-have capability for use when none of the other tools are initially
suitable or acceptable.
Burdening most of your tactical air fleet with a thousand pounds of
ballast that's used on 0.05% of combat sorties is
I guess the USAF is utterly clueless then, as they seem to disagree with
you. I'd note that a fair portion of your own RAF was apparently not happy
with the loss of the gun from the Typhoon. Do you know something none of
these folks do?
As well as getting into ricochet hazard, bringing up problems of target
fixation, all to employ a very limited weapon system. (Actual
effectiveness data is hard to come by for strafing, except that many
aircraft doing it seem to have shot themselves dry... suggests they ran
out of ammunition before their guns killed all the targets)
Well, if you don't even *have* a gun, that is not going to be a problem,
is
it?
And you describe above how in at least one case, strafing failed to
deter the enemy and heavier weapons had to be resorted to.
You are really having a problem with the idea that the ground commander
would prefer to work *up* the risk ladder, don't you? Not jumping in and
placing his ground troops at maximum risk from the outset? Odd, since you
were so risk adverse when it came to allowing the CAS assets down into the
weeds to make these sort of attacks.
Similarly, one drag on developing a weapon for danger-close CAS is the
airy claim that "that's what the gun is for" when its effectiveness is
patchy (some reports of 'suppression' when it was used, but others where
the enemy declined to be deterred)
Gee, if it really sucked so much, why did those CCT's keep calling for
strafe as opposed to bombs in the first place?
Of course, neither will the CCT (or its supported ground combat element)
get the CAS effort they want either... As to the value of the guns, it is
interesting to note that one of the comments that came out of the
Anaconda
participants was, "Every light division needs a supporting *squadron* of
AC-130's." Pie in the sky statement that may be, it points out the value
those ground folks placed upon aerial gunfire support. Imagine a scenario
where the bad guy has a better MANPADS capability and you are stuck in a
similar (daytime) situation--which would you rather commit to making
strafing runs to suppress the bad guys, fast-movers or that AC-130? If
you
are as concerned about risk as you claim, you know what the answer to
that
one is.
Sounds like there's a need for a similar weight and accuracy of fire as
the AC-130 can deliver, but with the survivability of a fast jet.
In your scenario, neither aircraft is particularly suitable: if the
AC-130 can't survive the SAM threat, repeated passes by fast movers will
also get them speared by those improved MANPADS (especially since
they're delivering a lot less firepower and so *need* to make multiple
passes through the weapon envelope of an alerted enemy... this is what
is technically known as a Really Bad Idea).
Really Worse Idea is not being able to deliver support when the risk is
assessed and accepted.
Where's the evidence of serious effectiveness to compensate? "This was
available, it was used, therefore it must be hugely lethal and vitally
necessary" is a shaky proposition.
Better than, "This was not available, so it could not be used, and we
lost a
lot of guys", IMO.
So where's the evidence for that?
The same place as your evidence that the gun is worthless--a product of the
argument. If you don't have a gun, and the bad guys are in so tight that you
*can't* resort to a bomb, then you are effectively saying CAS is out of the
picture, so any increased losses could be attributed to that, at least in
part.
Alternatively, you may want to investigate more capable options for
"really close support", with particular attention to target acquisition
and IFF (it's awkward to accidentally strafe your own side, or to make
a
low pass but not be able to find the dust-coloured dust-covered targets
on the dusty mountainside) rather than insist that a given weapon
system
is now and forever a fixture.
OFCS, the separation range mentioned in a couple of the reports (one from
a
participating Viper pilot and one from a CCT guy on the ground) was
*seventy-five meters*. Do you want any kind of bomb going off that close
to
*your* patrol if there is another method entailing less risk of
fratricide
available to be tried first? I wouldn't.
And the only options are 20mm cannon or 2000lb bombs? Think again. If
this is a genuine and frequent need, neither weapon is appropriate.
Nobody said "frequent". I have noted before that you seem ready to place
combat into the "nice neat box" category, where all things happen according
to plan, and there is a playbook for handling the proceedings. That just is
not the way it happens. Which is why flexibility is important. And I hate to
say it, but I think your empathy is a bit lacking--if it *were* you hugging
the dirt up close and personal and well within the danger close margin for
bombs, and you had the option of starting with guns and then working up
through higher risk alternatives, I suspect you'd do that as opposed to
starting with the more risky "big bang". It is a bit easier to say you
wouldn't when you are not facing that dilemma.
What is the real requirement, what is the real target, and is a M61
Gatling really the best solution? How about a different gun? How about
a
different type of munition? Is air-launched weaponry really the best
option for danger-close or should some other option be pursued?
For gosh sakes, Paul, we are talking a real world example where the M61
was
their best hope, at least initially.
No, we're talking about current and future procurement.
We have been using Anaconda as the point of discussion-the M61 was used in
that role by both USAF and (IIRC) USN aircraft during that operation.
Unless you plan your only combat to be action replays, then you need to
learn what worked and what didn't; decide what lessons are valid and
which were special cases; and then plan for the future so you do more of
what worked, less of what didn't work and learn from the Lessons
Identified.
Well, since it looks like the 25mm is going to be our next major gun caliber
for the fast movers, maybe that will satisfy some of your concern.
Remember, we (or at least I) am not talking about ripping guns out of
existing aircraft and plating over the ports; the issue is what to
procure in the future.
So if we have (God forbid) another Anaconda situation (and you know as
well
as I do that there *will* be someday another force inserted somewhere
that
will find the enemy in an unexpected place, in unexpected strength, and
find
itself fighting for survival), and our CAS stack is made up of Typhoons
and
STOVL F-35's sans guns, you think that is OK?
About as acceptable as declaring that there's no particular problem that
a few strafing passes won't completely solve.
Why would you claim that? I did not say any such thing. What I have been
saying is that when the ground guys find themselves in such a knife fight
and CAS is available, it is sure nice for that CAS to be able to contribute
to the fight. If it is successful in suppressing the bad guys (and I imagine
that it usually will at least be able to achieve short-term suppression), it
affords the troops a chance to either break contact or to maneuver into a
better situation. If it fails, then you have to do what SSG Brown did and
call in the heavier ordnance, accepting that you are placing your troops at
greater risk. I can't understand what you find disagreeable about allowing
those ground troops to escalate the risk level as needed, as opposed to
having to accept that greater risk of fratricide from the outset if you have
no gun capability.
What happens when the Bad Guys have a SA-11 parked out of sight? That's
serious trouble for anything flying within ten miles... bye-bye CAS
unless someone's willing to take some risks.
Taking risks is inherent to military operations. METT-T rules, and the
commanders get paid to weigh those risks versus gains. If you are
claiming
otherwise, then thank goodness our fathers who fought in WWII did not
take
that view.
I'm not the one claiming four situations in 17,500 sorties demonstrates
a completely untouchable situation, Kevin.
Neither am I; I shy away from such meaningless statistics. I recognize that
strafe is the least preferable manner of delivering effective CAS. I also
recognize that there is a lot of ground radiating out from between 25 meters
and (let's assume for the SDB which will shortly be in the inventory) maybe
20 meters, and retaining the ability to conduct immediate CAS requests
against such targets may very well mean the difference between
success/failure for the mission or life/death for the troops. Finally, I
recognize that the best laid plans can go to hell before you even cross the
LD, so "Semper Gumby" can be said to be the epitome of military slogans, and
the gun contributes to that.
Taking out an aircraft's gun is a risk (that somewhere in the future,
horrible things will happen for the lack of a strafing pass) but also an
opportunity (that's a thousand pounds more disposable load to use, and
training time freed up - now how to best use it?)
If there's a marginal capability (like danger-close CAS), does the gun
actually add much to it? Does it happen often enough to justify the very
real costs? Is there a better solution available or capable of
development?
Is it an unacceptable risk? Well, according to some... but then you get
into the mutual contradictions of "guns are essential weapons" and "it's
not worth developing anything better".
And it was my grandfather who fought in WW2, only his war started even
earlier than usual: he got a two-day head start on British and French
troops.
The idea is to stay out of as much avoidable predictable grief as
possible, and MANPADs and light AAA are known and hugely proliferated.
They're also most effective against an opponent flying a predictable
straight-line path... like a strafing run.
No, they are even more lethal to that guy flying the AC-130,
Who has the option of operating above the light AAA, though MANPADS are
a problem there too.
It does not matter how high he is operating-we don't like using the gunships
for daylight operations. Khafji put paid to that approach.
or to those
guys flying the cargo helos in to haul all those mortar and arty rounds
that
you would prefer we use exclusively.
Given that the mortars should be one to two miles back at least (for
81mm tubes, more for 120s) and artillery five to ten miles, that is one
_hell_ of a light AA gun or man-portable SAM that can detect and hit a
cargo flight at that distance while in contact with friendly troops and
under artillery fire. It's a *lot* easier to acquire and shoot at the
Big Loud Plane that just flew overhead.
Here is where your "should be" falls apart on the rocks of reality. During
Anaconda the troops found themselves engaged a lot earlier, and a lot more
heavily, than they predicted-that is war, with all of its uncertainty. So, I
'd assume (though I have not read anything to corroborate this) that the
plan was to have the mortars set up somewhere near the initial LZ's to cover
the troops movement to contact. By making contact a lot earlier than
anticipated, that put the mortars up near the close fight, and made the
resupply mission rather hazardous. Tube arty in this case was another
matter-Hagenbach, the MG in charge, has to shoulder the load for failing to
have a firebase set up within range, but he apparently did not anticipate
getting into a knifefight that precluded the use of the usual CAS delivered
bombs from the outset. Which is why those CCT's ended up begging for
strafing runs, again and again.
If the enemy air defences are _that_ good, you're definitely not wanting
to fly strafing passes.
Keeping a capability to strafe is worthwhile, but permanently giving up
a half-ton of useful payload while wearing a "Shoot Me!" sign is
perhaps
not the best solution to the problem.
I'd imagine had you been with those guys from the 10th LID who were so
happy
to get those strafing runs you'd have a slightly different view of the
value
of retaining that capability, as distasteful as having to resort to its
use
may be.
But the air-combat equivalent for a bayonet would be something on the
line of permanently issuing a halberd or bill, or at least a Bloody Big
Sword to every soldier and insisting it be carried everywhere they take
a rifle: it might be useful for those occasions where troops find
themselves at arm's length from the enemy, but it displaces a
significant amount of beans, bullets or batteries from the basic combat
load. A worthwhile tradeoff, or would the troops be better off with
more
of their main armament?
Not if their main armamnet was incapable of handling the situation that
arose. That is the difference, when viewed against the Anaconda model.
In at least one case the main armament had to be used anyway,
danger-close be damned.
ONLY as a last resort. Common sense dictates that you don't start off
treating a simple puncture wound to your hand by amputating the arm at the
elbow, though that option may be exercised later if the mere cleaning and
bandaging of the wound does not prevent blood poisoning. Likewise, those CCT
's did not jump directly to the risky use of bombs in a danger close
situation until they had exhausted their other less risky options.
Had
you taken up that M61 space and crammed a few new radios, or another few
pounds of fuel onboard, it would still not have allowed those CAS
aircraft
to do what they were *there* to do, which was support the troops engaged,
no
matter how close the separation of the two combatants. With the M61's
they
did that.
In four cases, with patchy results at best.
They DID it, which is more than they could have done had they lacked
those guns. Fratricide is a nasty thing, and we apparently came rather close
to a disastrous frat incident with one of those bombs-that is why those CCT'
s wanted to use the strafe first.
How about improving ground-to-air comms to shorten the targeting cycle?
More fuel, meaning more loiter time per aircraft, for more responsive
support? Both reduce the time needed from call-for-fire to delivery;
meaning instead of 'suppressing' the enemy with strafing passes, they
can be engaged with destructive weapons because they've had less time to
close. Or more payload, for a new munition that's got both short
danger-close and high lethality on target
Huh? They "closed" almost instantaneously in this event, from what I
have read. There was no detection of the bad guys in strength at 1000 meters
followed by maneuver to within danger-close limits-for gosh sakes, they
would have just pasted the guys with CAS delivered PGM's at the outset if
they had known they were there.
Again, you're not talking "a few pounds", you're talking about half a
ton: some wags would have you believe you could double an F-16's payload
that way. ("Wall-to-wall bombs today, boys, I'm carrying BOTH Mark
82s!")
The AH-64s got badly hammered (seven of eight badly damaged and IIRC
five were so shot up they never flew again...), and again IIRC the A-10
was pulled out early on because it struggled to cope with the
hot-and-high conditions.
Those AH-64's were indeed getting hammered--but because they hung around
and
continued to press home repeated gun runs against the critical targets.
How
many AH-64 crews were lost? None.
How many missions did they fly the next day? None. How much ordnance did
they deliver? None.
And they hung around because the guys on the ground were in deep do-do
and needed that support right then, not tomorrow. Tomorrow is meaningless if
you are likely to die today.
How many lives did they save on the
ground? We'll never know.
And how many helicopters were available to fly sorties the next day, and
the day after, and how many men could have died as a result? Or, what
was cancelled because the air support they needed for backup suddenly
wasn't there?
They were able to bring in replacement helos: IIRC some USMC AH-1W's
showed up to handle the attack helo role subsequent to having those Apaches
get shot up.
Losing a half-squadron of AH-64s in a single incident suggests that
there's a serious capability gap, not that the existing systems are just
fine.
Similarly, 88% attrition is _not_ sustainable.
Any source for that number? ISTR reading that most of those helos were
back up within the week (I only recall one being a write off at the time)?
The question is not "did they want strafe" but "did they want effective
fire support even at close range"? Not the same thing, not at all.
They wanted fire that would not also kill them in the bargain, which is
why
they repeatedly *requested* strafe, again and again. In some cases they
later resorted to using LGB's, with the curious methos of walking them in
as
if they were conventional rounds, from what I could decypher. And yet
they
still continued to request gun runs...wonder why?
Because those were the only two options available to them, and neither
sound satisfactory: the LGBs worryingly lethal over too large an area,
the gun runs inadequately lethal.
And they requested the gun runs in preference to the bombs-case
closed.
I doubt you'll find a soldier there who insisted on the support fire
coming from a given asset or weapon now and forever... provided it was
available and turned Bad Guys into Dead Guys (or at least Hiding Guys)
without creating blue-on-blue then it will be considered Good..
Yep, and what was available that day (or days, as IIRC this lasted well
into
the next day) was CAS, and what those soldiers kept asking for from the
CAS
was guns, at least in the early stages. Tells me they liked the guns.
Tells me they need another option available to them.
That may be, but I know of no other option that we can count on always
being onboard the loadout of the CAS packages. Even if APKWS was adopted by
the USAF it would not be an integral weapon. As it stands now we can get
some kind of CAS support at the 25 meters-from- friendlies- range from every
fast mover CAS aircraft we have-that is called flexibility.
Trouble is, when you've got an internal gun you've eaten up weight:
tending to, if you're using guns you're stuck with what you've fitted.
Remember, we're not discussing a major frontline capability here, but
an
emergency reversion. Can you justify _more_ guns when you have one
built
into the airframe anyway and crews expensively trained in its use?
It is not that important an issue. The fact is that all of the incoming
aircraft we will be fighting with in the foreseeable future, minus the
STOVL
version of the F-35, have guns included in their armament suites. I say
great, keep 'em and keep that flexibility they give us.
It must be wonderful having that much budget.
It is. And as we discussed earlier, the gun is a marginal part of the
total program cost. Which is maybe why most air forces still have them, and
why most, if not all, new aircraft orders, excepting that curious RAF
Typhoon situation, include them.
Then explain the STOVL JSF, which opted for a gun pod rather than an
internal solution despite CAS being high on its priority list.
From what I gather that was dictated by the addition of the STOVL
capability, which necessitates making room for the lift fan, etc.
But the STOVL version is more, not less, likely to be performing CAS.
How then can the gun be optional, if it's so effective and essential.
I did not say it was the most effective weapon-that is you twisting my
words (again). I said it affords a greater degree of flexibility, especially
in the very close fight, that you lose without the gun, and I believe that
flexibility is very important.
If the US can claim it's never run short of tanking assets in-theatre,
I'll call them liars, because they're the only force to achieve that.
And unless the tankers are flying low orbits over the firefights,
breaking off to refuel still means "not on station". More fuel means
more time between those absences.
Those absences are kind of meaningless if the alternative is another
couple
of circuits with an arament suite that does not allow you to serve the
customers down below, aren't they?
Yet again, armament suites are not fixed forever.
Ever try to specify what loadout you want from the air force side?
I doubt the groundpounder down below who
is in a situation where his options are such that he wants a strafe/can't
risk even a PGM is going to be very relieved by the knowledge that his
CAS
stack can do a few more circles without being able to actually handle his
request.
Having the enemy "suppressed" for a pass or two is not a great return on
investment either.
It is if it allows you to disengage, or if it allows you to maneuver
to a position offering better cover, or if it allows you to conduct an
assault to dislodge the bad guys. I believe if you asked the average ground
guy which he'd prefer to have, the ability to achieve short-term
suppression, or the inability to suppress at all, he'd take the former
Neither is having to use those PGMs even closer than the original "too
close" because the gun runs didn't do the job.
How much flying time does that get you, loitering in a notional 'CAS
stack'?
It does NOT matter if that CAS asset can't conduct the kind of attack you
need!
So you don't have the right weapons for the job? (20mm lacks
effectiveness, current PGMs too generous in their danger zones)
Bear in mind you're making force-wide assertions on the basis of 0.05%
of the offensive air sorties here.
Paging Mr. McNamara.
I'd suggest that if your CAS effort is so short of usable ordnance, or
so badly co-ordinated and equipped, that you're depending on guns...
you've also got something badly wrong.
You just don't get it, do you? "**** happens" in combat, and flexibility
is
what allows you to adjust. having that aerial gun option is a tool for
flexibility
snip what is undoubtedly the largest citation I have ever
encountered
Glad to see you found the article, Paul. Too bad you can't understand
the basic fact that those ground guys kept asking for strafing attacks
because they did not want to escalate their own risk until/unless they had
to.
Brooks
AIM-54 Phoenix missile Sujay Vijayendra Military Aviation 89 November 3rd 03 09:47 PM
P-39's, zeros, etc. old hoodoo Military Aviation 12 July 23rd 03 05:48 AM
