Jet Fuel
Old December 13th 03, 03:04 AM
Tarver Engineering
"Clark" stillnospam@me wrote in message
Do I understand that you don't know?
No, you do not understand.
Yes he does, Clark is an idiot.
Old December 13th 03, 03:46 AM
mg
Two mains products is used correctly:
About 12 minutes of flying time and whole lot a fun!
MG
"M. J. Powell" wrote in message
Does anyone know the products of combustion of, say, a ton, of jet fuel?
Mike
M.J.Powell
Old December 13th 03, 10:19 AM
Keith Willshaw
Hydrocarbons have about 2 hydrogens (CnH2n+2 for alkanes, CnH2n for
Alkenes,
etc.) for every carbon. Using decane (C10) or undecane (C11) to represent
jet
fuel may be reasonable - the density looks about right. You can figure an
average molecular weight somewhere in the large neighborhood of 150
#/#-mole
(that'll get you a rough number for molecules in a ton). The chemical
balance
and actual computation are left as an exercise for the student...
Actually Mike he just gave you the information you
need to work put the answer
Knowing the hydrogen/carbon ratio lets you work out the
water/co2 balance in the products of combustion
and with the atomic weights you can figure out the
rough masses , assuming complete conbustion.
Keith
Old December 13th 03, 11:40 AM
M. J. Powell
In message , Clark
writes
In message , Clark
writes
"M. J. Powell" wrote in newsKqxbJmQDe2
In message , Ron Parsons
writes
fuel?
Hmmm.... hydrocarbons plus oxygen.... about two tons of carbon
dioxide and water vapor?
Oxygen?
Yup, that's what "burning" requires. Generally, the atmosphere supplies
it in the form of O2.
I was asking about the products of combustion.
Yup. If you know what goes into the reaction then you know what comes out.
How much water vapour for one ton of fuel?
Alkenes, etc.) for every carbon. Using decane (C10) or undecane (C11) to
represent jet fuel may be reasonable - the density looks about right.
You can figure an average molecular weight somewhere in the large
neighborhood of 150 #/#-mole (that'll get you a rough number for
molecules in a ton). The chemical balance and actual computation are
Do your homework Mike and you will be able to answer your question.
I asked because I don't want to do more homework!
I looked up the previously given references and they told me everything
except what I want to know.
Mike
M.J.Powell
Old December 13th 03, 11:41 AM
M. J. Powell
In message , Keith Willshaw
writes
Alkenes,
jet
#/#-mole
balance
I can't. I was looking for some kind soul to help me.
Mike
M.J.Powell
Old December 13th 03, 07:46 PM
John Mullen
Clark wrote:
"M. J. Powell" wrote in news:Uj2uRaHhqv2$EwF0
@pickmere.demon.co.uk:
In message , Clark
writes
So, how's that working out for ya?
Assume jet fuel is pure decane, to simplify the calculation.
C10H22 + 15.5O2 - 11H20 + 10CO2
1 mole C10H22 = 142g
1 mole H2O = 18g
1 mole CO2 = 44g
So for every tonne (1000kg) of decane burned, assuming 100% combustion,
you will have
1000000/142 * 11 * 18g = 1394360g = 1394kg water
1000000/142 * 10 * 44 = 3098590g = 3098kg carbon dioxide
Which comes to about 4492kg of products. Where does the extra weight
come from?
Obviously from the oxygen used to burn the fuel, which comes to
1000000/142 * 15.5 * 32g = 3492957g = 3492kg
The assumptions made won't have much effect on the calculation, and
neither will rounding error. The biggest error probably comes from the
100% combustion; from the smell they make, most jets give out quite a
bit of unburnt fuel. Right ball park though.
HTH
John
Old December 13th 03, 09:01 PM
M. J. Powell
In message , John
Mullen writes
In message , Clark
writes
1 mole H2O = 18g
1 mole CO2 = 44g
you will have
come from?
HTH
It does indeed. Thank you very much.
Mike
M.J.Powell
Old December 13th 03, 10:59 PM
Tarver Engineering
In message , John
Mullen writes
In message , Clark
writes
1 mole H2O = 18g
1 mole CO2 = 44g
you will have
come from?
HTH
Just remember not to confuse a metric ton with 2000 lbs.
Old December 13th 03, 11:39 PM
M. J. Powell
In message , Tarver Engineering
writes
In message , John
Mullen writes
In message , Clark
writes
1 mole H2O = 18g
1 mole CO2 = 44g
you will have
come from?
HTH
I'm used to 2240 lbs/ton.
Mike
M.J.Powell
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Home Built 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Aviation Marketplace 0 January 26th 04 07:48 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
