How much fuel do you prefer to carry?
Old August 10th 08, 10:23 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Default How much fuel do you prefer to carry?
Mxsmanic wrote in
Rocky Stevens writes:
Sorry for the non-aviation blurb; lack of a fuel gauge in motorcycles
is just a pet peeve of mine.
There's no excuse for designing motorcycles without fuel gauges. Then
again, the systems of small aircraft seem just as frozen in time.
You are a moron.
Bertie
  #83
Old August 10th 08, 10:26 PM posted to rec.aviation.piloting
B A R R Y wrote in news:NPGnk.35455$ZE5.11635
@nlpi061.nbdc.sbc.com:
Rocky Stevens wrote:
Never thought of it that way. I ride a motorcycle, and motorcycles
have a "reserve" tank (not really a separate tank) that you can switch
to when you "run out" of gas
There are a few old planes with the same setup.
I think some Taylorcrafts had a reserve tank.
Bikes don't have a resere tank, they have a stand pipe that takes the
normal supply from an inch or two up in the tank. When that runs dry, you
selct reserve and you can get at all the fuel.
No airplane ever had that kind of instalation
The "reserve" in the T-craft was another tank that fed into the main in the
nose. Lots of airplanes of the period have this setup.
Bertie
  #85
Old August 10th 08, 10:27 PM posted to rec.aviation.piloting
Mxsmanic wrote in
It is shocking to me how many of these accidents exist; and it ain't
just new pilots. For example, the head instructor of the accelerated
school that was the subject of "getting my license in 7 days"
(http:// http://www.popularmechanics.com/blog...s/2092132.html)
died because he ran out of gas.
It makes me wonder how often this happens with motor vehicles in
general.
Of course it does. You have no clue as to how any machine works.
Bertie
  #87
Old August 10th 08, 10:35 PM posted to rec.aviation.piloting
On Aug 10, 5:17*pm, Mxsmanic wrote:
writes:
If an engine's leaning is inadvertently changed (it's been known to
happen that a right seat child does something like that, or even
vibration can sometimes) or the fuel cover on a high wing airplane
comes off, or a tank begins leaking fuel use will change markedly.
Having the left wing go dry unexpectedly is a LOT better than having
both wings go dry unexpectedly. This is a real world consideration.
Granted, but most fuel starvation and exhaustion accidents do not seem to
involve things like this. *Pilots simply fail to plan, and then sometimes
react inappropriately when the fuel runs out or runs low.
I don't recall seeing any accidents involving mixture changes or fuel-cover
losses, but it's certainly possible. *A pilot should be monitoring engine
gauges, however, and should notice a change in mixture or fuel consumption. He
might even be able to detect it by sound in some aircraft.
Actually, mixture problems, and carb ice on normally asperated
engines, show up on EGT first. Headsets that most pilots wear do not
allow subtle variations in engine sound through, which is why on take
off I have one ear uncovered. But mixture problems do occur, and are
one reason of several I cited as to why having the ability to select
fuel tanks, rather than drawing from both, is safer. That was the
issue, I answered it, and you are attempting to divert the
conversation from an area where your reasoning has been questioned.
Again.
  #88
Old August 10th 08, 10:39 PM posted to rec.aviation.piloting
On Aug 10, 5:24*pm, Mxsmanic wrote:
writes:
Although the regulations don't say it yet sooner or later we'll be
cited as failing pilots for not ANTICIPATING a critical part failure.
I had the carb heat cable break on a Mooney Ranger once. It was on a
non precision approach to an uncontrolled field in IMC, and if you
have any experience with those airplanes you know they love to form
carb ice.
Is there some regulation you failed to comply with that could have prevented
this?
I know airliners have regularly scheduled maintenance at multiple levels that
is supposed to catch all sorts of potential problems, but do small aircraft
have the same requirements? *Apart from required engine maintenance, what
other maintenance is required by regulations?
We fly in compliance with regs and POH. There is no regulation that
will predict the breaking of a cable connector. In some cases such a
breakage could lead to an accident. In this case I was lucky, the
accident 'chain' was broken before the airplane was.
  #90
Old August 10th 08, 10:43 PM posted to rec.aviation.piloting
Buster Hymen
Mxsmanic wrote in
There is no excuse for your existence, fjukwjit.
One More Reason I Prefer GA Kyle Boatright Piloting 19 December 27th 06 11:53 PM
Is it a habit we prefer mechnical instruments? [email protected] Home Built 80 April 28th 06 04:05 AM
Does V-22 Go Twices as Far, carry Twice as Much? Nick Lappos Rotorcraft 26 October 12th 05 08:11 PM
Headset wanted - prefer David Clark Marty from Sunny Florida Aviation Marketplace 0 October 5th 04 02:54 PM
things to carry Gary Drescher Piloting 62 July 20th 04 03:08 AM
