Two questions that I've been wondering about -- w/t vortices andlift.
Old August 11th 08, 07:32 PM posted to rec.aviation.piloting
Tman
Default Two questions that I've been wondering about -- w/t vortices andlift.
OK, these are trivial, but nonetheless been bugging me and the guys at
the airport don't have a satisfying answer;
1. Why do wing tip vortices sink? They're not made out of lead.
2. 747 overflies at FL 310 (or whatever). Is the weight of the airplane
ultimately supported by the earth's crust? How?
FWIW, my opinions on these: #1: because of a general downwards movement
of air in the wake, induced by lift. I've also heard that the
turbulence causes locally increased pressure and thus density, but I
s'pose it was also create locally reduced pressure -- so I don't believe
that factor.
#2: Yes, the wake of a overflying aircraft will cause a downward
acceleration of the air, which reacts with the surface of the ground
creating a locally higher pressure when it decelerates. Of course the
effect at FL310 is spread over such a large area that the effect at any
point is incredibly small, but it is spread over such a large area that
it in effect is supporting the weight of the A/C.
Ground effect at FL310 anyone?
T
Old August 11th 08, 08:15 PM posted to rec.aviation.piloting
Default Two questions that I've been wondering about -- w/t vortices and lift.
that factor.
The tip vortices do have a different pressure/temperature which can
be seen on humid days when vapor condenses and they become visible.
Though which effect is the dominate one that causes them to go down
I haven't a clue.
Nope, that's the old rockets can't work in space because they have
nothing to push against arguement redressed.
F=ma doesn't require the accelerated air to bounce off of anything.
Jim Pennino
Remove .spam.sux to reply.
Old August 11th 08, 08:21 PM posted to rec.aviation.piloting
Darkwing
"Tman" x@x wrote in message
OK, these are trivial, but nonetheless been bugging me and the guys at the
of air in the wake, induced by lift. I've also heard that the turbulence
causes locally increased pressure and thus density, but I s'pose it was
also create locally reduced pressure -- so I don't believe that factor.
point is incredibly small, but it is spread over such a large area that it
T
I hope this doesn't turn into the "airplane on a treadmill" redux.
Old August 11th 08, 08:26 PM posted to rec.aviation.piloting
Sylvain
here is an excellent website / online book that addresses many of these
questions:
http://www.av8n.com/ "See how it flies"
--Sylvain
Old August 11th 08, 09:48 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
wrote in :
at the airport don't have a satisfying answer;
airplane ultimately supported by the earth's crust? How?
movement of air in the wake, induced by lift. I've also heard that
the turbulence causes locally increased pressure and thus density,
but I s'pose it was also create locally reduced pressure -- so I
Uh, no, that's not it. The vector as the air leaves th ewingtip is
generally downwards, that's why the travel is down. Also the reason they
travel out.
I haven't a clue.
the effect at FL310 is spread over such a large area that the effect
at any point is incredibly small, but it is spread over such a large
area that it in effect is supporting the weight of the A/C.
It's not bouncing off anything, but the wieght of the airplane is still
borne by the air, ultimatley, though some of that is traded as drag.
Is a fly buzzing around the inside of th same ariplane contributing more
weight wehn it lands on the edge of your coffee cup?
Bertie
Old August 12th 08, 12:20 AM posted to rec.aviation.piloting
"Bob F." wrote in
wrote in news:l5f6n5-hp7.ln1
@mail.specsol.com:
they
travel out.
They travel outward because that's where the lower pressure is.
Well, in a way, yes, but they travel outward molecule by molecule so
it's a bit lie saying the wind blows because the trees wave back and
forth.
The spanwise flow is stronger on the bottom than the top of the wing and
the tendency is for the flow to travel around the edge of the wingtip.
It's all down to the force applied on them as they stream off the end of
the wing. all of the componenets of lift add up to them traveling out
and down, ultimately.
Bertie
Old August 12th 08, 12:28 AM posted to rec.aviation.piloting
BT
why do spinning baseballs curve.. the same effect from the spinning
vortices.. and the effect of the initial movement of the vortices as it
leaves the wing tip is down
T
Just wondering..... [email protected] Soaring 7 April 4th 06 03:13 AM
Wake vortices... a sterile danger? Ramapriya Piloting 20 December 20th 05 05:36 PM
Just wondering... Fritz Piloting 7 June 19th 05 05:03 AM
Wondering about the F-102... Bill McClain Military Aviation 49 February 22nd 04 03:54 PM
I was wondering Badwater Bill Home Built 2 August 6th 03 04:38 AM
