vintage powered glider
Old August 13th 08, 07:10 PM posted to rec.aviation.soaring
Chip Starr
Default vintage powered glider
Can anyone out there give me an idea of what a vintage powered sailplane is
worth? It is a Hawk model 3 1963 powered sailplane. In great condition,
with all log books, missing gauges.
Thanks,
Chip
Old August 13th 08, 08:25 PM posted to rec.aviation.soaring
Bob Kuykendall
On Aug 13, 11:10*am, Chip Starr wrote:
...It is a Hawk model 3 *1963 powered sailplane...
Never heard of it. Is it a production unit, or a one-off homebuilt? Do
you have a photo of it? Also, the N-number might give us a clue.
One thing to watch for is that aircraft homebuilders will sometimes
construct an aircraft from a kit or from plans, and then register it
as having a type completely unrelated to original design. For example,
I've seen RVs and HPs show up as type "QS-1" and stuff like that.
There is absolutely no rule that says that a homebuilder has to
register the aircraft they built from their RV-6 kit as an "RV-6." The
homebuilder is the manufacturer of record, and they can call it
anything they want.
As for value, that could be anywhere on the map depending on
condition, performance, utility, and historical value. If you're the
owner, the most practical way of determining the value is to offer it
for sale and see what people offer for it. And for that, you might
find that eBay is your best bet.
Thanks, Bob K.
Old August 13th 08, 09:15 PM posted to rec.aviation.soaring
vontresc
anything they want.
Thanks, Bob K.
Wow that is one ugly airplane.....
http://1000aircraftphotos.com/Contri...avidJ/7500.htm
Pete
Old August 13th 08, 09:23 PM posted to rec.aviation.soaring
Vaughn Simon
"vontresc" wrote in message
Ugly yes! But it has an amazingly unique propeller stowing scheme.
Vaughn
Nothing personal, but if you are posting through Google Groups I may not receive
your message. Google refuses to control the flood of spam messages originating
in their system, so on any given day I may or may not have Google blocked. Try
a real NNTP server & news reader program and you will never go back. All you
need is access to an NNTP server (AKA "news server") and a news reader program.
You probably already have a news reader program in your computer (Hint: Outlook
Express). Assuming that your Usenet needs are modest, use
http://news.aioe.org/ for free and/or http://www.teranews.com/ for a one-time
$3.95 setup fee.
Will poofread for food.
Old August 13th 08, 09:36 PM posted to rec.aviation.soaring
Bob Kuykendall
Good catch! I did a few searches before giving up.
Does anybody else think that the fuselage and vertical fin (what we
can see of them) looks a lot like LK-10A/TG-4 truncated at the front
cockpit? The wing is obviously in the wrong location for an LK
fuselage, but that could easily be a modification.
Say what you want about the aesthetics, but the retractable cowl
cheeks and pivoting engine are a pretty nifty solution to the problems
of engine-off cooling drag and prop drag.
Thanks, Bob K.
Old August 13th 08, 09:49 PM posted to rec.aviation.soaring
JJ Sinclair
Yep, it looks like the illegitimate offspring of an LK-10 with a put-
put.
JJ
Old August 14th 08, 05:25 AM posted to rec.aviation.soaring
raulb
worth? *It is a Hawk model 3 *1963 powered sailplane. *In great condition,
Thanks,
Chip
Haufe Dale Hawk Model 3, motor glider, 1 built, 469.6 lbs (213
kg), 40' span (12.34 m)
Since it is a one-off, it is worth what someone is willing to pay for
it.
Old August 14th 08, 10:55 AM posted to rec.aviation.soaring
Glenn Davis
Is this what you mean
http://cgi.ebay.co.uk/Aircraft-T21t-X-RAF-self-sustaining-Glider-No-reserve_W0QQitemZ280255595912QQcmdZViewItem?hash=i tem280255595912&_trkparms=72%3A984|39%3A1|66%3A2|6 5%3A12&_trksid=p3286.c0.m14.l1318
At 04:25 14 August 2008, raulb wrote:
sailplane
is
worth? =A0It is a Hawk model 3 =A01963 powered sailplane. =A0In great
con=
dition,
Thanks,
Chip
it.
Old August 14th 08, 04:29 PM posted to rec.aviation.soaring
Bob Kuykendall
On Aug 14, 2:55*am, Glenn Davis wrote:
Is this what you mean...
I think that's more in the way of a powered vintage sailplane, as
opposed to a vintage powered sailplane...
Thanks, Bob K.
Vintage glider newsreels. Excellent! [email protected] Soaring 2 May 3rd 08 09:08 AM
FAA Powered Glider Definition Mike Schumann Soaring 4 July 20th 07 06:26 PM
jet powered personal glider [email protected] Owning 18 March 15th 05 11:07 PM
Powered gliders = powered aircraft for 91.205 Mark James Boyd Soaring 2 December 12th 04 03:28 AM
Odp: Vintage Glider PWS 102 PWS 101 Janusz Kesik Soaring 0 September 29th 03 08:25 PM
