Jet Fuel
Old December 14th 03, 06:43 AM
John Mullen
M. J. Powell wrote:
In message , Tarver Engineering
writes
"M. J. Powell" wrote in message
In message , John
Mullen writes
news:Uj2uRaHhqv2$EwF0
@pickmere.demon.co.uk:
In message , Clark
writes
Do your homework Mike and you will be able to answer your question.
I asked because I don't want to do more homework!
So, how's that working out for ya?
Assume jet fuel is pure decane, to simplify the calculation.
C10H22 + 15.5O2 - 11H20 + 10CO2
1 mole C10H22 = 142g
1 mole H2O = 18g
1 mole CO2 = 44g
So for every tonne (1000kg) of decane burned, assuming 100% combustion,
you will have
1000000/142 * 11 * 18g = 1394360g = 1394kg water
1000000/142 * 10 * 44 = 3098590g = 3098kg carbon dioxide
Which comes to about 4492kg of products. Where does the extra weight
come from?
Obviously from the oxygen used to burn the fuel, which comes to
1000000/142 * 15.5 * 32g = 3492957g = 3492kg
The assumptions made won't have much effect on the calculation, and
neither will rounding error. The biggest error probably comes from the
100% combustion; from the smell they make, most jets give out quite a
bit of unburnt fuel. Right ball park though.
HTH
It does indeed. Thank you very much.
Just remember not to confuse a metric ton with 2000 lbs.
I'm used to 2240 lbs/ton.
Mike
Well you can just scale it up, it's a ratio. 1 ton of fuel + 3.5 tons
oxygen gives 1.4 tons water and 3.1 tons carbon dioxide, whichever
version of the ton/tonne you use, and there are at least three that I
know of!
John
Old December 14th 03, 11:27 AM
M. J. Powell
In message , John
Mullen writes
Mike
know of!
Yes, thank you. It was just the round figures that I wanted to bolster
up my general theory about the weather.
Mike
M.J.Powell
Old December 17th 03, 07:29 PM
Harry Andreas
In article , John
You only smell them when they're on the ground (for the most part)
and operating at partial throttle and low Tit.
When they're operating at higher throttle settings and higher
temps the combustion is more complete.
The higher combustion temp also forms NOx's.
Harry Andreas
Engineering raconteur
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Home Built 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Aviation Marketplace 0 January 26th 04 07:48 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
