New starter in a 172 2005
Old August 16th 08, 03:53 AM posted to rec.aviation.owning
Default New starter in a 172 2005
On Aug 15, 8:16 pm, "Mike" wrote:
"passenger 1957" wrote in message
I'd still like to know if I should push for a better starter or are
they all about the same? (I don't mind spending extra money if it will
help push off a similar problem) Where might I send the fried one to
see if it's either a 'bad unit' or to see if there's some other
problem to look into?
It all just depends on why your starter failed in the first place. If it
failed because someone is overcranking the starter, I don't know that a
better starter is going to fix your problem. I'm fond of Sky-Tec starters,
but I've had problems with those also. However my problem was related to a
starter adapter which your plane doesn't have. You may already have a
Sky-Tec as I've heard they come as standard equipment on some newer planes,
but I'm not sure if this is true or not.
We have four Magnaflite starters used in flight training
(which means frequent and sometimes abusive starts), and had several
more before these four, and *none* of them have ever given trouble.
They all go to the engine's TBO. The Lamar on an O-470 we had in an
older 182, on the other hand, was a pain, lacking cranking torque, and
the old Prestolites can also make life miserable at times, with brush
and bearing issues.
Lycoming sends their engines out with Magnaflites. If they like
them, then I do, too.
Dan
Dust Devil 2005 - South African National Gliding Championships 2005 [email protected] Soaring 0 December 27th 05 09:20 AM
Starter Denny Owning 6 September 27th 05 10:32 PM
C-150 (O-200) Starter Dave Home Built 0 November 25th 04 10:57 AM
C-150 (O-200) Starter Dave Restoration 0 November 25th 04 10:57 AM
Starter Questions Aaron Coolidge Owning 4 June 30th 04 02:52 PM
